Homematic IP window/door contact
Hi all,
I implemented a (optical) window contact but I dont know how to setup as common sensor. There is no status like on/off open/closed or something like that. Just get the rssi value which changes depending on position of the window contact.
Can someone give me a hint how to make use of this changing rssi value?
Thx
Sven
You can store the data you receive in an analog sensor, and then use a template binary sensor to determine if it is open or closed. See the sensor threshold example
  • platform: template
    sensors:
    door_open:
    friendly_name: “Door open”
    value_template: >-
    {{ states.sensor.hip_frontdoor_status.attributes.rssi | float < -36 }}
Working fine. THX Sven
