Functions and Features
ch: max setpoint adjustment
ch: otc control
ch: remote lockout-reset
ch: remote parameters
ch: remote room setpoint
ch: roomtemp control
ch: service/diagnostics
dhw: setpoint adjustment
general: standard ID’s
ID 000:HB0: Master status: CH enable
ID 000:HB1: Master status: DHW enable
ID 000:HB2: Master status: Cooling enable
ID 000:HB3: Master status: OTC active
ID 000:HB5: Master status: Summer/winter mode
ID 000:HB6: Master status: DHW blocking
ID 000:LB0: Slave Status: Fault indication
ID 000:LB1: Slave Status: CH mode
ID 000:LB2: Slave Status: DHW mode
ID 000:LB3: Slave Status: Flame status
ID 001: Control Setpoint i.e. CH water temperature Setpoint (°C)
ID 002:HB0: Master configuration: Smart power
ID 002:LB: Master MemberID Code
ID 003:HB0: Slave configuration: DHW present
ID 003:HB1: Slave configuration: Control type
ID 003:HB4: Slave configuration: Master low-off&pump control
ID 005:HB0: Service request
ID 005:HB1: Lockout-reset
ID 005:HB2: Low water pressure
ID 005:HB3: Gas/flame fault
ID 005:HB4: Air pressure fault
ID 005:HB5: Water over-temperature
ID 005:LB: OEM fault code
ID 006:HB0: Remote boiler parameter transfer-enable: DHW setpoint
ID 006:HB1: Remote boiler parameter transfer-enable: max. CH setpoint
ID 006:LB0: Remote boiler parameter read/write: DHW setpoint
ID 006:LB1: Remote boiler parameter read/write: max. CH setpoint
ID 009: Remote override room Setpoint
ID 010: Number of Transparent-Slave-Parameters supported by slave
ID 012: Size of Fault-History-Buffer supported by slave
ID 014 : Maximum relative modulation level setting (%)
ID 016: Room Setpoint (°C)
ID 017: Relative Modulation Level (%)
ID 018: Water pressure in CH circuit (bar)
ID 019: Water flow rate in DHW circuit. (litres/minute)
ID 024: Room temperature (°C)
ID 025: Boiler flow water temperature (°C)
ID 026: DHW temperature (°C)
ID 027: Outside temperature (°C)
ID 028: Return water temperature (°C)
ID 048: DHW Setpoint upper & lower bounds for adjustment (°C)
ID 049: Max CH water Setpoint upper & lower bounds for adjustment (°C)
ID 056: DHW Setpoint (°C) (Remote parameter 1)
ID 057: Max CH water Setpoint (°C) (Remote parameters 2)
ID 126: Master product version number and type
ID 127: Slave product version number and type
yes, that is the precise EMS-OT converter i have inbetween my boiler and the OTB.
to read out my EMS bus i use the following: https://github.com/emsesp/EMS-ESP32
i understood you can upgrade the ESP8266 version to the newer types with an ESP32 mini.
Kees made a wiki about the upgrade: wiki upgrade i have only have the interface board (even older design) i still have it connected via jumper wires. so i could easily made the change from ESP8266 to ESP32. i am willing to paypal you for all your efforts and support. let me know how.
So i have stuff and i think its sort of working but i really dont understand what im supposed to be doing with these known lists etc
im using a hgi 80 with an opentherm bridge the controller is in a zone with a trv i have 7 zones one with 2 valves in it. any help greatfully received!
Go to: /developer-tools/state and filter on “schema”. You would find something like binary_sensor.01_223036_schema, in the attribute list you can find the stuff to add to you known list.
The issue is that the RF comms are relatively unreliable with very poor error detection / correction.
Thus, corrupted but valid packets are common, and many of these have ‘ghost’ device IDs.
Using a known_list (we once used the phrase ‘whitelist’) allows ramses_rf to discard these corrupted packets (and provide for other benefits, such as faking).
I can’t recall how Domoticz did it, but if they’re not using the same technology, either they’re missing out on features (such as auto discovery), or ghost devices are popping up.
Actually, the above is not optimal: instead go to the **18:xxxxxx status binary sensor - the known_list is in there.
NOTE: I am shortly to investigate reports where the above sensor does not appears unless you first list the gateway in teh known list, along with its type:
