Hello all,
since a couple of weeks I´m dealing with smart home. I´ve not very much experience. I started to buy a raspberry and I´ve successfully installed home assistant. I also have successfully integrated my ip cam. Everything works fine so far. My next step is to buy more smart hardware to integrate more components to home assistant. I would like to start with replacing my light switch in the kitchen. After some research, I´m prefering the following product:
Homematic IP HmIP-BSM
http://www.eq-3.de/produkte/homematic-ip/licht/homematic-ip-schalt-mess-aktor-fuer-markenschalter.html
Now I have the following question:
Is it possible to integrate this component to home assistant without the Homematic IP Access Point or is the Access Point necessary?
Best regards,
Pauleo77
