I have a Homeseer HomeTroller Pi and was wondering if it could be used to load Home assistant on it and would HA be able to use the Z-Wave controller that is built into it.
It appears to just be a Raspberry Pi 3 running a custom OS, so you should be able to remove the SD card and load HA on a new SD card.
As far as the zwave controller is concerned, you’d have to tell us what it is. First thing to try, try lspci and lsusb commands.
