Homematic IP wired Integration
Hi everyone,
so I learned, that the Raspberry Matic is an available addon for Home Assistiant.
Some modules, especially the 32 DI with corrosion protection and Shutter Actor would help a lot in my planned Automation concept, as I want to use “normal” buttons that are wired to the central cabinet.
Does anybody here has experience with integration Homematic IP wired in Home assistant? From what I understandy I would need the Access Point and all the peripheral modules in the central cabinet and then a Raspberry Matic addon in Home assistant. But:
  • There seams to be an Issue integrating the HMIPW-DRAP in the Addon - but isnt this the only way to integrate the HomematicIP wired components?
  • When using the mentioned 32 DI, does it support measuring how long a button is pressed (for realizind different actions with one button)
  • Can more advanced devices like the glass display also be used in this combination?
