The HomeWizard P1 has a new firmware.
Since version v4.14, There are some extra fields added to the API.
So now it’s possible to read out the ‘Kwartierpiek’ and ‘Maandpiek’, that is used for calculating the ‘CapaciteitsTarief’ for Belgium customers.
It’s not in the HA integration yet, but it can be read (together with some other parameters) directly from the API, with a REST sensor.
This is the code (change the IP to your own
rest:
- resource: http://192.168.1.171/api/v1/data
method: GET
- name: "fluvius_dm_active_voltage_l1_v"
value_template: "{{ value_json.active_voltage_l1_v | float(0) | round(1) }}"
device_class: voltage
state_class: measurement
unit_of_measurement: V
- name: "fluvius_dm_active_current_l1_a"
value_template: "{{ value_json.active_current_l1_a | float(0) | round(2) }}"
device_class: current
unit_of_measurement: A
- name: "fluvius_dm_montly_power_peak_w"
value_template: "{{ value_json.montly_power_peak_w | float(0) | round(0) }}"
device_class: power
unit_of_measurement: W
- name: "fluvius_dm_active_power_average_w"
value_template: "{{ value_json.active_power_average_w | float(0) | round(1) }}"
device_class: power
These are all the parameters that can be read :
active_tariff
total_power_import_kwh
total_power_import_t1_kwh
total_power_import_t2_kwh
total_power_export_t1_kwh
total_power_export_t2_kwh
active_power_w
active_power_l1_w
active_voltage_l1_v
active_current_l1_a
montly_power_peak_w
montly_power_peak_timestamp
total_gas_m3
gas_timestamp
