Homematic.virtualkey service
I’m working with Home Assistant + Homematic CCU3 since a couple of days.
My first impression : I’m amazed about the possibilities that Home Assistant offers !
I’m new on the forum so I’m probable asking something stupid but still…
I’m trying unsuccessfully to trigger a virtual key on the CCU3 with a Button I made.
Using the “Developer Tools” / “Service” / “homematic.virtualkey” everything works fine
But when I put it into my http://homeassistant:8123/lovelace it doesn’t work anymore…
      - type: button
        tap_action:
          action: call-service
          service: homematic.virtualkey
          address: BidCoS-RF
          channel: 14
          param: PRESS_SHORT
        hold_action: none
I get this on the Log:
[2975940368] required key not provided @ data[‘channel’]
2:06:17 PM – websocket_api (ERROR) - message first occurred at 12:57:03 PM and shows up 43 times
Could anybody help me out with this ??
Thanks a lot !!
Hello Daniel,
did you solve your problem? I have the same problem.
I tryed this:
type: button
address: HmIP-RCV-1
channel: 26
param: PRESS_SHORT
But it not work :frowning:
Greetings Tobias
This might be the same / similar problem as reported here: Homematic.keypress giving inconsistent results
Hello tryan,
it works for me now. My code looks like this…
    - type: button
      name: Turn outside light off
      icon: mdi:lightbulb
      tap_action:
        confirmation:
          text: Are you sure?
        service_data:
          address: BidCoS-RF
          channel: 14
          param: PRESS_SHORT
      hold_action: none
Hope it works for you. I added a confirmation message, you may don’t want that
Hello Daniel,
thanks that works!
Thanks for your help.
Greetings Tobias
