Homematic Motion Detector
I have an HM motion detector (HMIP SMI55) showing the movements under Hassio. The question is how do I get it that as soon as he detects movement, a lamp is switched on and goes off again after 2 minutes. How can i find out witch singnal will be sed by motion?
Thats wat i tested without function:
platform: state
entity_id: automation.bewegungsmelder
for: '0:00:05'
to: 'on'
Thereā€˜s a default blueprint that you just need to provide the motion sensor entity and the light entity
where to find?
Einstellungen > Vorlagen
It seems the Homematic IP presence detectors are not showing up correctly as motion detectors in HA. They also cannot be used in the template. Any advice?
