For the life of me I can’t find what version ESPhome I’m running. I would hope after digging an available update note would be somewhere like when HA needs an update.
How do I tell what version I’m on?
It’s not at the top of the Settings page. Like an ha update is.
It’s not on the ESPhome dashboard that shows all of my esphome devices.
It’s not on the settings/integrations page.
See Home Assistant Add-on Repo ESPHome 2022.2.0 - 16th February 2022 — ESPHome. First delete the old ESPHome add-on and then add the repo by pressing the blue repo button and next add the add-on by pressing the blue add-on button.
To remove the old version go to setting->add-ons->ESPHome and click on uninstall.
Deleting the add-on has no impact on your yaml files, however having a backup is always a good thing…
Is there esphome doc that says delete the whole add-on? That seems really really sketchy. There is no mention of update instructions in the version link you posted for esphome. Where did you learn that is the way to update esphome?
If you are using the ESPHome version from the community add-on repo there will be no new update because that version is deprecated. So auto update will also not work because there is no new update within the community add-on repro anymore
Before I changed the repo myself, I removed the old add-on, added the new repo and installed the ESPHome just as described in the link I posted. Your yaml files are stored in /config/esphome and this directory is not removed when removing a ESPHome add-on. You can even install the current, beta and dev version of ESPHome side by side (and removing them), they are all using the same location of the yaml-files. This wouldn’t work if one of them removes this directory when you uninstall one of them.
So after switching to the right add-on repo you can activate the auto update toggle if you wish. I’m personally not a fan of auto-update. I want to read the change log first, to see if there are breaking changes impacting the working of my nodes.
Off course you can switch to the new repo without removing the old one, I didn’t test it, but I wouldn’t be surprised if you end up with two versions of ESPHome, the old one from the community add-on repro and a new one form the new repo.
The part: ABP2DANT001PGSA3XX
Wired
1 Gnd
2 3.3v
3 MISO
4 SS
5 SOSI
6 SCLK
[02:08:56][D][sensor:124]: ‘Honeywell pressure’: Sending state -1.87500 psi with 1 decimals of accuracy
[02:08:56][D][sensor:124]: ‘Honeywell temperature’: Sending state -50.00000 °C with 1 decimals of accuracy
