I’m using the Honeycomb menu in a floorplan. Recently it stopped working because the depreciated service call was removed.
So, I updated my yaml but its still not working. Based on docs I had to change the service call to a fire-dom-event. However, when I do, it still does not work.
Below is a sample of the Yaml and the error message.
Error in the logs:
Uncaught error from Chrome 135.0.0.0 on Windows 10 TypeError: Cannot read properties of null (reading ‘addEventListener’) zt.close (/hacsfiles/honeycomb-menu/honeycomb-menu.js:257:973) /hacsfiles/honeycomb-menu/honeycomb-menu.js:119:3195 window.honeycomb_menu (/hacsfiles/honeycomb-menu/honeycomb-menu.js:119:3901) HTMLBodyElement. (/hacsfiles/honeycomb-menu/honeycomb-menu.js:119:4110) pe (/hacsfiles/ha-floorplan/floorplan.js:52:482) Pi.handleActions (/hacsfiles/ha-floorplan/floorplan.js:131:19122) me.onClick (/hacsfiles/ha-floorplan/floorplan.js:131:17855) /hacsfiles/ha-floorplan/floorplan.js:52:3424
Thxs for the reply. I redownloaded both floor-plan and honeycomb, same issue.
If I specify one entity, like the following, it works.
If I have a list of entities, in the original post, it does not:
There is probably a conflict, probably because floorplan doesn’t use config as a normal lovelace card and therefore honeycomb can’t assign the correct entities.
Anyway, try to assign entity to a button, or use variables. My config looks like this
Thxs for the reply.
However, this will not work for me.
For my honeycomb menu, each position (0 thru 5) does an operation for the entity under - entities
In your case, you have hard coded the entity, for each position.
One work around for me, maybe is to use a script and pass in the entity.
I think that was what you were referring to by using variables.
I think right now, I’ll back out honeycomb menu version to the previous version.
I’m going to write this up as an issue.
Using the older version of HoneyComb is the only solution.
They closed the issue I reported, so there is no plan to fix it I guess.
They said there is no issue but multiple users have reported an issue.
So, who knows if it will ever be fixed.
Honeycomb menu is a Home Assistant module (not a card) that can be applied to any lovelace card. When activated by the defined action on said card, the module will display a ‘rounded’ list of honeycomb buttons with an optional XY pad to make interfacing with lovelace more fluent
Here is a snippet of code I use for my floorplan. I jumped to the new format the second I saw the warning in the logs and it gave me an opportunity to iron it out, so-to-speak.
So, if you have the following entities and you wanted the buttons to be; off, slow, low, medium, high. How would you do that?
- fan.master_bed_room_fan
- fan.south_bed_room_fan
- fan.north_bed_room_fan
See the original post for the complete issue.
Kevin
Correct me if I’m wrong, but what you’re trying to do is have the buttons in a honeycomb control all 3 fans simultaneously?
If so, your logic is mucked up a bit. A simple fix is to create a helper (choose group, then fan group) and use the group as your main entity. You can’t use entities: (that I know of) and then list multiple entities.
Also, for the data fields for each button, you would list the fan group as your entity_id. You have to define an entity in that field irregardless. You currently have entity.
No, it would not control all 3 fans at one time. Before the update, you could include multiple fans, and based on which one you selected in the GUI, it would use this one rule.
Now, you have to separate out each fan, into its own, honeycomb rule for the same exact functionality of the buttons. Its duplicating the same YAML, for each entity. Something that is harder to maintain.
I see… well that’s a bummer. I’ve reread the readme and that functionality isn’t there, so yea, it must’ve been removed with the new call service. You could reach out to the developer on GitHub and request that feature back or something similar be added. Otherwise, unfortunately, it seems you’ll need to define honeycomb menus for each of your fans. That’s what I do and I include it on the state-icons on my floorplan.
yes, its a real bummer. So I have a total of 6 ceiling fans in my house. Each honeycomb Yaml is about 60 lines, so instead of 60 lines of Yaml, I now have 60 * 6 = 360 lines of Yaml. Also, if I need to make changes to the ceiling Fan Yaml, I have to make the same change 6 times. The only difference, is one line, the entity name. This is really a poor design change!
