After a restart of my hassio my homematic hassio addon has stopped working. I have done several restarts and reinstalled the plugin without success. One of the error messages I get is the one below. Anyone a clue ?
2020-02-22 21:15:01,453 [INFO] InterfaceInitializer - Added InterfaceId: homeassistant-hmip
de.eq3.cbcs.legacy.communication.rpc.RpcSerializationException: javax.xml.stream.XMLStreamException: ParseError at [row,col]:[81,15]
Message: found: CHARACTERS, expected START_ELEMENT or END_ELEMENT
at de.eq3.cbcs.legacy.communication.rpc.internal.format.xml.XmlRequestResponseProcessor.parseResponse(XmlRequestResponseProcessor.java:173)
at de.eq3.cbcs.legacy.communication.rpc.internal.transport.http.HttpTransport.sendRequest(HttpTransport.java:107)
at de.eq3.cbcs.legacy.communication.rpc.internal.rpc.RpcClient.sendRequest(RpcClient.java:94)
at de.eq3.cbcs.legacy.communication.rpc.internal.rpc.RpcClient.invoke(RpcClient.java:82)
at com.sun.proxy.$Proxy23.listDevices(Unknown Source)
at de.eq3.cbcs.legacy.bidcos.rpc.internal.LegacyBackendClient.listDevices(LegacyBackendClient.java:139)
at de.eq3.cbcs.legacy.bidcos.rpc.internal.DeviceUtil.synchronizedBackendDevices(DeviceUtil.java:142)
at de.eq3.cbcs.legacy.bidcos.rpc.internal.InterfaceInitializer.handle(InterfaceInitializer.java:109)
at de.eq3.cbcs.legacy.bidcos.rpc.internal.InterfaceInitializer.handle(InterfaceInitializer.java:26)
at io.vertx.core.eventbus.impl.HandlerRegistration.deliver(HandlerRegistration.java:212)
at io.vertx.core.eventbus.impl.HandlerRegistration.handle(HandlerRegistration.java:191)
at io.vertx.core.eventbus.impl.EventBusImpl.lambda$deliverToHandler$3(EventBusImpl.java:505)
at io.vertx.core.impl.ContextImpl.lambda$wrapTask$2(ContextImpl.java:337)
at io.vertx.core.impl.TaskQueue.lambda$new$0(TaskQueue.java:60)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:834)
Caused by: javax.xml.stream.XMLStreamException: ParseError at [row,col]:[81,15]
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLStreamReaderImpl.nextTag(XMLStreamReaderImpl.java:1361)
at de.eq3.cbcs.legacy.communication.rpc.internal.format.xml.XmlRpcParser.parseObject(XmlRpcParser.java:437)
at de.eq3.cbcs.legacy.communication.rpc.internal.format.xml.XmlRpcParser.parseValue(XmlRpcParser.java:394)
at de.eq3.cbcs.legacy.communication.rpc.internal.format.xml.XmlRpcParser.parseArray(XmlRpcParser.java:521)
at de.eq3.cbcs.legacy.communication.rpc.internal.format.xml.XmlRpcParser.parseValue(XmlRpcParser.java:387)
at de.eq3.cbcs.legacy.communication.rpc.internal.format.xml.XmlRpcParser.parseMethodResponse(XmlRpcParser.java:164)
at de.eq3.cbcs.legacy.communication.rpc.internal.format.xml.XmlRequestResponseProcessor.parseResponse(XmlRequestResponseProcessor.java:171)
... 16 more
2020-02-22 21:15:01,512 [ERROR] InterfaceInitializer - Serialization Exception: Could not add interface: homeassistant-hmip
