Hi, I’m using Homey as main controller in my home, which works perfectly fine, except that it lacks a good dashboard functionality. Therefore I bought a Raspberry Pi and installed HA on it, so I could make my own lovelace dashboard.
But now I’ve a weird problem; I’m missing 4 or 5 devices as entity in HA. MQTT on HA does detect 44 devices and 156 entities, so it looks like there’s nothing wrong on the homey part. I’ve installed MQTT Explorer on my laptop to check if everything is being broadcasted, which is the case (see screenshot).
Screenshot of MQTT Explorer / Part of configuration.yaml / Snippet of Lovelace (can only post 1 photo):
I’ve tried multiple variations of typing the entity-name, with/without spaces/capitals etc, but I think as long as it isn’t showing up in the entity list, non of this will work…
It’s a socket-switch of the brand ‘KlikAanKlikUit’, type ACD-300, which is also dimmable. But the problem also occurs with other devices.
And a second, more general, question: If I restart HA, so configuration changes take effect, I have to manually tell Homey to broadcast again, before any status/sensor will show up on the dashboard of HA. Is it possible to change this behaviour?
Your workaround sounds too complex for me, that’s the reason I’ve a Homey instead of HA as main controller Setting-up a proper dashboard is hard enough for my skills
Another way is to dumb Homey, and go the straight HA way, I did that and never seen back.
I also did what you are doing, and had the same issue with birth/will messages, now my Homey is parked a dark place, not in use and I have a Zigbee network that works.
Did you solved the problem and got the missing entities to show up in HA? I have a similair problem and as it seems to be my dimmer switches that is not showing up in HA, but in MQTT explorer.
Yes/no, I didn’t found a solution to get the missing entities to show up automaticly, but I did manage to add the desired entities manually by adding the following code to configuration.YAML. This is for a dimable wallsocket switch, a simple on/off switch doesn’t need the brightness_ topics.
