Honeywell CH/DHW via RF - evohome, sundial, hometronics, chronotherm
You don’t have a valve in your property that allows / stops the communal HW from coming in? If so, that woudl be a target fro a BDR91 / R8810.
Other than that, you would be better off getting a bunch of Bluetooth TRVs - much cheaper than HR92s too.
But note: a room thermostat is much more accurate that using the 'stats in teh TRVs.
@zxdavb i tried to create a fake remote for my itho fan, but i want first to know the id’s of both. (Fan and real remote)
When i take a look in my log file when i press a button on the remote i see:
I --- 20:007902 --:------ 20:007902 31DA 029 00EF007FFFEFEF7FFF7FFF7FFF7FFFF000EF0101000000EFEF7FFF7FFF
i think thats the id of the remote?
I moved over from EvoGateway to Evohome_CC and honestly, it went without a hitch. Thanks, guys for coding this:-)
I installed HA in a VM first to go through the install and build configuration, then once I saw it working I moved over to my HA server and it was up and running very quickly.
Just one issue, a minor one. I added a logger section to my configuration like this.
#logger:
#  default: warn
#  logs:
#    homeassistant.core: debug
#    custom_components.ramses_cc: info
#    ramses_rf.dispatcher: info
#    ramses_rf.protocol.protocol: info
#    ramses_rf.protocol.transport: info
I’m not seeing anything from ramses_rf.dispatcher: info
Could I be doing something wrong? The log file is full of everything else I’d expect to be seeing.
cheers,
Mike
Actively using this integration inc combo with a EvoHome install.
However I also have some Orphans in HVAC;
        "orphans_hvac": [
          "20:001676",
          "20:004772",
          "20:017294",
          "37:088287",
          "37:088288",
          "37:088297",
          "37:088301",
          "37:088302",
          "37:100120"
Packets below. Could anybody tell me what devices this can be? I have a split airco setup and hoping that is actually might be that or something else in my house of which I did not know I could control it. Or is this my neighbors stuff?
Packets (took some out to avoid to large file)
      "packets": {
        "2023-01-14T13:33:25.362255": "... RQ --- 34:245645 01:202227 --:------ 000A 001 09 # 000A|RQ|34:245645|09 (09)",
        "2023-01-14T13:33:25.443190": "... RQ --- 34:245645 01:202227 --:------ 2309 001 09 # 2309|RQ|34:245645|09 (09)",
        "2023-01-14T13:33:31.949388": "...  W --- 34:245645 01:202227 --:------ 2309 003 090708 # 2309| W|34:245645|09 (09)",
        "2023-01-14T14:08:53.104407": "... RQ --- 04:035126 01:202227 --:------ 0004 002 0000 # 0004|RQ|04:035126|00 (00)",
        "2023-01-15T19:33:22.398591": "... RQ --- 04:044879 01:202227 --:------ 0004 002 0900 # 0004|RQ|04:044879|09 (09)",
        "2023-01-15T19:33:41.315594": "... RQ --- 04:044879 01:202227 --:------ 1F09 001 00 # 1F09|RQ|04:044879",
        "2023-01-15T19:42:24.373721": "...  I --- 04:044879 --:------ 04:044879 10E0 038 000002FF0412FFFFFFFF1B0807E30D0307DE48523932205261646961746F72204374726C2E00 # 10E0| I|04:044879",
        "2023-01-24T15:37:35.663852": "... RQ --- 04:038517 01:202227 --:------ 0004 002 0600 # 0004|RQ|04:038517|06 (06)",
        "2023-01-31T23:47:21.416342": "...  I --- 37:088302 --:------ 37:088302 10E0 038 000001001B391B01FEFFFFFFFFFF040B07E54356452D52460000000000000000000000000000 # 10E0| I|37:088302",
        "2023-02-04T21:25:59.253599": "...  I --- 20:017294 --:------ 20:017294 10E0 038 000001001B221201FEFFFFFFFFFF0C0507DF4356452D52460000000000000000000000000000 # 10E0| I|20:017294",
        "2023-02-04T21:52:21.560720": "... RQ --- 04:038517 01:202227 --:------ 0100 005 006E6CFFFF # 0100|RQ|04:038517",
        "2023-02-04T21:52:23.459119": "...  I --- 04:038517 --:------ 01:202227 1060 003 066401 # 1060| I|04:038517|06 (06)",
        "2023-02-04T21:52:23.469842": "...  I --- 04:038517 --:------ 04:038517 1060 003 006401 # 1060| I|04:038517",
        "2023-02-04T21:54:47.677830": "... RQ --- 04:044877 01:202227 --:------ 0100 005 006E6CFFFF # 0100|RQ|04:044877",
        "2023-02-04T21:54:48.552530": "...  I --- 04:044877 --:------ 01:202227 1060 003 016401 # 1060| I|04:044877|01 (01)",
        "2023-02-04T21:54:48.567564": "...  I --- 04:044877 --:------ 04:044877 1060 003 006401 # 1060| I|04:044877",
        "2023-02-04T23:10:47.858167": "... RP --- 01:202227 18:066571 --:------ 000C 006 02040010AF4B # 000C|RP|01:202227|0204 (0204)",
        "2023-02-04T23:10:50.526960": "... RP --- 01:202227 18:066571 --:------ 000C 006 000400108936 # 000C|RP|01:202227|0004 (0004)",
        "2023-02-04T23:10:53.360006": "... RP --- 01:202227 18:066571 --:------ 000C 006 030800109679 # 000C|RP|01:202227|0308 (0308)",
        "2023-02-04T23:10:53.614731": "... RP --- 01:202227 18:066571 --:------ 000C 006 000800108936 # 000C|RP|01:202227|0008 (0008)",
        "2023-02-04T23:10:56.900895": "... RP --- 01:202227 18:066571 --:------ 000C 012 01080010AF5101080010AF4D # 000C|RP|01:202227|0108 (0108)",
        "2023-02-04T23:10:57.048898": "... RP --- 01:202227 18:066571 --:------ 000C 006 04080010967B # 000C|RP|01:202227|0408 (0408)",
        "2023-02-04T23:10:57.519947": "... RP --- 01:202227 18:066571 --:------ 000C 006 030400109679 # 000C|RP|01:202227|0304 (0304)",
        "2023-02-04T23:10:58.080486": "... RP --- 01:202227 18:066571 --:------ 000C 018 090800127ED109080010AF4F090800108930 # 000C|RP|01:202227|0908 (0908)",
        "2023-02-04T23:10:59.497261": "... RP --- 01:202227 18:066571 --:------ 000C 006 02080010AF4B # 000C|RP|01:202227|0208 (0208)",
        "2023-02-04T23:10:59.547961": "... RP --- 01:202227 18:066571 --:------ 000C 006 050800109677 # 000C|RP|01:202227|0508 (0508)",
        "2023-02-04T23:10:59.844191": "... RP --- 01:202227 18:066571 --:------ 000C 006 080800108938 # 000C|RP|01:202227|0808 (0808)",
        "2023-02-04T23:11:00.521072": "... RP --- 01:202227 18:066571 --:------ 000C 006 01047FFFFFFF # 000C|RP|01:202227|0104 (0104)",
        "2023-02-04T23:11:01.280880": "... RP --- 01:202227 18:066571 --:------ 000C 006 060400109675 # 000C|RP|01:202227|0604 (0604)",
        "2023-02-04T23:11:03.146127": "... RP --- 01:202227 18:066571 --:------ 000C 006 04040010967B # 000C|RP|01:202227|0404 (0404)",
        "2023-02-04T23:11:06.189565": "... RP --- 01:202227 18:066571 --:------ 000C 006 000E7FFFFFFF # 000C|RP|01:202227|000E (000E)",
        "2023-02-04T23:11:09.055430": "... RP --- 01:202227 18:066571 --:------ 000C 006 080400108938 # 000C|RP|01:202227|0804 (0804)",
        "2023-02-04T23:11:14.795586": "... RP --- 01:202227 18:066571 --:------ 000C 006 070800108932 # 000C|RP|01:202227|0708 (0708)",
        "2023-02-04T23:11:17.864843": "... RP --- 01:202227 18:066571 --:------ 000C 006 070400108932 # 000C|RP|01:202227|0704 (0704)",
        "2023-02-04T23:11:22.243674": "... RP --- 01:202227 18:066571 --:------ 000C 006 000F7FFFFFFF # 000C|RP|01:202227|000F (000F)",
        "2023-02-04T23:11:22.354203": "... RP --- 01:202227 18:066571 --:------ 0005 004 000A0000 # 0005|RP|01:202227|000A (000A)",
        "2023-02-04T23:11:25.449610": "... RP --- 01:202227 18:066571 --:------ 000C 006 000D7FFFFFFF # 000C|RP|01:202227|000D (000D)",
        "2023-02-04T23:11:25.589580": "... RP --- 01:202227 18:066571 --:------ 0005 004 0008FF03 # 0005|RP|01:202227|0008 (0008)",
        "2023-02-04T23:11:25.790694": "... RP --- 01:202227 18:066571 --:------ 0005 004 00090000 # 0005|RP|01:202227|0009 (0009)",
        "2023-02-04T23:11:25.991544": "... RP --- 01:202227 18:066571 --:------ 0005 004 000B0000 # 0005|RP|01:202227|000B (000B)",
        "2023-02-04T23:11:28.030931": "... RP --- 01:202227 18:066571 --:------ 000C 006 050400109677 # 000C|RP|01:202227|0504 (0504)",
        "2023-02-04T23:11:28.223563": "... RP --- 01:202227 18:066571 --:------ 000C 006 060800109675 # 000C|RP|01:202227|0608 (0608)",
        "2023-02-04T23:11:28.935637": "... RP --- 01:202227 18:066571 --:------ 000C 006 0904008BBF8D # 000C|RP|01:202227|0904 (0904)",
        "2023-02-04T23:11:29.130647": "... RP --- 01:202227 18:066571 --:------ 000C 006 010E7FFFFFFF # 000C|RP|01:202227|010E (010E)",
        "2023-02-04T23:11:51.687191": "... RP --- 01:202227 18:066571 --:------ 0005 004 0004FF03 # 0005|RP|01:202227|0004 (0004)",
        "2023-02-04T23:19:45.687764": "... RP --- 10:029511 18:066571 --:------ 3220 005 00C07D0300 # 3220|RP|10:029511|7D (7D)",
        "2023-02-04T23:19:48.753495": "... RP --- 10:029511 18:066571 --:------ 3220 005 00C0060303 # 3220|RP|10:029511|06 (06)",
        "2023-02-04T23:21:32.398933": "...  I --- 37:088287 --:------ 37:088287 10E0 038 000001001B391B01FEFFFFFFFFFF040B07E54356452D52460000000000000000000000000000 # 10E0| I|37:088287",
        "2023-02-04T23:22:38.126765": "... RQ --- 04:035128 01:202227 --:------ 0100 005 006E6CFFFF # 0100|RQ|04:035128",
        "2023-02-04T23:22:38.903967": "...  I --- 04:035128 --:------ 01:202227 1060 003 086401 # 1060| I|04:035128|08 (08)",
        "2023-02-04T23:22:38.918875": "...  I --- 04:035128 --:------ 04:035128 1060 003 006401 # 1060| I|04:035128",
        "2023-02-04T23:44:40.263822": "...  I --- 37:088288 --:------ 37:088288 10E0 038 000001001B391B01FEFFFFFFFFFF040B07E54356452D52460000000000000000000000000000 # 10E0| I|37:088288",
        "2023-02-05T04:00:20.650279": "... RQ --- 04:038523 01:202227 --:------ 313F 001 00 # 313F|RQ|04:038523",
        "2023-02-05T04:00:25.313814": "... RQ --- 04:038521 01:202227 --:------ 313F 001 00 # 313F|RQ|04:038521",
        "2023-02-05T04:00:30.295058": "... RQ --- 04:035122 01:202227 --:------ 313F 001 00 # 313F|RQ|04:035122",
        "2023-02-05T04:00:31.312133": "... RQ --- 04:035126 01:202227 --:------ 313F 001 00 # 313F|RQ|04:035126",
      ------ took some out------
        "2023-02-05T18:49:02.567495": "... RQ --- 01:202227 10:029511 --:------ 3220 005 0080760000 # 3220|RQ|01:202227|76 (76)",
        "2023-02-05T18:49:02.763429": "... RQ --- 01:202227 10:029511 --:------ 3220 005 0000770000 # 3220|RQ|01:202227|77 (77)",
        "2023-02-05T18:49:02.791608": "... RP --- 10:029511 01:202227 --:------ 3220 005 0030770000 # 3220|RP|10:029511|77 (77)",
        "2023-02-05T18:49:02.963160": "... RQ --- 01:202227 10:029511 --:------ 3220 005 0000780000 # 3220|RQ|01:202227|78 (78)",
        "2023-02-05T18:49:02.985371": "... RP --- 10:029511 01:202227 --:------ 3220 005 0030780000 # 3220|RP|10:029511|78 (78)",
        "2023-02-05T18:49:03.163369": "... RQ --- 01:202227 10:029511 --:------ 3220 005 0080790000 # 3220|RQ|01:202227|79 (79)",
        "2023-02-05T18:49:03.189389": "... RP --- 10:029511 01:202227 --:------ 3220 005 00B0790000 # 3220|RP|10:029511|79 (79)",
        "2023-02-05T18:49:03.399794": "... RQ --- 01:202227 10:029511 --:------ 3220 005 00807A0000 # 3220|RQ|01:202227|7A (7A)",
        "2023-02-05T18:49:03.401230": "... RP --- 10:029511 01:202227 --:------ 3220 005 00B07A0000 # 3220|RP|10:029511|7A (7A)",
        "2023-02-05T18:49:03.563332": "... RQ --- 01:202227 10:029511 --:------ 3220 005 00007B0000 # 3220|RQ|01:202227|7B (7B)",
        "2023-02-05T18:49:03.584010": "... RP --- 10:029511 01:202227 --:------ 3220 005 00307B0000 # 3220|RP|10:029511|7B (7B)",
        "2023-02-05T18:49:03.763506": "... RQ --- 01:202227 10:029511 --:------ 3220 005 00807F0000 # 3220|RQ|01:202227|7F (7F)",
        "2023-02-05T18:49:03.780537": "... RP --- 10:029511 01:202227 --:------ 3220 005 00407F0A14 # 3220|RP|10:029511|7F (7F)",
        "2023-02-05T18:49:06.686485": "... RP --- 10:029511 18:066571 --:------ 3220 005 00B0760000 # 3220|RP|10:029511|76 (76)",
        "2023-02-05T18:55:01.962347": "...  I --- 04:044877 --:------ 01:202227 2309 003 0107D0 # 2309| I|04:044877|01 (01)",
        "2023-02-05T18:55:30.156533": "...  I --- 04:035122 --:------ 01:202227 2309 003 0704B0 # 2309| I|04:035122|07 (07)",
        "2023-02-05T18:58:46.457670": "...  I --- 04:044877 --:------ 01:202227 12B0 003 010000 # 12B0| I|04:044877|01 (01)",
        "2023-02-05T19:00:01.067040": "...  I --- 04:072385 --:------ 63:262142 12B0 003 000000 # 12B0| I|04:072385",
        "2023-02-05T19:00:35.789846": "...  I --- 04:035128 --:------ 04:035128 30C9 003 00067C # 30C9| I|04:035128",
        "2023-02-05T19:01:19.681809": "... RP --- 01:202227 18:066571 --:------ 313F 009 00FC0301D3050207E7 # 313F|RP|01:202227",
        "2023-02-05T19:01:55.355411": "...  I --- 04:035120 --:------ 01:202227 2309 003 0906D6 # 2309| I|04:035120|09 (09)",
        "2023-02-05T19:04:13.502049": "... RQ --- 04:163537 01:202227 --:------ 0100 005 006E6CFFFF # 0100|RQ|04:163537",
        "2023-02-05T19:04:50.582754": "...  I --- 04:163537 --:------ 01:202227 2309 003 0906D6 # 2309| I|04:163537|09 (09)",
        "2023-02-05T19:05:16.814240": "... RP --- 10:029511 18:066571 --:------ 10A0 003 001770 # 10A0|RP|10:029511",
        "2023-02-05T19:05:19.925465": "... RP --- 10:029511 18:066571 --:------ 3220 005 00C0303C28 # 3220|RP|10:029511|30 (30)",
        "2023-02-05T19:07:34.211361": "... RP --- 10:029511 18:066571 --:------ 1081 003 001770 # 1081|RP|10:029511",
        "2023-02-05T19:07:36.314044": "... RQ --- 04:035120 01:202227 --:------ 0100 005 006E6CFFFF # 0100|RQ|04:035120",
        "2023-02-05T19:08:07.367725": "... RP --- 10:029511 18:066571 --:------ 3220 005 0040313C14 # 3220|RP|10:029511|31 (31)",
        "2023-02-05T19:10:40.534719": "...  I --- 04:044875 --:------ 01:202227 12B0 003 020000 # 12B0| I|04:044875|02 (02)",
        "2023-02-05T19:11:51.523062": "...  I --- 04:044875 --:------ 01:202227 2309 003 020640 # 2309| I|04:044875|02 (02)",
        "2023-02-05T19:11:52.663261": "...  I --- 04:038519 --:------ 04:038519 30C9 003 0005FF # 30C9| I|04:038519",
        "2023-02-05T19:12:14.903690": "...  I --- 04:038523 --:------ 01:202227 3150 002 0400 # 3150| I|04:038523|04 (04)",
        "2023-02-05T19:13:40.169542": "...  I --- 04:038521 --:------ 01:202227 12B0 003 030000 # 12B0| I|04:038521|03 (03)",
        "2023-02-05T19:15:30.787638": "...  I --- 04:044881 --:------ 04:044881 30C9 003 000E47 # 30C9| I|04:044881",
        "2023-02-05T19:17:56.445527": "...  I --- 04:038519 --:------ 01:202227 3150 002 0500 # 3150| I|04:038519|05 (05)",
        "2023-02-05T19:18:30.567210": "...  I --- 04:035126 --:------ 04:035126 30C9 003 000597 # 30C9| I|04:035126",
        "2023-02-05T19:19:00.986621": "...  I --- 04:044877 --:------ 01:202227 3150 002 0144 # 3150| I|04:044877|01 (01)",
        "2023-02-05T19:19:01.872986": "...  I --- 04:044881 --:------ 01:202227 3150 002 0144 # 3150| I|04:044881|01 (01)",
        "2023-02-05T19:19:35.042473": "...  I --- 37:088297 --:------ 37:088297 10E0 038 000001001B391B01FEFFFFFFFFFF040B07E54356452D52460000000000000000000000000000 # 10E0| I|37:088297",
        "2023-02-05T19:19:52.292577": "...  I --- 34:245645 63:262142 --:------ 10E0 038 000001C8380F0100F1FF080A07E3030507E15438375246323032350000000000000000000000 # 10E0| I|34:245645",
        "2023-02-05T19:19:52.350135": "...  I --- 34:245645 --:------ 34:245645 1060 003 00FF01 # 1060| I|34:245645",
        "2023-02-05T19:20:04.092730": "...  I --- 04:072385 --:------ 63:262142 3150 002 0000 # 3150| I|04:072385",
        "2023-02-05T19:20:22.589138": "...  I --- 04:035128 --:------ 01:202227 2309 003 0805DC # 2309| I|04:035128|08 (08)",
        "2023-02-05T19:20:46.453867": "...  I --- 10:029511 --:------ 10:029511 10E0 038 000001C8810B0700FEFFFFFFFFFF140807E35238383230000000000000000000000000000000 # 10E0| I|10:029511",
        "2023-02-05T19:21:06.087185": "...  I --- 04:044879 --:------ 01:202227 12B0 003 090000 # 12B0| I|04:044879|09 (09)",
        "2023-02-05T19:21:14.107454": "...  I --- 04:035122 --:------ 01:202227 12B0 003 070000 # 12B0| I|04:035122|07 (07)",
        "2023-02-05T19:22:04.345847": "...  I --- 04:044879 --:------ 04:044879 30C9 003 000DA6 # 30C9| I|04:044879",
        "2023-02-05T19:22:29.426361": "...  I --- 04:035126 --:------ 01:202227 3150 002 003E # 3150| I|04:035126|00 (00)",
        "2023-02-05T19:22:38.495445": "...  I --- 04:035128 --:------ 01:202227 12B0 003 080000 # 12B0| I|04:035128|08 (08)",
        "2023-02-05T19:23:01.816551": "... RP --- 01:202227 18:066571 --:------ 12B0 003 060000 # 12B0|RP|01:202227|06 (06)",
        "2023-02-05T19:23:03.544497": "... RP --- 01:202227 18:066571 --:------ 12B0 003 070000 # 12B0|RP|01:202227|07 (07)",
        "2023-02-05T19:23:03.732362": "... RP --- 01:202227 18:066571 --:------ 12B0 003 080000 # 12B0|RP|01:202227|08 (08)",
        "2023-02-05T19:23:08.398553": "... RP --- 01:202227 18:066571 --:------ 12B0 003 050000 # 12B0|RP|01:202227|05 (05)",
        "2023-02-05T19:23:09.654649": "... RP --- 01:202227 18:066571 --:------ 12B0 003 000000 # 12B0|RP|01:202227|00 (00)",
        "2023-02-05T19:23:12.903846": "... RP --- 01:202227 18:066571 --:------ 12B0 003 030000 # 12B0|RP|01:202227|03 (03)",
        "2023-02-05T19:23:13.711708": "... RP --- 01:202227 18:066571 --:------ 12B0 003 040000 # 12B0|RP|01:202227|04 (04)",
        "2023-02-05T19:23:14.931611": "... RP --- 01:202227 18:066571 --:------ 12B0 003 020000 # 12B0|RP|01:202227|02 (02)",
        "2023-02-05T19:24:07.385521": "...  I 081 37:088302 --:------ 37:088302 31D9 017 0006280020202020202020202020202000 # 31D9| I|37:088302|00 (00)",
        "2023-02-05T19:25:09.307620": "...  I --- 04:035120 --:------ 01:202227 3150 002 09A6 # 3150| I|04:035120|09 (09)",
        "2023-02-05T19:27:37.660323": "...  I --- 04:035128 --:------ 01:202227 3150 002 0800 # 3150| I|04:035128|08 (08)",
        "2023-02-05T19:27:42.173201": "...  I --- 37:088302 --:------ 37:088302 31DA 030 00EF007FFF3EEF7FFF7FFF7FFF7FFFF800EF1828000000EFEF7FFF7FFF00 # 31DA| I|37:088302",
        "2023-02-05T19:27:48.222529": "...  I --- 04:044877 --:------ 04:044877 30C9 003 000E07 # 30C9| I|04:044877",
        "2023-02-05T19:27:50.658895": "...  I --- 04:035122 --:------ 01:202227 3150 002 0700 # 3150| I|04:035122|07 (07)",
        "2023-02-05T19:28:17.305003": "...  I 077 37:088288 --:------ 37:088288 31D9 017 0006290020202020202020202020202000 # 31D9| I|37:088288|00 (00)",
        "2023-02-05T19:28:30.273149": "...  I --- 37:088287 --:------ 37:088287 31DA 030 00EF007FFF42EF7FFF7FFF7FFF7FFFF800EF1829000000EFEF7FFF7FFF00 # 31DA| I|37:088287",
        "2023-02-05T19:28:38.105419": "...  I 028 37:088287 --:------ 37:088287 31D9 017 0006290020202020202020202020202000 # 31D9| I|37:088287|00 (00)",
        "2023-02-05T19:29:38.848213": "... RP --- 01:202227 18:066571 --:------ 12B0 003 010000 # 12B0|RP|01:202227|01 (01)",
        "2023-02-05T19:31:10.272866": "...  I --- 04:044875 --:------ 01:202227 3150 002 0200 # 3150| I|04:044875|02 (02)",
        "2023-02-05T19:31:33.047352": "...  I --- 04:035126 --:------ 01:202227 12B0 003 000000 # 12B0| I|04:035126|00 (00)",
        "2023-02-05T19:31:42.029800": "...  I --- 37:088288 --:------ 37:088288 31DA 030 00EF007FFF36EF7FFF7FFF7FFF7FFFF800EF1829000000EFEF7FFF7FFF00 # 31DA| I|37:088288",
        "2023-02-05T19:31:45.886616": "...  I --- 01:202227 --:------ 01:202227 2309 030 0005780107D00206400306A404073A0505DC0605DC0704B00805DC0905DC # 2309| I|01:202227 (True)",
        "2023-02-05T19:31:45.910713": "...  I --- 01:202227 --:------ 01:202227 30C9 030 0005970107F60206A70306E404068F0505FF0605DF0705F508067C0906E9 # 30C9| I|01:202227 (True)",
        "2023-02-05T19:32:08.918602": "...  I --- 04:163537 --:------ 01:202227 3150 002 0900 # 3150| I|04:163537|09 (09)",
        "2023-02-05T19:32:10.541968": "...  I --- 04:038521 --:------ 01:202227 3150 002 0328 # 3150| I|04:038521|03 (03)",
        "2023-02-05T19:32:10.745812": "...  I --- 04:044879 --:------ 01:202227 3150 002 0900 # 3150| I|04:044879|09 (09)",
        "2023-02-05T19:32:13.284237": "...  I --- 01:202227 --:------ 01:202227 3150 002 FC44 # 3150| I|01:202227|FC (FC)",
        "2023-02-05T19:32:25.956226": "...  I --- 04:038521 --:------ 01:202227 2309 003 0306A4 # 2309| I|04:038521|03 (03)",
        "2023-02-05T19:32:30.830124": "...  I --- 04:038517 --:------ 01:202227 3150 002 0600 # 3150| I|04:038517|06 (06)",
        "2023-02-05T19:32:36.526427": "...  I --- 01:202227 --:------ 01:202227 3B00 002 FCC8 # 3B00| I|01:202227|FC (FC)",
        "2023-02-05T19:32:50.836686": "...  I --- 04:038519 --:------ 01:202227 12B0 003 050000 # 12B0| I|04:038519|05 (05)",
        "2023-02-05T19:33:05.188568": "... RQ --- 04:044879 01:202227 --:------ 0100 005 006E6CFFFF # 0100|RQ|04:044879",
        "2023-02-05T19:33:05.204557": "... RP --- 01:202227 04:044879 --:------ 0100 005 006E6CFFFF # 0100|RP|01:202227",
        "2023-02-05T19:33:07.700668": "...  I --- 04:044879 --:------ 01:202227 1060 003 09C801 # 1060| I|04:044879|09 (09)",
        "2023-02-05T19:33:07.718807": "...  I --- 04:044879 --:------ 04:044879 1060 003 00C801 # 1060| I|04:044879",
        "2023-02-05T19:33:09.036456": "...  I --- 37:088297 --:------ 37:088297 31DA 030 00EF007FFF4EEF7FFF7FFF7FFF7FFFF800EF0101000000EFEF7FFF7FFF00 # 31DA| I|37:088297",
        "2023-02-05T19:33:11.601861": "... RP --- 10:029511 18:066571 --:------ 3200 003 0010C1 # 3200|RP|10:029511",
        "2023-02-05T19:33:19.471014": "...  I --- 04:044879 --:------ 01:202227 2309 003 0905DC # 2309| I|04:044879|09 (09)",
        "2023-02-05T19:33:23.886257": "...  I 042 37:088297 --:------ 37:088297 31D9 017 0006010020202020202020202020202000 # 31D9| I|37:088297|00 (00)",
        "2023-02-05T19:33:34.510210": "...  I --- 10:029511 --:------ 10:029511 3EF0 009 0000104200FF032100 # 3EF0| I|10:029511",
        "2023-02-05T19:33:42.974593": "... RP --- 01:202227 18:066571 --:------ 0418 022 000000B0000000000000000000007FFFFF7000000000 # 0418|RP|01:202227|00 (00)",
        "2023-02-05T19:33:56.656770": "...  I --- 04:035120 --:------ 04:035120 30C9 003 00081E # 30C9| I|04:035120",
        "2023-02-05T19:34:11.959474": "... RP --- 01:202227 18:066571 --:------ 2349 007 0905DC00FFFFFF # 2349|RP|01:202227|09 (09)",
        "2023-02-05T19:34:15.958589": "... RP --- 01:202227 18:066571 --:------ 0004 022 09004565746B616D6572000000000000000000000000 # 0004|RP|01:202227|09 (09)",
        "2023-02-05T19:34:38.714616": "...  I 251 37:088301 --:------ 37:088301 31D9 017 0006280020202020202020202020202000 # 31D9| I|37:088301|00 (00)",
        "2023-02-05T19:34:39.129424": "... RP --- 01:202227 18:066571 --:------ 2349 007 0505DC00FFFFFF # 2349|RP|01:202227|05 (05)",
        "2023-02-05T19:34:42.089023": "... RP --- 01:202227 18:066571 --:------ 2349 007 04073A00FFFFFF # 2349|RP|01:202227|04 (04)",
        "2023-02-05T19:34:42.555735": "... RP --- 01:202227 18:066571 --:------ 2349 007 02064000FFFFFF # 2349|RP|01:202227|02 (02)",
        "2023-02-05T19:34:42.954721": "... RP --- 01:202227 18:066571 --:------ 2349 007 0605DC00FFFFFF # 2349|RP|01:202227|06 (06)",
        "2023-02-05T19:34:44.726590": "... RP --- 10:029511 18:066571 --:------ 3220 005 00C0000300 # 3220|RP|10:029511|00 (00)",
        "2023-02-05T19:34:44.854631": "... RP --- 10:029511 18:066571 --:------ 12F0 003 007FFF # 12F0|RP|10:029511",
        "2023-02-05T19:34:45.063619": "... RP --- 10:029511 18:066571 --:------ 1260 003 007FFF # 1260|RP|10:029511",
        "2023-02-05T19:34:45.252761": "... RP --- 01:202227 18:066571 --:------ 2349 007 0805DC00FFFFFF # 2349|RP|01:202227|08 (08)",
        "2023-02-05T19:34:45.598690": "... RP --- 01:202227 18:066571 --:------ 0006 004 0005000A # 0006|RP|01:202227",
        "2023-02-05T19:34:48.153602": "... RP --- 10:029511 18:066571 --:------ 1300 003 000096 # 1300|RP|10:029511",
        "2023-02-05T19:34:48.383457": "...  I --- 04:163537 --:------ 04:163537 30C9 003 000985 # 30C9| I|04:163537",
        "2023-02-05T19:34:51.224427": "... RP --- 01:202227 18:066571 --:------ 2349 013 00057804FFFFFF2C11060207E7 # 2349|RP|01:202227|00 (00)",
        "2023-02-05T19:34:51.392147": "... RP --- 01:202227 18:066571 --:------ 2349 007 0306A400FFFFFF # 2349|RP|01:202227|03 (03)",
        "2023-02-05T19:35:07.854552": "...  I --- 01:202227 --:------ 01:202227 1F09 003 FF07E4 # 1F09| I|01:202227",
        "2023-02-05T19:35:07.905936": "...  I --- 01:202227 --:------ 01:202227 000A 012 081001F40DAC091001F40DAC # 000A| I|01:202227 (True)",
        "2023-02-05T19:35:12.595955": "... RP --- 01:202227 18:066571 --:------ 2349 013 0704B004FFFFFF2C11060207E7 # 2349|RP|01:202227|07 (07)",
        "2023-02-05T19:35:29.799195": "...  I --- 10:029511 --:------ 10:029511 1FD4 003 000D6E # 1FD4| I|10:029511",
        "2023-02-05T19:36:00.545885": "...  I --- 04:038517 --:------ 01:202227 12B0 003 060000 # 12B0| I|04:038517|06 (06)",
        "2023-02-05T19:36:18.774270": "...  I --- 04:038517 --:------ 04:038517 30C9 003 0005E0 # 30C9| I|04:038517",
        "2023-02-05T19:36:20.811406": "...  I --- --:------ --:------ 20:004772 31D9 003 0000C8 # 31D9| I|20:004772|00 (00)",
        "2023-02-05T19:36:21.228123": "... RP --- 10:029511 18:066571 --:------ 3210 003 001084 # 3210|RP|10:029511",
        "2023-02-05T19:36:26.763448": "...  I --- 37:088301 --:------ 37:088301 31DA 030 00EF007FFF3FEF7FFF7FFF7FFF7FFFF800EF1828000000EFEF7FFF7FFF00 # 31DA| I|37:088301",
        "2023-02-05T19:36:37.681710": "... RP --- 01:202227 18:066571 --:------ 12B0 003 090000 # 12B0|RP|01:202227|09 (09)",
        "2023-02-05T19:36:37.944673": "...  I --- 04:044875 --:------ 04:044875 30C9 003 000694 # 30C9| I|04:044875",
        "2023-02-05T19:36:57.992837": "... RP --- 01:202227 18:066571 --:------ 2349 007 0107D000FFFFFF # 2349|RP|01:202227|01 (01)",
        "2023-02-05T19:37:01.098843": "...  I --- 34:245645 --:------ 34:245645 30C9 003 0006F4 # 30C9| I|34:245645",
        "2023-02-05T19:37:12.735710": "...  I --- 04:035122 --:------ 04:035122 30C9 003 0005E5 # 30C9| I|04:035122",
        "2023-02-05T19:37:17.039053": "...  I --- --:------ --:------ 20:001676 31D9 003 000001 # 31D9| I|20:001676|00 (00)",
        "2023-02-05T19:37:18.806453": "... RQ --- 01:202227 10:029511 --:------ 22D9 001 00 # 22D9|RQ|01:202227",
        "2023-02-05T19:37:18.830276": "... RP --- 10:029511 01:202227 --:------ 22D9 003 000D20 # 22D9|RP|10:029511",
        "2023-02-05T19:37:19.092937": "... RQ --- 01:202227 10:029511 --:------ 3220 005 0000050000 # 3220|RQ|01:202227|05 (05)",
        "2023-02-05T19:37:19.094246": "... RP --- 10:029511 01:202227 --:------ 3220 005 00C00500FF # 3220|RP|10:029511|05 (05)",
        "2023-02-05T19:37:19.256258": "... RQ --- 01:202227 10:029511 --:------ 3220 005 0000110000 # 3220|RQ|01:202227|11 (11)",
        "2023-02-05T19:37:19.257920": "... RP --- 10:029511 01:202227 --:------ 3220 005 00C0110000 # 3220|RP|10:029511|11 (11)",
        "2023-02-05T19:37:19.436781": "... RQ --- 01:202227 10:029511 --:------ 3220 005 0000120000 # 3220|RQ|01:202227|12 (12)",
        "2023-02-05T19:37:19.439250": "... RP --- 10:029511 01:202227 --:------ 3220 005 00C0120180 # 3220|RP|10:029511|12 (12)",
        "2023-02-05T19:37:19.646364": "... RQ --- 01:202227 10:029511 --:------ 3220 005 0080130000 # 3220|RQ|01:202227|13 (13)",
        "2023-02-05T19:37:19.649236": "... RP --- 10:029511 01:202227 --:------ 3220 005 00C01347AB # 3220|RP|10:029511|13 (13)",
        "2023-02-05T19:37:20.679673": "... RQ --- 01:202227 10:029511 --:------ 3220 005 0080190000 # 3220|RQ|01:202227|19 (19)",
        "2023-02-05T19:37:20.682830": "... RP --- 10:029511 01:202227 --:------ 3220 005 0040192A4A # 3220|RP|10:029511|19 (19)",
        "2023-02-05T19:37:20.685805": "... RQ --- 01:202227 10:029511 --:------ 3220 005 00801A0000 # 3220|RQ|01:202227|1A (1A)",
        "2023-02-05T19:37:20.687741": "... RP --- 10:029511 01:202227 --:------ 3220 005 00C01A47AB # 3220|RP|10:029511|1A (1A)",
        "2023-02-05T19:37:20.689364": "... RQ --- 01:202227 10:029511 --:------ 3220 005 00801C0000 # 3220|RQ|01:202227|1C (1C)",
        "2023-02-05T19:37:20.690852": "... RP --- 10:029511 01:202227 --:------ 3220 005 00401C2A4A # 3220|RP|10:029511|1C (1C)",
        "2023-02-05T19:37:20.692445": "... RQ --- 01:202227 10:029511 --:------ 3220 005 0080730000 # 3220|RQ|01:202227|73 (73)",
        "2023-02-05T19:37:20.693939": "... RP --- 10:029511 01:202227 --:------ 3220 005 00B0730000 # 3220|RP|10:029511|73 (73)",
        "2023-02-05T19:37:22.717440": "... RP --- 10:029511 18:066571 --:------ 1290 003 007FFF # 1290|RP|10:029511",
        "2023-02-05T19:37:23.672846": "... RQ --- 01:202227 10:029511 --:------ 3EF0 001 00 # 3EF0|RQ|01:202227",
        "2023-02-05T19:37:23.676019": "... RP --- 10:029511 01:202227 --:------ 3EF0 009 0000104200FF032100 # 3EF0|RP|10:029511",
        "2023-02-05T19:37:24.095773": "... RP --- 01:202227 18:066571 --:------ 2E04 008 00FFFFFFFFFFFF00 # 2E04|RP|01:202227",
        "2023-02-05T19:37:25.372579": "...  I --- 04:038523 --:------ 04:038523 30C9 003 0006A4 # 30C9| I|04:038523",
        "2023-02-05T19:37:27.871774": "...  I --- 01:202227 --:------ 01:202227 0008 002 FC00 # 0008| I|01:202227|FC (FC)",
        "2023-02-05T19:37:27.903500": "...  I --- 10:029511 --:------ 01:202227 3150 002 FC00 # 3150| I|10:029511|FC (FC)",
        "2023-02-05T19:37:37.770493": "... RP --- 10:029511 18:066571 --:------ 2401 004 00000944 # 2401|RP|10:029511",
        "2023-02-05T19:37:38.274511": "...  I --- 04:038521 --:------ 04:038521 30C9 003 0006D1 # 30C9| I|04:038521",
        "2023-02-05T19:37:47.081623": "...  I --- 04:163537 --:------ 01:202227 12B0 003 090000 # 12B0| I|04:163537|09 (09)"
    "remotes": {}
It looks like a FAN to me. Generally:
  • fans: 31D9, 31DA
  • remotes: 22F1, 22F3
Or, try running ramses_cc with eavesdropping on, and it will try to work out the device types for you.
Well, all the # need to be gone, for a start.
Please start by providing a packet log (rather than a copy of the cache).
Sorry, i know that.
It was commented out and only enabled while testing. I suppose I should have posted an uncommented version to the forum in this case. Let’s start again. With this section added to the configuration I don’t see any log entries for dispatcher.
logger:
  default: warn
  logs:
Probably.
This is what I am using:
logger:
  default: warning
  logs:
    asyncio: error
    zeroconf: warning
    homeassistant.core: debug  # for 'Event call_service'
    custom_components.ramses_cc:               info     # info for state messages
    custom_components.ramses_cc.binary_sensor: warning  # info for 'Found a ...'
    custom_components.ramses_cc.climate:       warning
    custom_components.ramses_cc.climate_heat:  warning
    custom_components.ramses_cc.climate_hvac:  info
    custom_components.ramses_cc.remote:        info
    custom_components.ramses_cc.sensor:        warning
    custom_components.ramses_cc.water_heater:  warning
    ramses_rf.dispatcher: info                          # messages   Tx/Rx at app layer - usu. the logging you want (no RQs for readability)
    # ramses_rf.protocol.protocol: info                 # packets    Tx/Rx at upper (serial) layer (SENT/rcvd)
    # ramses_rf.protocol.transport: info                # raw frames Tx/Rx at lower (RF) layer (incl. RSSI)
Thx! It works!
@zxdavb I am very interested in this to see which circuit / zone is calling for heat.
I have only recently discovered ramses_cc and am very impressed with what you have achieved.
I will gather some packet logs. Which config files do you need?
I think you’re right about the corrupt install, and I’ve reinstalled it a couple of times but no change. I see in the logs that it’s missing hardware.py, cast.py etc. , Screenshot 2023-02-07 at 08.34.55
I suspect I’m not installing it properly, but no idea why. I appreciate diagnosing possible user error is difficult. All help appreciated. Thx
Are you installing via HACS?
What is this packet telling me with the 63?
2023-02-07T16:24:54.221200 000 I — 18:004892 63:262142 --:------ 7FFF 016 001001862CB1C7FF76302E32312E3430
yes - using HACS to install. I’m doing nothing different to other things, but for some reason it’s not playing ball
A copy of your packet log - preferably one that includes a restart of HA (in the early am, even better if just past midnight), then the rest of the day (including times where the UFH was heating).
ramses_cc does not include any of those files (e.g. logbook.py).
I would remove it altogether from HACS, and start again.
The 7FFF packets are meta-packets generated by ramses_rf - they are not part of the RAMSES II protocol. I call them ‘puzzle’ packets for historical reasons.
The above, decoded is:
16:24:54.221 || HGI:004892 |  63:262142 |  I | puzzle_packet    |      || {'datetime': '2023-02-08T03:24:54.015', 'engine': 'v0.21.40', 'parser': 'v0.22.2'}
This one is simply to document, in the packet log, which version of ramses_rf was used to create (and decode) the packet log (I uses v0.22.2 to decode it).
I’ve redone the HACS install before and will happily do it again. Does installing ramses_cc in HACS also install the ramses_rf client library, or does that need to be done separately? Thank you
@zxdavb : I found a 2d hand round thermostat and RFG100 gateway. Installed and integrated directly with Home Assistant. I installed the card Simple Thermostat. Big thanks for your support !!
Extra question: is it possible Home Assistant to be notified when heating is activated/deactivated by BRD91 ?
