[Homematic IP] Missing entity from HmIP-BWTH sensor
Hello everybody,
this is my first question so please be gentle I’m still learning :slight_smile:
What I did:
  • integrated HmIP-BWTH into my CCU3 --> works fine
  • that thermostat can be seen/found in home assistant --> also fine
  • I’m able to plot the humidity from this sensor in grafana
My problem:
I cannot plot the temperature in grafana since the entity of the temperature cannot be found. So with my other thermostats (HmIP-STHD) I see for instance the humidity and the actual temperature entities:
but for the HmIP-BWTH sensor there is no actual temperature:
So my two questions short:
  1. How do I get this entity?
  2. How do I plot the temperature from this sensor in grafana?
Thank you in advance!
take a look at Is there a list of attributes?
In your example go to http://:8123/developer-tools/template
and let you show all attributes with {{ states.climate.hmip_bwth_.attributes }}
To use it you need an template to show the attribute
