Hi!
I’ve connected my RaspberryMatic to HA using the following configuration in configuration.yaml
homematic:
interfaces:
ip:
host: 192.168.2.3
port: 2010
jsonport: 80
ssl: false
verify_ssl: false
resolvenames: "json"
username: "Admin"
password: "redacted"
hosts:
ccu3:
host: 192.168.2.3
port: 2001
username: "Admin"
I have a single HMIP Motion Sensor attached to it which HA discovered nicely. However, HA doesn’t recognize any motion detection. Checking RaspberryMatic I can confirm motion being detected, meaning the device itself is working fine, it’s just not ending up in HA.
In addition (but maybe totally unrelated), I’m getting the following error in my logs:
Entity homematic.ccu3 (<class 'homeassistant.components.homematic.entity.HMHub'>) does not have a platform, this may be caused by adding it manually instead of with an EntityComponent helper, please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue
Am I missing some configuration?
Any help is highly appreciated!
I just found a solution:
What broke it was the fact that I only opened specific ports for my HA Docker container. Switching it to network_mode: host
solved it but for some reason broke / slowed the Unicast connection with my Shellys.
So I ended up tweaking my config as follows:
homematic:
local_port: 8060
interfaces:
ip:
host: 192.168.2.3
port: 2010
jsonport: 80
ssl: false
verify_ssl: false
username: "Admin"
callback_ip: 192.168.2.2
callback_port: 8060
hosts:
ccu3:
host: 192.168.2.3
port: 2001
username: "Admin"
(note the added local_port
and callback_
parts)
while at the same time of course passing port 8060 into the Docker container.
Everything is working as supposed now!
It’s not broken, but outdated and unmaintained. Support for new devices won’t be added, and the new integration is A LOT better in many ways.
How would I install this in my Docker container? Do I just copy&paste custom_components/homematicip_local
into my local custom_components/
folder?
I would suggest to use HACS, as this will make it easy to update the integration in the future. Here’s a pretty good walkthrough on how to set up HACS and the new HomeMatic integration: HomeAssistant Integration · jens-maus/RaspberryMatic Wiki · GitHub
