Homematic Set Value inhibit
Hello. Im Quite new to Home Assistant. After 2 days of exploring im totallly blown away by this System. Now i want to find out if i can move from my existing system to Home assistant.
I have a First small question surrounding Homematic. How can i set the „Inhibit“ value of a Switch or Sensor to True/False via Script or automation?
Best regards,
André
There’s no native way of doing it, and the PR for the feature has not been merged. It should be possible though to do it manually by either using the set_device_value or put_paramset services.
Thanks. A closer look at the homematic docs here gave me an idea. Now i Need to Understand how to work with scripts(when i find the time)
