There you go:
SCHEMA_MSG_IDS: tuple = (
"03", # ..3: "Slave configuration",
"06", # ..6: "Remote boiler parameter flags", # 0x38, 0x39
"7D", # 125: "Opentherm version Slave", # not native
"7F", # 127: "Slave product version number and type",
# These are STATUS seen RQ'd by 01:/30:, but here to retreive less frequently
"71", # 113: "Number of un-successful burner starts",
"72", # 114: "Number of times flame signal was too low",
"74", # 116: "Number of starts burner",
"75", # 117: "Number of starts central heating pump",
"76", # 118: "Number of starts DHW pump/valve",
"77", # 119: "Number of starts burner during DHW mode",
"78", # 120: "Number of hours burner is in operation (i.e. flame on)",
"79", # 121: "Number of hours central heating pump has been running",
"7A", # 122: "Number of hours DHW pump has been running/valve has been opened",
"7B", # 123: "Number of hours DHW burner is in operation during DHW mode",
PARAMS_MSG_IDS: tuple = (
"0E", # .14: "Maximum relative modulation level setting (%)"
"0F", # .15: "Max. boiler capacity (kW) and modulation level setting (%)",
"30", # .48: "DHW Setpoint upper & lower bounds for adjustment (°C)",
"31", # .49: "Max CH water Setpoint upper & lower bounds for adjustment (°C)",
"38", # .56: "DHW Setpoint (°C) (Remote parameter 1)", # see: 0x06
"39", # .57: "Max CH water Setpoint (°C) (Remote parameter 2)", # see: 0x06
STATUS_MSG_IDS: tuple = (
"00", # ..0: "Master/Slave status flags", # not RAMSES
"01", # ..1: "CH water temperature Setpoint (°C)", # also R/W
"11", # .17: "Relative Modulation Level (%)",
"12", # .18: "Water pressure in CH circuit (bar)",
"13", # .19: "Water flow rate in DHW circuit. (L/min)",
"19", # .25: "Boiler flow water temperature (°C)",
"1A", # .26: "DHW temperature (°C)",
"1B", # .27: "Outside temperature (°C)", # TODO: any value here?
"1C", # .28: "Return water temperature (°C)",
# These are error/state codes...
"05", # ..5: "Fault flags & OEM codes", # not RAMSES
"73", # 115: "OEM diagnostic code", # not RAMSES
