Since I’m using the “normal” home assistant running in a docker container on my Pi, I want to integrate it in the same way like seen in the video (no extra hardware etc).
Is there a way to do that?
I only found the homematic component which requires a running homematic server (you have to enter the IP), but no possibility to just use a local USB device.
Isn’t it possible to use a component for that if there is one for hassio?
IP components would be totally ok (I mainly want to use the blind shutter controllers) - so the stick would be enough. The question is how I can use it with the “normal” home assistant?
I am not sure if I understand the question correctly. if you have connected the components to the Homematic manager. You cam See they as entities in Home Assistant.
