HomematicIP HmIP-PSM-2 *solved*
I am in despair. I have now purchased a HMIP device. I have been using the HM (not IP) switch-measure sockets for years without any problems. I use a Raspberrymatic as CCU3. The HmIP-PSM-2 switch measurement socket works perfectly in the Homematic.
But, the HmIP-PSM-2 is not included in the Homeassistant. The following from the log:
2022-10-25 20:17:23.985 DEBUG (SyncWorker_3) [pyhomematic._hm] RPCFunctions.newDevices: interface_id = homeassistant-ip, dev_descriptions = [{'TYPE': 'HmIP-PSM-2', 'SUBTYPE': 'PSM', 'ADDRESS': '0034DF298E852A', 'RF_ADDRESS': 6360822, 'CHILDREN': ['0034DF298E852A:0', '0034DF298E852A:1', '0034DF298E852A:2', '0034DF298E852A:3', '0034DF298E852A:4', '0034DF298E852A:5', '0034DF298E852A:6', '0034DF298E852A:7', '0034DF298E852A:8'], 'PARENT': '', 'PARENT_TYPE': '', 'INDEX': 0, 'AES_ACTIVE': 1, 'PARAMSETS': ['MASTER', 'SERVICE'], 'FIRMWARE': '2.22.0', 'AVAILABLE_FIRMWARE': '2.22.8', 'UPDATABLE': True, 'FIRMWARE_UPDATE_STATE': 'DELIVER_FIRMWARE_IMAGE', 'VERSION': 21, 'FLAGS': 1, 'LINK_SOURCE_ROLES': '', 'LINK_TARGET_ROLES': '', 'DIRECTION': 0, 'GROUP': '', 'TEAM': '', 'TEAM_TAG': '', 'TEAM_CHANNELS': [], 'INTERFACE': '', 'ROAMING': 0, 'RX_MODE': 0}, {'TYPE': 'MAINTENANCE', 'SUBTYPE': '', 'ADDRESS': '0034DF298E852A:0', 'RF_ADDRESS': 0, 'CHILDREN': [], 'PARENT': '0034DF298E852A', 'PARENT_TYPE': 'HmIP-PSM-2', 'INDEX': 0, 'AES_ACTIVE': 1, 'PARAMSETS': ['MASTER', 'VALUES', 'SERVICE'], 'FIRMWARE': '', 'AVAILABLE_FIRMWARE': '', 'UPDATABLE': True, 'FIRMWARE_UPDATE_STATE': '', 'VERSION': 21, 'FLAGS': 1, 'LINK_SOURCE_ROLES': '', 'LINK_TARGET_ROLES': '', 'DIRECTION': 0, 'GROUP': '', 'TEAM': '', 'TEAM_TAG': '', 'TEAM_CHANNELS': [], 'INTERFACE': '', 'ROAMING': 0, 'RX_MODE': 0}, {'TYPE': 'KEY_TRANSCEIVER', 'SUBTYPE': '', 'ADDRESS': '0034DF298E852A:1', 'RF_ADDRESS': 0, 'CHILDREN': [], 'PARENT': '0034DF298E852A', 'PARENT_TYPE': 'HmIP-PSM-2', 'INDEX': 1, 'AES_ACTIVE': 1, 'PARAMSETS': ['MASTER', 'VALUES', 'LINK', 'SERVICE'], 'FIRMWARE': '', 'AVAILABLE_FIRMWARE': '', 'UPDATABLE': True, 'FIRMWARE_UPDATE_STATE': '', 'VERSION': 31, 'FLAGS': 1, 'LINK_SOURCE_ROLES': 'REMOTE_CONTROL', 'LINK_TARGET_ROLES': '', 'DIRECTION': 1, 'GROUP': '', 'TEAM': '', 'TEAM_TAG': '', 'TEAM_CHANNELS': [], 'INTERFACE': '', 'ROAMING': 0, 'RX_MODE': 0}, {'TYPE': 'SWITCH_TRANSMITTER', 'SUBTYPE': '', 'ADDRESS': '0034DF298E852A:2', 'RF_ADDRESS': 0, 'CHILDREN': [], 'PARENT': '0034DF298E852A', 'PARENT_TYPE': 'HmIP-PSM-2', 'INDEX': 2, 'AES_ACTIVE': 1, 'PARAMSETS': ['MASTER', 'VALUES', 'SERVICE'], 'FIRMWARE': '', 'AVAILABLE_FIRMWARE': '', 'UPDATABLE': True, 'FIRMWARE_UPDATE_STATE': '', 'VERSION': 21, 'FLAGS': 1, 'LINK_SOURCE_ROLES': '', 'LINK_TARGET_ROLES': '', 'DIRECTION': 0, 'GROUP': '', 'TEAM': '', 'TEAM_TAG': '', 'TEAM_CHANNELS': [], 'INTERFACE': '', 'ROAMING': 0, 'RX_MODE': 0}, {'TYPE': 'SWITCH_VIRTUAL_RECEIVER', 'SUBTYPE': '', 'ADDRESS': '0034DF298E852A:3', 'RF_ADDRESS': 0, 'CHILDREN': [], 'PARENT': '0034DF298E852A', 'PARENT_TYPE': 'HmIP-PSM-2', 'INDEX': 3, 'AES_ACTIVE': 1, 'PARAMSETS': ['MASTER', 'VALUES', 'LINK', 'SERVICE'], 'FIRMWARE': '', 'AVAILABLE_FIRMWARE': '', 'UPDATABLE': True, 'FIRMWARE_UPDATE_STATE': '', 'VERSION': 21, 'FLAGS': 1, 'LINK_SOURCE_ROLES': '', 'LINK_TARGET_ROLES': 'REMOTE_CONTROL LEVEL SWITCH CONDITIONAL_SWITCH', 'DIRECTION': 2, 'GROUP': '', 'TEAM': '', 'TEAM_TAG': '', 'TEAM_CHANNELS': [], 'INTERFACE': '', 'ROAMING': 0, 'RX_MODE': 0}, {'TYPE': 'SWITCH_VIRTUAL_RECEIVER', 'SUBTYPE': '', 'ADDRESS': '0034DF298E852A:4', 'RF_ADDRESS': 0, 'CHILDREN': [], 'PARENT': '0034DF298E852A', 'PARENT_TYPE': 'HmIP-PSM-2', 'INDEX': 4, 'AES_ACTIVE': 1, 'PARAMSETS': ['MASTER', 'VALUES', 'LINK', 'SERVICE'], 'FIRMWARE': '', 'AVAILABLE_FIRMWARE': '', 'UPDATABLE': True, 'FIRMWARE_UPDATE_STATE': '', 'VERSION': 21, 'FLAGS': 1, 'LINK_SOURCE_ROLES': '', 'LINK_TARGET_ROLES': 'REMOTE_CONTROL LEVEL SWITCH CONDITIONAL_SWITCH', 'DIRECTION': 2, 'GROUP': '', 'TEAM': '', 'TEAM_TAG': '', 'TEAM_CHANNELS': [], 'INTERFACE': '', 'ROAMING': 0, 'RX_MODE': 0}, {'TYPE': 'SWITCH_VIRTUAL_RECEIVER', 'SUBTYPE': '', 'ADDRESS': '0034DF298E852A:5', 'RF_ADDRESS': 0, 'CHILDREN': [], 'PARENT': '0034DF298E852A', 'PARENT_TYPE': 'HmIP-PSM-2', 'INDEX': 5, 'AES_ACTIVE': 1, 'PARAMSETS': ['MASTER', 'VALUES', 'LINK', 'SERVICE'], 'FIRMWARE': '', 'AVAILABLE_FIRMWARE': '', 'UPDATABLE': True, 'FIRMWARE_UPDATE_STATE': '', 'VERSION': 21, 'FLAGS': 1, 'LINK_SOURCE_ROLES': '', 'LINK_TARGET_ROLES': 'REMOTE_CONTROL LEVEL SWITCH CONDITIONAL_SWITCH', 'DIRECTION': 2, 'GROUP': '', 'TEAM': '', 'TEAM_TAG': '', 'TEAM_CHANNELS': [], 'INTERFACE': '', 'ROAMING': 0, 'RX_MODE': 0}, {'TYPE': 'ENERGIE_METER_TRANSMITTER', 'SUBTYPE': '', 'ADDRESS': '0034DF298E852A:6', 'RF_ADDRESS': 0, 'CHILDREN': [], 'PARENT': '0034DF298E852A', 'PARENT_TYPE': 'HmIP-PSM-2', 'INDEX': 6, 'AES_ACTIVE': 1, 'PARAMSETS': ['MASTER', 'VALUES', 'SERVICE'], 'FIRMWARE': '', 'AVAILABLE_FIRMWARE': '', 'UPDATABLE': True, 'FIRMWARE_UPDATE_STATE': '', 'VERSION': 21, 'FLAGS': 1, 'LINK_SOURCE_ROLES': '', 'LINK_TARGET_ROLES': '', 'DIRECTION': 0, 'GROUP': '', 'TEAM': '', 'TEAM_TAG': '', 'TEAM_CHANNELS': [], 'INTERFACE': '', 'ROAMING': 0, 'RX_MODE': 0}, {'TYPE': 'COND_SWITCH_TRANSMITTER', 'SUBTYPE': '', 'ADDRESS': '0034DF298E852A:7', 'RF_ADDRESS': 0, 'CHILDREN': [], 'PARENT': '0034DF298E852A', 'PARENT_TYPE': 'HmIP-PSM-2', 'INDEX': 7, 'AES_ACTIVE': 1, 'PARAMSETS': ['MASTER', 'VALUES', 'LINK', 'SERVICE'], 'FIRMWARE': '', 'AVAILABLE_FIRMWARE': '', 'UPDATABLE': True, 'FIRMWARE_UPDATE_STATE': '', 'VERSION': 21, 'FLAGS': 1, 'LINK_SOURCE_ROLES': 'CONDITIONAL_SWITCH', 'LINK_TARGET_ROLES': '', 'DIRECTION': 1, 'GROUP': '', 'TEAM': '', 'TEAM_TAG': '', 'TEAM_CHANNELS': [], 'INTERFACE': '', 'ROAMING': 0, 'RX_MODE': 0}, {'TYPE': 'SWITCH_WEEK_PROFILE', 'SUBTYPE': '', 'ADDRESS': '0034DF298E852A:8', 'RF_ADDRESS': 0, 'CHILDREN': [], 'PARENT': '0034DF298E852A', 'PARENT_TYPE': 'HmIP-PSM-2', 'INDEX': 8, 'AES_ACTIVE': 1, 'PARAMSETS': ['MASTER', 'VALUES', 'SERVICE'], 'FIRMWARE': '', 'AVAILABLE_FIRMWARE': '', 'UPDATABLE': True, 'FIRMWARE_UPDATE_STATE': '', 'VERSION': 21, 'FLAGS': 1, 'LINK_SOURCE_ROLES': '', 'LINK_TARGET_ROLES': '', 'DIRECTION': 0, 'GROUP': '', 'TEAM': '', 'TEAM_TAG': '', 'TEAM_CHANNELS': [], 'INTERFACE': '', 'ROAMING': 0, 'RX_MODE': 0}, {'TYPE': 'RPI-RF-MOD', 'SUBTYPE': 'CCU', 'ADDRESS': '001F5A4993FB51', 'RF_ADDRESS': 12368894, 'CHILDREN': ['001F5A4993FB51:0'], 'PARENT': '', 'PARENT_TYPE': '', 'INDEX': 0, 'AES_ACTIVE': 1, 'PARAMSETS': ['MASTER', 'SERVICE'], 'FIRMWARE': '4.4.22', 'AVAILABLE_FIRMWARE': '0.0.0', 'UPDATABLE': True, 'FIRMWARE_UPDATE_STATE': '', 'VERSION': 2, 'FLAGS': 9, 'LINK_SOURCE_ROLES': '', 'LINK_TARGET_ROLES': '', 'DIRECTION': 0, 'GROUP': '', 'TEAM': '', 'TEAM_TAG': '', 'TEAM_CHANNELS': [], 'INTERFACE': '', 'ROAMING': 0, 'RX_MODE': 0}, {'TYPE': 'MAINTENANCE', 'SUBTYPE': '', 'ADDRESS': '001F5A4993FB51:0', 'RF_ADDRESS': 0, 'CHILDREN': [], 'PARENT': '001F5A4993FB51', 'PARENT_TYPE': 'RPI-RF-MOD', 'INDEX': 0, 'AES_ACTIVE': 1, 'PARAMSETS': ['MASTER', 'VALUES', 'SERVICE'], 'FIRMWARE': '', 'AVAILABLE_FIRMWARE': '', 'UPDATABLE': True, 'FIRMWARE_UPDATE_STATE': '', 'VERSION': 2, 'FLAGS': 1, 'LINK_SOURCE_ROLES': '', 'LINK_TARGET_ROLES': '', 'DIRECTION': 0, 'GROUP': '', 'TEAM': '', 'TEAM_TAG': '', 'TEAM_CHANNELS': [], 'INTERFACE': '', 'ROAMING': 0, 'RX_MODE': 0}, {'TYPE': 'HmIP-RCV-50', 'SUBTYPE': 'RCV50', 'ADDRESS': 'HmIP-RCV-1', 'RF_ADDRESS': 12368894, 'CHILDREN': ['HmIP-RCV-1:0', 'HmIP-RCV-1:1', 'HmIP-RCV-1:2', 'HmIP-RCV-1:3', 'HmIP-RCV-1:4', 'HmIP-RCV-1:5', 'HmIP-RCV-1:6', 'HmIP-RCV-1:7', 'HmIP-RCV-1:8', 'HmIP-RCV-1:9', 'HmIP-RCV-1:10', 'HmIP-RCV-1:11', 'HmIP-RCV-1:12', 'HmIP-RCV-1:13', 'HmIP-RCV-1:14', 'HmIP-RCV-1:15', 'HmIP-RCV-1:16', 'HmIP-RCV-1:17', 'HmIP-RCV-1:18', 'HmIP-RCV-1:19', 'HmIP-RCV-1:20', 'HmIP-RCV-1:21', 'HmIP-RCV-1:22', 'HmIP-RCV-1:23', 'HmIP-RCV-1:24', 'HmIP-RCV-1:25', 'HmIP-RCV-1:26', 'HmIP-RCV-1:27', 'HmIP-RCV-1:28', 'HmIP-RCV-1:29', 'HmIP-RCV-1:30', 'HmIP-RCV-1:31', 'HmIP-RCV-1:32', 'HmIP-RCV-1:33', 'HmIP-RCV-1:34', 'HmIP-RCV-1:35', 'HmIP-RCV-1:36', 'HmIP-RCV-1:37', 'HmIP-RCV-1:38', 'HmIP-RCV-1:39', 'HmIP-RCV-1:40', 'HmIP-RCV-1:41', 'HmIP-RCV-1:42', 'HmIP-RCV-1:43', 'HmIP-RCV-1:44', 'HmIP-RCV-1:45', 'HmIP-RCV-1:46', 'HmIP-RCV-1:47', 'HmIP-RCV-1:48', 'HmIP-RCV-1:49', 'HmIP-RCV-1:50', ''], 'PARENT': '', 'PARENT_TYPE': '', 'INDEX': 0, 'AES_ACTIVE': 1, 'PARAMSETS': ['MASTER'], 'FIRMWARE': '1.0.0', 'AVAILABLE_FIRMWARE': '0.0.0', 'UPDATABLE': False, 'FIRMWARE_UPDATE_STATE': 'UP_TO_DATE', 'VERSION': 1, 'FLAGS': 9, 'LINK_SOURCE_ROLES': '', 'LINK_TARGET_ROLES': '', 'DIRECTION': 0, 'GROUP': '', 'TEAM': '', 'TEAM_TAG': '', 'TEAM_CHANNELS': [], 'INTERFACE': '', 'ROAMING': 0, 'RX_MODE': 1}, {'TYPE': 'MAINTENANCE', 'SUBTYPE': '', 'ADDRESS': 'HmIP-RCV-1:0', 'RF_ADDRESS': 0, 'CHILDREN': [], 'PARENT': 'HmIP-RCV-1', 'PARENT_TYPE': 'HmIP-RCV-50', 'INDEX': 0, 'AES_ACTIVE': 1, 'PARAMSETS': ['MASTER', 'VALUES'], 'FIRMWARE': '1.0.0', 'AVAILABLE_FIRMWARE': '', 'UPDATABLE': False, 'FIRMWARE_UPDATE_STATE': 'UP_TO_DATE', 'VERSION': 1, 'FLAGS': 9, 'LINK_SOURCE_ROLES': '', 'LINK_TARGET_ROLES': '', 'DIRECTION': 0, 'GROUP': '', 'TEAM': '', 'TEAM_TAG': '', 'TEAM_CHANNELS': [], 'INTERFACE': '', 'ROAMING': 0, 'RX_MODE': 0}, {'TYPE': 'KEY_TRANSCEIVER', 'SUBTYPE': '', 'ADDRESS': 'HmIP-RCV-1:1', 'RF_ADDRESS': 0, 'CHILDREN': [], 'PARENT': 'HmIP-RCV-1', 'PARENT_TYPE': 'HmIP-RCV-50', 'INDEX': 1, 'AES_ACTIVE': 1, 'PARAMSETS': ['MASTER', 'VALUES', 'LINK'], 'FIRMWARE': '1.0.0', 'AVAILABLE_FIRMWARE': '', 'UPDATABLE': False, 'FIRMWARE_UPDATE_STATE': 'UP_TO_DATE', 'VERSION': 1, 'FLAGS': 9, 'LINK_SOURCE_ROLES': 'REMOTE_CONTROL', 'LINK_TARGET_ROLES': '', 'DIRECTION': 1, 'GROUP': '', 'TEAM': '', 'TEAM_TAG': '', 'TEAM_CHANNELS': [], 'INTERFACE': '', 'ROAMING': 0, 'RX_MODE': 0}, {'TYPE': 'KEY_TRANSCEIVER', 'SUBTYPE': '', 'ADDRESS': 'HmIP-RCV-1:2', 'RF_ADDRESS': 0, 'CHILDREN': [], 'PARENT': 'HmIP-RCV-1', 'PARENT_TYPE': 'HmIP-RCV-50', 'INDEX': 2, 'AES_ACTIVE': 1, 'PARAMSETS': ['MASTER', 'VALUES', 'LINK'], 'FIRMWARE': '1.0.0', 'AVAILABLE_FIRMWARE': '', 'UPDATABLE': False, 'FIRMWARE_UPDATE_STATE': 'UP_TO_DATE', 'VERSION': 1, 'FLAGS': 9, 'LINK_SOURCE_ROLES': 'REMOTE_CONTROL', 'LINK_TARGET_ROLES': '', 'DIRECTION': 1, 'GROUP': '', 'TEAM': '', 'TEAM_TAG': '', 'TEAM_CHANNELS': [], 'INTERFACE': '', 'ROAMING': 0, 'RX_MODE': 0}, {'TYPE': 'KEY_TRANSCEIVER', 'SUBTYPE': '', 'ADDRESS': 'HmIP-RCV-1:3', 'RF_ADDRESS': 02022-10-25 20:17:23.986 DEBUG (SyncWorker_3) [pyhomematic.devicetypes.generic] HMGeneric.__init__: device_description: 0034DF298E852A : {'TYPE': 'HmIP-PSM-2', 'SUBTYPE': 'PSM', 'ADDRESS': '0034DF298E852A', 'RF_ADDRESS': 6360822, 'CHILDREN': ['0034DF298E852A:0', '0034DF298E852A:1', '0034DF298E852A:2', '0034DF298E852A:3', '0034DF298E852A:4', '0034DF298E852A:5', '0034DF298E852A:6', '0034DF298E852A:7', '0034DF298E852A:8'], 'PARENT': '', 'PARENT_TYPE': '', 'INDEX': 0, 'AES_ACTIVE': 1, 'PARAMSETS': ['MASTER', 'SERVICE'], 'FIRMWARE': '2.22.0', 'AVAILABLE_FIRMWARE': '2.22.8', 'UPDATABLE': True, 'FIRMWARE_UPDATE_STATE': 'DELIVER_FIRMWARE_IMAGE', 'VERSION': 21, 'FLAGS': 1, 'LINK_SOURCE_ROLES': '', 'LINK_TARGET_ROLES': '', 'DIRECTION': 0, 'GROUP': '', 'TEAM': '', 'TEAM_TAG': '', 'TEAM_CHANNELS': [], 'INTERFACE': '', 'ROAMING': 0, 'RX_MODE': 0}
2022-10-25 20:17:23.993 DEBUG (SyncWorker_3) [pyhomematic._hm] RPCFunctions.createDeviceObjects: created 0034DF298E852A  as UNSUPPORTED device for HmIP-PSM-2
2022-10-25 20:17:23.994 DEBUG (SyncWorker_3) [pyhomematic.devicetypes.generic] HMGeneric.__init__: device_description: 0034DF298E852A:0 : {'TYPE': 'MAINTENANCE', 'SUBTYPE': '', 'ADDRESS': '0034DF298E852A:0', 'RF_ADDRESS': 0, 'CHILDREN': [], 'PARENT': '0034DF298E852A', 'PARENT_TYPE': 'HmIP-PSM-2', 'INDEX': 0, 'AES_ACTIVE': 1, 'PARAMSETS': ['MASTER', 'VALUES', 'SERVICE'], 'FIRMWARE': '', 'AVAILABLE_FIRMWARE': '', 'UPDATABLE': True, 'FIRMWARE_UPDATE_STATE': '', 'VERSION': 21, 'FLAGS': 1, 'LINK_SOURCE_ROLES': '', 'LINK_TARGET_ROLES': '', 'DIRECTION': 0, 'GROUP': '', 'TEAM': '', 'TEAM_TAG': '', 'TEAM_CHANNELS': [], 'INTERFACE': '', 'ROAMING': 0, 'RX_MODE': 0}
2022-10-25 20:17:23.994 DEBUG (SyncWorker_3) [pyhomematic.devicetypes.generic] HMGeneric.__init__: device_description: 0034DF298E852A:1 : {'TYPE': 'KEY_TRANSCEIVER', 'SUBTYPE': '', 'ADDRESS': '0034DF298E852A:1', 'RF_ADDRESS': 0, 'CHILDREN': [], 'PARENT': '0034DF298E852A', 'PARENT_TYPE': 'HmIP-PSM-2', 'INDEX': 1, 'AES_ACTIVE': 1, 'PARAMSETS': ['MASTER', 'VALUES', 'LINK', 'SERVICE'], 'FIRMWARE': '', 'AVAILABLE_FIRMWARE': '', 'UPDATABLE': True, 'FIRMWARE_UPDATE_STATE': '', 'VERSION': 31, 'FLAGS': 1, 'LINK_SOURCE_ROLES': 'REMOTE_CONTROL', 'LINK_TARGET_ROLES': '', 'DIRECTION': 1, 'GROUP': '', 'TEAM': '', 'TEAM_TAG': '', 'TEAM_CHANNELS': [], 'INTERFACE': '', 'ROAMING': 0, 'RX_MODE': 0}
2022-10-25 20:17:23.994 DEBUG (SyncWorker_3) [pyhomematic.devicetypes.generic] HMGeneric.__init__: device_description: 0034DF298E852A:2 : {'TYPE': 'SWITCH_TRANSMITTER', 'SUBTYPE': '', 'ADDRESS': '0034DF298E852A:2', 'RF_ADDRESS': 0, 'CHILDREN': [], 'PARENT': '0034DF298E852A', 'PARENT_TYPE': 'HmIP-PSM-2', 'INDEX': 2, 'AES_ACTIVE': 1, 'PARAMSETS': ['MASTER', 'VALUES', 'SERVICE'], 'FIRMWARE': '', 'AVAILABLE_FIRMWARE': '', 'UPDATABLE': True, 'FIRMWARE_UPDATE_STATE': '', 'VERSION': 21, 'FLAGS': 1, 'LINK_SOURCE_ROLES': '', 'LINK_TARGET_ROLES': '', 'DIRECTION': 0, 'GROUP': '', 'TEAM': '', 'TEAM_TAG': '', 'TEAM_CHANNELS': [], 'INTERFACE': '', 'ROAMING': 0, 'RX_MODE': 0}
2022-10-25 20:17:23.995 DEBUG (SyncWorker_3) [pyhomematic.devicetypes.generic] HMGeneric.__init__: device_description: 0034DF298E852A:3 : {'TYPE': 'SWITCH_VIRTUAL_RECEIVER', 'SUBTYPE': '', 'ADDRESS': '0034DF298E852A:3', 'RF_ADDRESS': 0, 'CHILDREN': [], 'PARENT': '0034DF298E852A', 'PARENT_TYPE': 'HmIP-PSM-2', 'INDEX': 3, 'AES_ACTIVE': 1, 'PARAMSETS': ['MASTER', 'VALUES', 'LINK', 'SERVICE'], 'FIRMWARE': '', 'AVAILABLE_FIRMWARE': '', 'UPDATABLE': True, 'FIRMWARE_UPDATE_STATE': '', 'VERSION': 21, 'FLAGS': 1, 'LINK_SOURCE_ROLES': '', 'LINK_TARGET_ROLES': 'REMOTE_CONTROL LEVEL SWITCH CONDITIONAL_SWITCH', 'DIRECTION': 2, 'GROUP': '', 'TEAM': '', 'TEAM_TAG': '', 'TEAM_CHANNELS': [], 'INTERFACE': '', 'ROAMING': 0, 'RX_MODE': 0}
2022-10-25 20:17:23.995 DEBUG (SyncWorker_3) [pyhomematic.devicetypes.generic] HMGeneric.__init__: device_description: 0034DF298E852A:4 : {'TYPE': 'SWITCH_VIRTUAL_RECEIVER', 'SUBTYPE': '', 'ADDRESS': '0034DF298E852A:4', 'RF_ADDRESS': 0, 'CHILDREN': [], 'PARENT': '0034DF298E852A', 'PARENT_TYPE': 'HmIP-PSM-2', 'INDEX': 4, 'AES_ACTIVE': 1, 'PARAMSETS': ['MASTER', 'VALUES', 'LINK', 'SERVICE'], 'FIRMWARE': '', 'AVAILABLE_FIRMWARE': '', 'UPDATABLE': True, 'FIRMWARE_UPDATE_STATE': '', 'VERSION': 21, 'FLAGS': 1, 'LINK_SOURCE_ROLES': '', 'LINK_TARGET_ROLES': 'REMOTE_CONTROL LEVEL SWITCH CONDITIONAL_SWITCH', 'DIRECTION': 2, 'GROUP': '', 'TEAM': '', 'TEAM_TAG': '', 'TEAM_CHANNELS': [], 'INTERFACE': '', 'ROAMING': 0, 'RX_MODE': 0}
2022-10-25 20:17:23.995 DEBUG (SyncWorker_3) [pyhomematic.devicetypes.generic] HMGeneric.__init__: device_description: 0034DF298E852A:5 : {'TYPE': 'SWITCH_VIRTUAL_RECEIVER', 'SUBTYPE': '', 'ADDRESS': '0034DF298E852A:5', 'RF_ADDRESS': 0, 'CHILDREN': [], 'PARENT': '0034DF298E852A', 'PARENT_TYPE': 'HmIP-PSM-2', 'INDEX': 5, 'AES_ACTIVE': 1, 'PARAMSETS': ['MASTER', 'VALUES', 'LINK', 'SERVICE'], 'FIRMWARE': '', 'AVAILABLE_FIRMWARE': '', 'UPDATABLE': True, 'FIRMWARE_UPDATE_STATE': '', 'VERSION': 21, 'FLAGS': 1, 'LINK_SOURCE_ROLES': '', 'LINK_TARGET_ROLES': 'REMOTE_CONTROL LEVEL SWITCH CONDITIONAL_SWITCH', 'DIRECTION': 2, 'GROUP': '', 'TEAM': '', 'TEAM_TAG': '', 'TEAM_CHANNELS': [], 'INTERFACE': '', 'ROAMING': 0, 'RX_MODE': 0}
2022-10-25 20:17:23.995 DEBUG (SyncWorker_3) [pyhomematic.devicetypes.generic] HMGeneric.__init__: device_description: 0034DF298E852A:6 : {'TYPE': 'ENERGIE_METER_TRANSMITTER', 'SUBTYPE': '', 'ADDRESS': '0034DF298E852A:6', 'RF_ADDRESS': 0, 'CHILDREN': [], 'PARENT': '0034DF298E852A', 'PARENT_TYPE': 'HmIP-PSM-2', 'INDEX': 6, 'AES_ACTIVE': 1, 'PARAMSETS': ['MASTER', 'VALUES', 'SERVICE'], 'FIRMWARE': '', 'AVAILABLE_FIRMWARE': '', 'UPDATABLE': True, 'FIRMWARE_UPDATE_STATE': '', 'VERSION': 21, 'FLAGS': 1, 'LINK_SOURCE_ROLES': '', 'LINK_TARGET_ROLES': '', 'DIRECTION': 0, 'GROUP': '', 'TEAM': '', 'TEAM_TAG': '', 'TEAM_CHANNELS': [], 'INTERFACE': '', 'ROAMING': 0, 'RX_MODE': 0}
2022-10-25 20:17:23.995 DEBUG (SyncWorker_3) [pyhomematic.devicetypes.generic] HMGeneric.__init__: device_description: 0034DF298E852A:7 : {'TYPE': 'COND_SWITCH_TRANSMITTER', 'SUBTYPE': '', 'ADDRESS': '0034DF298E852A:7', 'RF_ADDRESS': 0, 'CHILDREN': [], 'PARENT': '0034DF298E852A', 'PARENT_TYPE': 'HmIP-PSM-2', 'INDEX': 7, 'AES_ACTIVE': 1, 'PARAMSETS': ['MASTER', 'VALUES', 'LINK', 'SERVICE'], 'FIRMWARE': '', 'AVAILABLE_FIRMWARE': '', 'UPDATABLE': True, 'FIRMWARE_UPDATE_STATE': '', 'VERSION': 21, 'FLAGS': 1, 'LINK_SOURCE_ROLES': 'CONDITIONAL_SWITCH', 'LINK_TARGET_ROLES': '', 'DIRECTION': 1, 'GROUP': '', 'TEAM': '', 'TEAM_TAG': '', 'TEAM_CHANNELS': [], 'INTERFACE': '', 'ROAMING': 0, 'RX_MODE': 0}
2022-10-25 20:17:23.995 DEBUG (SyncWorker_3) [pyhomematic.devicetypes.generic] HMGeneric.__init__: device_description: 0034DF298E852A:8 : {'TYPE': 'SWITCH_WEEK_PROFILE', 'SUBTYPE': '', 'ADDRESS': '0034DF298E852A:8', 'RF_ADDRESS': 0, 'CHILDREN': [], 'PARENT': '0034DF298E852A', 'PARENT_TYPE': 'HmIP-PSM-2', 'INDEX': 8, 'AES_ACTIVE': 1, 'PARAMSETS': ['MASTER', 'VALUES', 'SERVICE'], 'FIRMWARE': '', 'AVAILABLE_FIRMWARE': '', 'UPDATABLE': True, 'FIRMWARE_UPDATE_STATE': '', 'VERSION': 21, 'FLAGS': 1, 'LINK_SOURCE_ROLES': '', 'LINK_TARGET_ROLES': '', 'DIRECTION': 0, 'GROUP': '', 'TEAM': '', 'TEAM_TAG': '', 'TEAM_CHANNELS': [], 'INTERFACE': '', 'ROAMING': 0, 'RX_MODE': 0}
UNSUPPORTED device? Why?
Many many thanks, i hope someone can help me.
Grüße
Sven
I have found a solution.
danielperna84/custom_homematic: Custom Home Assistant Component for HomeMatic (github.com)
Many thanks to Daniel.
I’m facing the exact same issue, as mentioned in the documentation of the Homematic Integration, the solution would be add it to pyhomematic repository.
HMIP-PSM seems to be supported but not the newer version HMIP-PSM-2.
It needs to be added. Can you confirm this @danielperna84 ? Or is it already added in a different branch or PR?
Thanks,
As the post above you suggest, switch to the new integration. The old one (based on pyhomematic) is not being maintained anymore.
Thanks, I was about to ask when will the current integration be replaced, and how…
For others reading this, more info to be found here: Planung für Integration im HA Core · Discussion #381 · danielperna84/hahomematic · GitHub
Thanks @danielperna84 for your work :+1:
