I’ve installed a HomeSeer HS-FS100+ Flex Sensor with the optional light sensor. When I added the device to HomeAssistant it correctly identified that the LED it was mounted on was turned off, and then it detected the LED turn on a single time, and has never switched back even though the light has been off for days.
Has anyone else experienced this?
Go into the HA device configuration page for that device and enable the disabled sensors. One of these should work.
That was it. I’m surprised that one of the only useful sensors for this device is disabled by default.
