I’m using the OCCU add-on with my HM-MOD-RPI-PCB and some Homematic devices. Works fine.
But now I want to add/use some homematicIP devices. Since HM-MOD-RPI-PCB is able to handle both homematic and homematicIP, I wanted to setup OCCU to support hmip. Unfortunatelly it won’t work when I enable hmip and change the device to /dev/ttyAMA0 (where HM-MOD-RPI-PCB is).
Hi, i’m very interested in this as well. Could someone fill me in if this is a technical Limitation or am i missing something? (Hardware runs fine, tested with Raspberrymatic)
i can now confirm the HmIP-RFUSB Stick is working with Homeassistant on one single RPi3 with HassOS. minor typo in the docs though, The Port for HmIP should be 2010
