There is a new doorlooksensor from HomematicIP. Íve got the following error Message:
There is no class for group ‘OPEN_DOOR_NOTIFICATION_RULE_GROUP’ yet
07:03:10 – (WARNUNG) /usr/local/lib/python3.9/site-packages/homematicip/home.py - Die Nachricht ist zum ersten Mal um 07:03:10 aufgetreten und erscheint 3 mal
There is no class for device ‘DOOR_LOCK_SENSOR’ yet
Same here. Also waiting for an integration of HmIP-DLS.
In the meantime, I have created a program that tracks the status of the DLS in a variable in CCU3. The state of this variable can be pulled with a template in Home Assistant.
I’m only working on the CCU-based integration. The logs from the opening post are from the cloud integration. Hence I can’t help with that.
Apart from that the device also is not supported by the CCU-based integration. For that to work we need the device details, which can be extracted using this script. You can then either post the result as a gist, or create a pull request here if you know your way around GitHub.
Hello everyone, I bought this sensor aswell and would really appreciate a CCU integration of her.
Are there missing information? I could gather some if necessary.
Best djm193
