I am new to HA and am trying to set up Homematic on ODROID supervised HA install. I followed the install and got stuck on setting up the integration and connect to the RaspberryMatic.
The firewall has been opened and I searched the forum but my error seems different, here is the log:
Logger: hahomematic.central
Source: custom_components/homematicip_local/control_unit.py:770
Integration: homematicip_local ([documentation](https://github.com/danielperna84/custom_homematic), [issues](https://github.com/danielperna84/hahomematic/issues))
First occurred: January 6, 2024 at 21:16:29 (16 occurrences)
Last logged: 10:22:11
* URL can't contain control characters. ' de838cd8-raspberrymatic' (found at least ' ')
* OSError on temporary_instance-BidCos-RF: (-5, 'Name has no usable address')
* OSError on temporary_instance-BidCos-Wired: (-5, 'Name has no usable address')
I tried to enter the hostname manually, by copying and from 2 different browsers but result stays the same.
Tried reinstalling everything, the error is now only that first empty entry
This error originated from a custom integration.
Integration: homematicip_local (documentation, issues)
First occurred: 13:20:16 (3 occurrences)
Last logged: 13:28:59
There must be something missing from your logs. In any case, read the docs very carefully. Make sure the firewall and username + password match the documented specifications.
Im having the exact same problem, read the docu, triple checked everything.
When I enable debug logging, I get the following output (same warning message in last line and setup fails):
What device are you using to communicate with the Homematic devices?
Im using HA OS in a VM and pass a USB HmIP-RFUSB-TK through.
HmIP-RFUSB-TK is a third party RFUSB by Telekom for their router and there is some information online that it does not have the exact same featureset/firmware as the standard HmIP-RFUSB.
Maybe that is the reason why it fails @danielperna84 ?
I use debmatic for the CCU software and they have this about the Telekom stick.
HmIP-RFUSB-TK (Telekom Version, nur HmIP Funk, Firmware Updates nicht möglich, Funktionalität nicht dauerhaft sichergestellt.
It says that only Homematic IP is available. That updates of the stick is not possible and that all the features in the CCU have not been tested on the stick, so it is uncertain what is supported.
I am using a HA supervised install on Odroid hardware, with Raspberrian on same environment, and HM-Lan-GW to connect with HomeMatic Wired devices on RS485. I still have the same issue and with Debug logging on I only get what you see below.
All devices are operating in Raspberrian, another HA setup where I used the earlier integration also works fine, but for some reason I can’t get past this step.
2024-04-05 10:17:45.581 WARNING (MainThread) [hahomematic.central] ()
2024-04-05 10:19:33.971 DEBUG (MainThread) [custom_components.hacs] Nothing in the queue
Today my HmIP-RFUSB arrived and now Homematic IP local works perfectly fine. I didn’t even need to change any other configurations, just swapped the USB.
So for me using the HmIP-RFUSB-TK was the problem, even if Raspberrymatic worked without any issues before.
While this may not be helpful towards fixing things, it shows that the issue probably lies within the used RF module/GW.
The -TK version is a stick bought as a white-label product by Telekom together with a range of the Homematic IP products and then labeled as a Telekom brand.
It was meant to be a clsoed ecosystem and not part of the Homematic one.
