Im trying to get the Homematic Keypress working, afters hours of searching of the same topics i still have problems and no clue how to solve it. I bought a HMIP WRC2 device and added it into my CCU, also done the workaround with create a programm for both channels as written in Homematic - Home Assistant.
But when i press the button nothing happens.
is there anything in the coding I did wrong?
My code is:
Not at first glance. I would enable debug logging for pyhomematic and the homematic platform (has been mentioned here in the forum several times, don’t know from the top of my head the exact syntax). There you should at least see the events in the logs. If you don’t see the events there, the program on the CCU might have some problem.
The code from my first post is my automation, so im not sure why the logs saying Wohnzimmer_lichtschalter instead of 00019D899762D6. In the ccu I gave the name Wohnzimmer_lichtschalter to serial 00019D899762D6. I will delete everything and Setup everything new to get a fresh start, maybe that will help.
Anyway thanks for trying to solve my problem, I will post later if the result of the logs changed after fresh setup.
