I’ve got an HSM200 z-wave multi-sensor, which I understand is a re-badged EXMultiPli or something like that. When I try to turn the LED on to a particular color (a nice deep yellow, e.g.) from the main Overview page or the device info page using the color picker, it only turns on white. Same thing if I create a scene, again using the color picker dialog. When I activate the scene for yellow indicator LED, it come on white.
So I searched the forum a little, and everyone who had automations that used the HSM200 (or EZM) would set the color as RGB. So I edited the scene created with the GUI scene editor and the color picker and then found this in the YAML:
entities:
light.ezm:
supported_color_modes:
- hs
color_mode: hs
brightness: 255
hs_color:
- 45.738
- 47.843
rgb_color:
- 255
- 226
- 133
xy_color:
- 0.429
- 0.421
friendly_name: "EZM "
supported_features: 32
state: "on"
...snip...
Well, that’s obviously using HS to set the color, not RGB. So I directly edited the YAML to use rgb instead:
entities:
light.ezm:
- rgb
color_mode: rgb
brightness: 255
hs_color:
- 45.738
- 47.843
rgb_color:
- 255
- 226
- 133
xy_color:
- 0.429
- 0.421
state: "on"
...snip...
Doesn’t work. LED still comes on white, not yellow. ![]()
Read the forum some more and found some comments about the rbg values being on or off only. 0 is off, anything else is on, no shades. So maybe setting RGB to 255:226:133 was just turning on all the LEDs full power and therefore I get white instead of yellow. I edited the YAML again, this time setting RGB to 1:1:0:
entities:
light.ezm:
- rgb
color_mode: rgb
brightness: 255
hs_color:
- 45.738
- 47.843
rgb_color:
- 1
- 1
- 0
xy_color:
- 0.429
- 0.421
state: "on"
...snip again...
I applied the scene again, and it’s yellow. Not the nice deep yellow I picked, but yellow.
I think this should count as a bug because:
- The color picker uses HS mode for the HSM200 which doesn’t seem to work
- I would be almost impossible to pick a color on the color picker where one or two of the RGB values would be zero. And if they’re all 1 or greater they’re just ON, so the only color one could possibly choose with the GUI picker is effectively white.
So, should I file this as a bug report? Any suggestions on extra info I should add if I do?
