I think you are wrong about the multiply by 4 part.
The values we get with the HomeWizard Energy are the correct values and don’t need to be multiplied. The values from Fluvius (MijnFluvius) are wrong and need to be multiplied.
I’ve also noted that the sensor you suggested, doesn’t seem to work.
Thanks for the update, my multiplication by 4 suggestion came indeed from the fact that this is necessary for the Fluvius site.
Creating the max (quarter-hourly t1 +t2) sensor I did not try yet, I’ll post the results when I try it.
Thx for the suggestion about statistics, do you have an idea on how I can display them in lovelace ?
I created this in configuration.yaml, but I have no idea on how to display the max and mean value of kwartierpiek
When I add stats to my energy entities card configuration, it says the result is unknown.
With this version is is possible to change the update interval. Prioritized this for @Fabian_V.
Reimplemented ‘manual’ config. You can now add your meter by entering an IP address instead of just discovery. This should solve your problem @bigfloor.
hi guys & girls,
I’m new here and trying to get this thing to work.
finally got the add on installed and now waiting for hours te the Homewizzard dongle to be “discovered’”.
did some reboots…
in the “custom_components” folder there is the wizard folder with the files…
did a restart of the wizard dongle itself…
and i kan see RAW data if I go to the : “http://...**/api/v1/data” page.
so I assume the dongle is working
i assume I did enough home assistant reboots…
@ [Unsigus] Thanks for the latest update ! Manual worked for me (just entered the IP address). Might be nice to actually see that it expects an IP address (no problem for me though).
In the meantime, I made a Node Red sequence to dump the data into my InfluxDB/Grafana setup and got it kind of working overthere as well.
I currently have an issue where my active power sensor does something wrong.
So it currently it’s -1238W but the graph shows 434W. I’ve already restarted HomeAssistant, removed the integration (and restarted and readded), also removed the integration from HACS, restarted HA, readded from HACS,…
No idea what causes this or why.
edit: In Grafana and InfluxDB it works fine weirdly enough.
Do you see anything in your log?
Do you see the same in history? It could be a an issue caused by Home Assistant (or the frontend) or something that is corrupted in the database.
And to be sure, please check http://<ip_address>/api/v1/data to see if the data is as expected. (I suspect so because Grafana works fine)
I think the best you can do is ask on Discord or another topic to see if this an issue with the card. If they think it is an issue with this integration we can continue with troubleshooting
I’m very interested in purchasing this, however can you clarify something?
From the images I found (at Bol.com) it appears there is no external power connection, is this device powered directly by the P1 port, battery or a connector that simply wasn’t shown in the pictures?
My meter cupboard doesn’t actually have a power outlet in it so would be tricky to implement if it did require external power.
