@blich Thanks for sharing your blueprint! This worked perfectly for my setup, and it simplifies my existing automations quite a bit.
I only wish Home-Assistant provided a way to do select multiple zwave entities here, without having to hardcode a specific number of them. I have 5 of these switches in my kitchen area, and I’d love to create a single automation via blueprint so that they can all behave the same way with respect to the multi-tap controls.
I can easily adapt your blueprint to accomodate this, but it’d be specific to my setup and not easily sharable
I’ve modified the original code provided for OpenZWave use. If you are using the OpenZWave Beta extension you can use the following logic to replace the code based on the native zwave implementation.
I tested this only the fan controller switch. I do not know if other HomeSeer switches will have issues.
Simple changes were to convert from entity select to node id entry, to match conditions to the node_id coming from the event and to filter based on the scene_value_id, which replaces scene_data when using OZW. I also converted the match values to be consistent with what is coming in the event. No longer do the four digit scene IDs work.
As far as I am aware there is no easy way to convert from an entity selector to a node_id, thus I have changed the selector to a number field and this will require you to change your automations to identify switches generating events by their node_id. I could not determine an easy way to match based on entity selection (node_id could not be found) and the event from OZW does not contain the entity. If someone else has a fix for this, please share.
blueprint:
name: HomeSeer multi-tap actions
domain: automation
input:
ozwave_entity:
name: OZW Node Identity
description: Provide the node id of the entity that will control this automation.
two_tap_up:
name: 2x tap up
description: Action to run on double tap up
default: []
selector:
action: {}
two_tap_down:
name: 2x tap down
description: Action to run on double tap down
default: []
selector:
action: {}
three_tap_up:
name: 3x tap up
description: Action to run on triple tap up
default: []
selector:
action: {}
three_tap_down:
name: 3x tap down
description: Action to run on triple tap down
default: []
selector:
action: {}
four_tap_up:
name: 4x tap up
description: Action to run on four taps up
default: []
selector:
action: {}
four_tap_down:
name: 4x tap down
description: Action to run on four taps down
default: []
selector:
action: {}
five_tap_up:
name: 5x tap up
description: Action to run on five taps up
default: []
selector:
action: {}
five_tap_down:
name: 5x tap down
description: Action to run on five taps down
default: []
selector:
action: {}
source_url: https://community.home-assistant.io/t/homeseer-multi-tap-controls/257141
mode: restart
max_exceeded: silent
variables:
ozwave_node: !input ozwave_entity
- platform: event
event_type: ozw.scene_activated
condition: "{{ trigger.event.data.node_id == (ozwave_node | int) }}"
- variables:
scene_id: '{{ trigger.event.data.scene_id }}'
scene_value_id: '{{ trigger.event.data.scene_value_id }}'
- choose:
- conditions:
- condition: template
value_template: '{{ scene_id == 1 }}'
value_template: '{{ scene_value_id == 4 }}'
sequence: !input 'two_tap_up'
- conditions:
value_template: '{{ scene_id == 2 }}'
sequence: !input 'two_tap_down'
- conditions:
value_template: '{{ scene_value_id == 5 }}'
sequence: !input 'three_tap_up'
- conditions:
sequence: !input 'three_tap_down'
- conditions:
value_template: '{{ scene_value_id == 6 }}'
sequence: !input 'four_tap_up'
- conditions:
sequence: !input 'four_tap_down'
- conditions:
value_template: '{{ scene_value_id == 7 }}'
sequence: !input 'five_tap_up'
- conditions:
sequence: !input 'five_tap_down'
If you use this blueprint to replace the previous one, you will need to rebuild your automations. You should remove them if you change the contents of your original blueprint file, as this new format will not be compatible with your existing automations if based on the old logic.
If someone has an update for Z-Wave JS please share. I have not updated to use Z-Wave JS.
