I am using the old Homematic wired. I did a test with one wireless device and it was add to hass.
Here you will find my log:
2022-01-09 10:55:13 WARNING (SyncWorker_5) [pyhomematic._hm] Failed to initialize proxy for homeassistant-wired
2022-01-09 11:13:47 WARNING (MainThread) [zigpy_deconz.api] No response to 'Command.device_state' command with seq id '0x02'
2022-01-09 11:13:47 ERROR (MainThread) [zigpy_zigate.common] Unable to set PiZiGate GPIO, please check configuration
2022-01-09 11:13:47 ERROR (MainThread) [zigpy_zigate.common] No module named 'RPi'
2022-01-09 11:13:48 WARNING (MainThread) [zigpy_zigate.api] No response to command 0x0002
2022-01-09 11:13:48 WARNING (MainThread) [zigpy_zigate.api] Retry command 0x0002
2022-01-09 11:13:51 WARNING (MainThread) [zigpy_xbee.api] at: No response to AP command
2022-01-09 11:26:11 ERROR (MainThread) [homeassistant.components.synology_dsm.config_flow] {'api': 'SYNO.Core.System.Utilization', 'code': 105, 'reason': 'Insufficient user privilege', 'details': None}
2022-01-09 11:26:16 ERROR (MainThread) [homeassistant.components.synology_dsm.config_flow] {'api': None, 'code': -1, 'reason': 'Unknown', 'details': 'SSLError = [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1129)'}
2022-01-09 11:26:18 ERROR (MainThread) [homeassistant.components.synology_dsm.config_flow] {'api': None, 'code': -1, 'reason': 'Unknown', 'details': 'SSLError = [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1129)'}
2022-01-09 11:26:19 ERROR (MainThread) [homeassistant.components.synology_dsm.config_flow] {'api': None, 'code': -1, 'reason': 'Unknown', 'details': 'SSLError = [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1129)'}
2022-01-09 11:26:26 ERROR (MainThread) [homeassistant.components.synology_dsm.config_flow] {'api': None, 'code': -1, 'reason': 'Unknown', 'details': 'SSLError = [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1129)'}
2022-01-09 11:26:27 ERROR (MainThread) [homeassistant.components.synology_dsm.config_flow] {'api': None, 'code': -1, 'reason': 'Unknown', 'details': 'SSLError = [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1129)'}
2022-01-09 11:26:28 ERROR (MainThread) [homeassistant.components.synology_dsm.config_flow] {'api': None, 'code': -1, 'reason': 'Unknown', 'details': 'SSLError = [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1129)'}
2022-01-09 11:26:29 ERROR (MainThread) [homeassistant.components.synology_dsm.config_flow] {'api': None, 'code': -1, 'reason': 'Unknown', 'details': 'SSLError = [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1129)'}
2022-01-09 11:26:41 ERROR (MainThread) [homeassistant.components.synology_dsm.config_flow] {'api': None, 'code': -1, 'reason': 'Unknown', 'details': 'RequestException = Bad Request'}
2022-01-09 11:26:42 ERROR (MainThread) [homeassistant.components.synology_dsm.config_flow] {'api': None, 'code': -1, 'reason': 'Unknown', 'details': 'RequestException = Bad Request'}
2022-01-09 11:26:43 ERROR (MainThread) [homeassistant.components.synology_dsm.config_flow] {'api': None, 'code': -1, 'reason': 'Unknown', 'details': 'RequestException = Bad Request'}
2022-01-09 13:08:48 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Refusing to update waldemar non-registered sensor: f1e257b4f55b90948f0876fcdb6942aa28f825441d52625a15f608f12ff89ef4_audio_output_in_use
2022-01-09 13:08:48 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Refusing to update waldemar non-registered sensor: f1e257b4f55b90948f0876fcdb6942aa28f825441d52625a15f608f12ff89ef4_active_audio_output
2022-01-09 13:08:58 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Refusing to update waldemar non-registered sensor: f1e257b4f55b90948f0876fcdb6942aa28f825441d52625a15f608f12ff89ef4_focus
2022-01-16 13:58:08 ERROR (MainThread) [homeassistant.helpers.entity] Update for media_player.macbookpro fails
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 487, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 691, in async_device_update
raise exc
File "/usr/src/homeassistant/homeassistant/components/squeezebox/media_player.py", line 314, in async_update
await self._player.async_update()
File "/usr/local/lib/python3.9/site-packages/pysqueezebox/player.py", line 357, in async_update
response = await self.async_query("status", "-", "1", f"tags:{tags}")
File "/usr/local/lib/python3.9/site-packages/pysqueezebox/player.py", line 341, in async_query
return await self._lms.async_query(*parameters, player=self._id)
File "/usr/local/lib/python3.9/site-packages/pysqueezebox/server.py", line 172, in async_query
data = await response.json()
File "/usr/local/lib/python3.9/site-packages/aiohttp/client_reqrep.py", line 1119, in json
return loads(stripped.decode(encoding))
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xed in position 286: invalid continuation byte
2022-01-17 21:52:11 WARNING (SyncWorker_4) [pyhomematic._hm] ServerThread.proxyDeInit: Not performing de-init for homeassistant-wired
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
2022-01-17 21:52:12 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /homeassistant/restart request Server disconnected
[finish] process exit code 0
s6-svscanctl: fatal: unable to control /var/run/s6/services: supervisor not listening
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
2022-01-17 21:52:36 WARNING (SyncWorker_0) [pyhomematic._hm] Failed to initialize proxy for homeassistant-wired
