Honeywell CH/DHW via RF - evohome, sundial, hometronics, chronotherm
I’ve pull the latest, I’m using a nanoCUL running evofw3.
I dont remember where the detailed release info for evofw3 is logged though :frowning:
packetlog en-route.
There is a new version of evofw3 at https://github.com/ghoti57/evofw3 - please use the master branch.
hi, i’m quite new here and it seems that I cannot send a PM to you or I don’t know how to do that
Click on my Avatar, then click on Message - I think I fixed the specific problem you were reporting…
There are a bunch of missing features: they will come!
In the meantime, the official integration - which is based upon the vendor’s RESTful API - is pretty good: I think it does everything that can be done via that API (actually, this is not strictly true - I have since found some new, undocumented, system modes).
Hi David, loving some of the recent changes like picking zone names up etc. thanks for this great work!
How do I determine if the system is calling for heat at all right now, I’m sorry if I’m missing something really obvious but I’m not seeing / finding my BDR91 (heating and DHW relays) or equivalent(s).
temperature property is still showing null
Dear All,
Please make sure you pull the latest commit of evohome_cc - the manifest.json file will have
evohome-rf==0.2.2
Then let me know if you still have problems - my big issue current is dropped packets, as the QoS code is buggy - if anyone has experience with / can write a async protocol/tramsport wrapper for a serial device, I’d be grateful (I’ve got a lot of demands on my time, presently)…
(answering my own question: I think I got it)
I found two binary sensors (search “actuator”) they seem to represent my DHW relay and CH relay actuators and the data looks relevant so far:
Pulled latest yesterday (approc 17:28 I think) but stopped getting data after 2200 last night :frowning:
I will send packet.log shortly.
I only noticed after I had upgraded hass to 0.115.3 so had a restart of homeassistant get the following again which I assume is due to pulling a new homeassistant image:
2020-09-27 13:34:16 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-09-27 13:34:16 ERROR (MainThread) [homeassistant.loader] Error loading custom_components.evohome_cc. Make sure all dependencies are installed
  File "/usr/src/homeassistant/homeassistant/loader.py", line 516, in _load_file
    module = importlib.import_module(path)
  File "/usr/local/lib/python3.8/importlib/__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
  File "<frozen importlib._bootstrap>", line 991, in _find_and_load
  File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 783, in exec_module
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "/config/custom_components/evohome_cc/__init__.py", line 10, in <module>
    import evohome
ModuleNotFoundError: No module named 'evohome'
so, within homeassistant container:
bash-5.0# pip list | grep evo
aioazuredevops                   1.3.5
devolo-home-control-api          0.13.0
evohome-async                    0.3.5.post1
bash-5.0# cat custom_components/evohome_cc/manifest.json
  "domain": "evohome_rf",
  "name": "Honeywell evohome (RAMSES II protocol) agent",
  "documentation": "https://github.com/zxdavb/evohome_cc",
  "requirements": [
    "evohome-rf==0.2.2", "pyserial-asyncio==0.4"
  "dependencies": [],
  "codeowners": ["@zxdavb"]
bash-5.0#
Reinstalled evohome-rf and reloaded homeassistant and seems to to be happy again
2020-09-26T22:12:09.209153 # A9.6A.A9.A6.56.62.
2020-09-26T22:12:12.266454 094  I --- 04:191062 --:------ 01:138490 ???? ??? * Invalid Manchester Code
2020-09-26T22:12:12.267329 # A9.6A.A9.A6.56.66.99.96.AA.96.A9.5A.55.66.A5.A9.99.2A.
2020-09-26T22:12:45.514852 058  I --- 01:138490 --:------ 01:138490 1F09 003 FF05B9
2020-09-26T22:12:45.541932 058  I --- 01:138490 --:------ 01:138490 2309 027 0001F401044C0201F40305DC04076C0501F40603E80702BC0801F4
2020-09-26T22:12:45.566804 058  I --- 01:138490 --:------ 01:138490 30C9 027 00084F01069B02070403076E04072305050906071707066B080780
2020-09-26T22:12:55.775052 064  I --- 04:190960 --:------ 01:138490 3150 002 0300
2020-09-26T22:13:27.695409 054  I --- 13:169230 --:------ 13:169230 3EF0 003 0000FF
2020-09-26T22:13:32.550226 058  I --- 01:138490 --:------ 01:138490 3B00 002 FCC8
2020-09-26T22:13:32.687578 055  I --- 13:169230 --:------ 13:169230 3EF0 003 0000FF
2020-09-26T22:13:32.751459 047  I --- 13:079800 --:------ 13:079800 3EF0 003 0000FF
2020-09-26T22:14:19.968120 082  I --- 04:021457 --:------ 01:138490 3150 002 0200
2020-09-26T22:15:12.001838 059  I --- 01:138490 --:------ 01:138490 1F09 003 FF05B9
2020-09-26T22:15:12.066949 058  I --- 01:138490 --:------ 01:138490 000A 048 001001F40A8C011001F40DAC021001F409C4031001F40DAC041001F409C4051201F40A28061203E80898071001F40960
2020-09-26T22:15:12.079111 058  I --- 01:138490 --:------ 01:138490 000A 006 081001F40A8C
2020-09-26T22:15:25.011377 073  I --- 04:191058 --:------ 04:191058 30C9 003 00082F
2020-09-26T22:16:12.343866 071  I --- 04:190958 --:------ 01:138490 3150 002 0600
2020-09-26T22:16:16.404173 045  I --- 04:048656 --:------ 04:048656 30C9 003 000777
2020-09-26T22:17:38.501163 058  I --- 01:138490 --:------ 01:138490 1F09 003 FF05B9
2020-09-26T22:17:38.542099 058  I --- 01:138490 --:------ 01:138490 2309 027 0001F401044C0201F40305DC04076C0501F40603E80702BC0801F4
2020-09-26T22:17:38.565070 058  I --- 01:138490 --:------ 01:138490 30C9 027 00084F01069B02070403076E04072305050906071707066B080777
2020-09-26T22:19:31.608297 ...  W --- 18:000730 01:138490 --:------ 2349 007 067FFF00FFFFFF
2020-09-26T22:19:34.186059 ...  W --- 18:000730 01:138490 --:------ 2349 007 027FFF00FFFFFF
2020-09-26T22:19:36.796549 ...  W --- 18:000730 01:138490 --:------ 2349 007 027FFF00FFFFFF
2020-09-26T22:19:49.569331 ...  W --- 18:000730 01:138490 --:------ 2349 007 0209C402FFFFFF
2020-09-27T14:09:56.918806 # evofw3 0.4.2
2020-09-27T14:09:57.222657 000 RQ --- 18:056026 01:138490 --:------ 1FC9 001 00
2020-09-27T14:09:57.557903 059 RP --- 01:138490 18:056026 --:------ 1FC9 012 0010E0061CFA001FC9061CFA
2020-09-27T14:09:57.908020 000 RQ --- 18:056026 01:138490 --:------ 10E0 001 00
2020-09-27T14:09:57.992806 058 RP --- 01:138490 18:056026 --:------ 10E0 038 000002FF0163FFFFFFFF140B07E1010807DD45766F20436F6C6F720000000000000000000000
2020-09-27T14:09:58.224247 000 RQ --- 18:056026 01:138490 --:------ 000C 002 000F
2020-09-27T14:09:58.291133 058 RP --- 01:138490 18:056026 --:------ 000C 006 000F7FFFFFFF
2020-09-27T14:09:58.337181 000 RQ --- 18:056026 01:138490 --:------ 000C 002 000D
2020-09-27T14:09:58.440175 059 RP --- 01:138490 18:056026 --:------ 000C 006 000D001C8945
2020-09-27T14:09:58.506605 000 RQ --- 18:056026 01:138490 --:------ 0005 002 0008
2020-09-27T14:09:59.233956 000 RQ --- 18:056026 01:138490 --:------ 0005 002 0009
2020-09-27T14:09:59.314229 058 RP --- 01:138490 18:056026 --:------ 0005 004 00090000
2020-09-27T14:09:59.367903 000 RQ --- 18:056026 01:138490 --:------ 0005 002 000A
2020-09-27T14:09:59.383809 058 RP --- 01:138490 18:056026 --:------ 0005 004 000A0000
2020-09-27T14:09:59.463717 000 RQ --- 18:056026 01:138490 --:------ 0005 002 000B
2020-09-27T14:09:59.547220 058 RP --- 01:138490 18:056026 --:------ 0005 004 000B0000
2020-09-27T14:09:59.564288 000 RQ --- 18:056026 01:138490 --:------ 0005 002 0011
2020-09-27T14:09:59.593086 000 RQ --- 18:056026 01:138490 --:------ 1F09 001 00
2020-09-27T14:09:59.658113 059 RP --- 01:138490 18:056026 --:------ 1F09 003 000573
I wonder why it all stopped last night?
There is a bug, most noticeable with the relays (HA binary sensors) - will drop an update tonight.
This is caused by buggy code deep down in the library that speaks with the USB-to-RF device. This code is also the reason for dropped packets (more correctly for not detecting / re-transmitting dropped packets).
I know of one bug, and the rest of it is a mess…
This whole thing needs a complete refactor. I guess I need to focus on it for a while…
There is a ton of functionality yet to be added to HA - was working on (fixing) relay state & (adding) relay demand just now.
Thanks for following up, I’ll knock something up to detect when I stop getting data so I can restart in the mean time.
Let us know when later code needs testing (I pulled from repo yesterday afty and it was broken so I reverted, still on 0.2.2)
I’m sorry I can’t help with the driver bit though :frowning:
hi Guys,
i would like to join the party and assist the development with log files. however i am a complete noob regarding programming and linux. so the only way i can assist is by log files and instruction testing.
but unfortunatly i can’t get this component working. can somebody give me a hint?
i have a raspberry pi4 (dedicated for this project) and HGI80. on the raspberry i installed raspberry pi os. next i followed the instructions in post 208, then i installed home assistant in a docker container via this script
error log of home assistant gives me:
Logger: homeassistant.loader
Source: custom_components/evohome_cc/init.py:10
First occurred: 9:35:57 PM (1 occurrences)
Last logged: 9:35:57 PM
File “/usr/src/homeassistant/homeassistant/loader.py”, line 516, in _load_file
File “/usr/local/lib/python3.8/importlib/init.py”, line 127, in import_module
File “”, line 1014, in _gcd_import
File “”, line 991, in _find_and_load
File “”, line 975, in _find_and_load_unlocked
File “”, line 671, in _load_unlocked
File “”, line 783, in exec_module
File “”, line 219, in _call_with_frames_removed
File “/config/custom_components/evohome_cc/init.py”, line 10, in
import evohome
ModuleNotFoundError: No module named ‘evohome’
pip doesn’t work, but pip3 does:
pi@raspberrypi:~ $ pip3 list | grep evohome
evohome-rf 0.2.3
my manifest:
pi@raspberrypi:/usr/share/hassio/homeassistant/custom_components/evohome_cc $ cat manifest.json
“domain”: “evohome_rf”,
“name”: “Honeywell evohome (RAMSES II protocol) agent”,
“documentation”: “https://github.com/zxdavb/evohome_cc”,
“requirements”: [
“evohome-rf==0.2.3”, “pyserial-asyncio==0.4”
“dependencies”: [],
“codeowners”: ["@zxdavb"]
This is looking good - just not loading the client - other people seem to have discovered that it will load if you restart a couple of times.
evohome_cc was working fine but after the recent update of Home Assistant the evohome_cc custom component seems to be not loading:
2020-09-29 22:29:02 ERROR (MainThread) [homeassistant.loader] Error loading custom_components.evohome_cc. Make sure all dependencies are installed
    import evohome
2020-09-29 22:29:02 ERROR (MainThread) [homeassistant.components.hassio] Component error: evohome_cc - Integration 'evohome_cc' not found.
my manifest:
  "requirements": [
    "evohome-rf==0.2.3", "pyserial-asyncio==0.4"
  "dependencies": [],
Tried restarting home assistant a few times, but getting same error message.
LM
It is there: https://pypi.org/project/evohome-rf/
I will make some change tomorrow that may improve the situation.
I’ve installed evohome_rf in the docker and it works fine again.
I just want to say thanks for all the hard work you’ve put into this project.
Everything is working really well for me apart from the DHW status which is shown as unknown.
Cheers
Just pulled 0.2.4
2020-10-03 13:18:56 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up evohome_cc platform for sensor
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 201, in _async_setup_platform
    await asyncio.gather(*pending)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 310, in async_add_entities
    await asyncio.gather(*tasks)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 481, in _async_add_entity
    await entity.add_to_platform_finish()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 522, in add_to_platform_finish
    self.async_write_ha_state()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 296, in async_write_ha_state
    self._async_write_ha_state()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 317, in _async_write_ha_state
    if not self.available:
  File "/config/custom_components/evohome_cc/__init__.py", line 245, in available
    return self._evo_device._is_present
AttributeError: 'TrvActuator' object has no attribute '_is_present'
2020-10-03 13:19:27 ERROR (MainThread) [homeassistant.components.ipp] Error fetching ipp data: Invalid response from API: Error occurred while communicating with IPP server.
2020-10-03 13:19:27 WARNING (MainThread) [homeassistant.config_entries] Config entry for ipp not ready yet. Retrying in 80 seconds
2020-10-03 13:19:56 WARNING (MainThread) [custom_components.evohome_cc] Schema = {'controller': '01:138490', 'system': {'heating_control': None, 'orphans': []}, 'stored_hotwater': None, 'ufh_controllers': {}, 'zones': {'00': {'heating_type': None, 'sensor': None, 'devices': []}, '01': {'heating_type': None, 'sensor': None, 'devices': []}, '02': {'heating_type': None, 'sensor': None, 'devices': []}, '03': {'heating_type': None, 'sensor': None, 'devices': []}, '04': {'heating_type': None, 'sensor': None, 'devices': []}, '05': {'heating_type': None, 'sensor': None, 'devices': []}, '06': {'heating_type': None, 'sensor': None, 'devices': []}, '07': {'heating_type': None, 'sensor': None, 'devices': []}, '08': {'heating_type': 'radiator_valve', 'sensor': None, 'devices': ['04:048656']}}, 'device_info': {}}
2020-10-03 13:19:56 WARNING (MainThread) [custom_components.evohome_cc] Params = {'system': {'mode': None, 'language': None, 'heating_control': {}}, 'stored_hotwater': None, 'zones': {'00': {'name': None, 'mode': None, 'zone_config': None}, '01': {'name': None, 'mode': None, 'zone_config': None}, '02': {'name': None, 'mode': None, 'zone_config': None}, '03': {'name': None, 'mode': None, 'zone_config': None}, '04': {'name': None, 'mode': None, 'zone_config': None}, '05': {'name': None, 'mode': None, 'zone_config': None}, '06': {'name': None, 'mode': None, 'zone_config': None}, '07': {'name': None, 'mode': None, 'zone_config': None}, '08': {'name': None, 'mode': None, 'zone_config': None}}}
2020-10-03 13:19:56 WARNING (MainThread) [custom_components.evohome_cc] Status = {'system': {'datetime': None}, 'stored_hotwater': None, 'zones': {'00': {'setpoint': None, 'temperature': None}, '01': {'setpoint': None, 'temperature': None}, '02': {'setpoint': None, 'temperature': None}, '03': {'setpoint': None, 'temperature': None}, '04': {'setpoint': None, 'temperature': None}, '05': {'setpoint': None, 'temperature': None}, '06': {'setpoint': None, 'temperature': None}, '07': {'setpoint': None, 'temperature': None}, '08': {'setpoint': None, 'temperature': None, 'heat_demand': None, 'open_window': None}}, 'devices': {'04:048656': {'temperature': None, 'setpoint': None, 'heat_demand': None, 'battery_state': {}, 'window_state': False}}}
2020-10-03 13:19:56 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 283, in async_update_ha_state
2020-10-03 13:19:56 INFO (MainThread) [homeassistant.components.climate] Setting up climate.evohome_cc
2020-10-03 13:19:56 WARNING (MainThread) [custom_components.evohome_cc.climate] Found a Zone (None), id=00, name=None
2020-10-03 13:19:56 WARNING (MainThread) [custom_components.evohome_cc.climate] Found a Zone (None), id=01, name=None
2020-10-03 13:19:56 WARNING (MainThread) [custom_components.evohome_cc.climate] Found a Zone (None), id=02, name=None
2020-10-03 13:19:56 WARNING (MainThread) [custom_components.evohome_cc.climate] Found a Zone (None), id=03, name=None
2020-10-03 13:19:56 WARNING (MainThread) [custom_components.evohome_cc.climate] Found a Zone (None), id=04, name=None
2020-10-03 13:19:56 WARNING (MainThread) [custom_components.evohome_cc.climate] Found a Zone (None), id=05, name=None
2020-10-03 13:19:56 WARNING (MainThread) [custom_components.evohome_cc.climate] Found a Zone (None), id=06, name=None
2020-10-03 13:19:56 WARNING (MainThread) [custom_components.evohome_cc.climate] Found a Zone (None), id=07, name=None
2020-10-03 13:20:56 WARNING (MainThread) [custom_components.evohome_cc] Schema = {'controller': '01:138490', 'system': {'heating_control': None, 'orphans': []}, 'stored_hotwater': None, 'ufh_controllers': {}, 'zones': {'00': {'heating_type': None, 'sensor': None, 'devices': []}, '01': {'heating_type': None, 'sensor': None, 'devices': []}, '02': {'heating_type': None, 'sensor': None, 'devices': []}, '03': {'heating_type': None, 'sensor': None, 'devices': []}, '04': {'heating_type': None, 'sensor': None, 'devices': []}, '05': {'heating_type': None, 'sensor': None, 'devices': []}, '06': {'heating_type': None, 'sensor': None, 'devices': []}, '07': {'heating_type': None, 'sensor': None, 'devices': []}, '08': {'heating_type': 'radiator_valve', 'sensor': None, 'devices': ['04:048656']}}, 'device_info': {}}
2020-10-03 13:20:56 WARNING (MainThread) [custom_components.evohome_cc] Params = {'system': {'mode': None, 'language': None, 'heating_control': {}}, 'stored_hotwater': None, 'zones': {'00': {'name': None, 'mode': None, 'zone_config': None}, '01': {'name': None, 'mode': None, 'zone_config': None}, '02': {'name': None, 'mode': None, 'zone_config': None}, '03': {'name': None, 'mode': None, 'zone_config': None}, '04': {'name': None, 'mode': None, 'zone_config': None}, '05': {'name': None, 'mode': None, 'zone_config': None}, '06': {'name': None, 'mode': None, 'zone_config': None}, '07': {'name': None, 'mode': None, 'zone_config': None}, '08': {'name': None, 'mode': None, 'zone_config': None}}}
2020-10-03 13:20:56 WARNING (MainThread) [custom_components.evohome_cc] Status = {'system': {'datetime': None}, 'stored_hotwater': None, 'zones': {'00': {'setpoint': None, 'temperature': None}, '01': {'setpoint': None, 'temperature': None}, '02': {'setpoint': None, 'temperature': None}, '03': {'setpoint': None, 'temperature': None}, '04': {'setpoint': None, 'temperature': None}, '05': {'setpoint': None, 'temperature': None}, '06': {'setpoint': None, 'temperature': None}, '07': {'setpoint': None, 'temperature': None}, '08': {'setpoint': None, 'temperature': None, 'heat_demand': None, 'open_window': None}}, 'devices': {'04:048656': {'temperature': None, 'setpoint': None, 'heat_demand': None, 'battery_state': {}, 'window_state': False}}}
2020-10-03 13:20:56 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2020-10-03 13:21:56 WARNING (MainThread) [custom_components.evohome_cc] Schema = {'controller': '01:138490', 'system': {'heating_control': None, 'orphans': []}, 'stored_hotwater': None, 'ufh_controllers': {}, 'zones': {'00': {'heating_type': 'radiator_valve', 'sensor': None, 'devices': ['04:191054', '04:191058']}, '01': {'heating_type': None, 'sensor': None, 'devices': []}, '02': {'heating_type': None, 'sensor': None, 'devices': []}, '03': {'heating_type': None, 'sensor': None, 'devices': []}, '04': {'heating_type': None, 'sensor': None, 'devices': []}, '05': {'heating_type': None, 'sensor': None, 'devices': []}, '06': {'heating_type': 'radiator_valve', 'sensor': None, 'devices': ['04:190958']}, '07': {'heating_type': None, 'sensor': None, 'devices': []}, '08': {'heating_type': 'radiator_valve', 'sensor': None, 'devices': ['04:048656']}}, 'device_info': {}}
2020-10-03 13:21:56 WARNING (MainThread) [custom_components.evohome_cc] Params = {'system': {'mode': None, 'language': None, 'heating_control': {}}, 'stored_hotwater': None, 'zones': {'00': {'name': None, 'mode': None, 'zone_config': None}, '01': {'name': None, 'mode': None, 'zone_config': None}, '02': {'name': None, 'mode': None, 'zone_config': None}, '03': {'name': None, 'mode': None, 'zone_config': None}, '04': {'name': None, 'mode': None, 'zone_config': None}, '05': {'name': None, 'mode': None, 'zone_config': None}, '06': {'name': None, 'mode': None, 'zone_config': None}, '07': {'name': None, 'mode': None, 'zone_config': None}, '08': {'name': None, 'mode': None, 'zone_config': None}}}
2020-10-03 13:21:56 WARNING (MainThread) [custom_components.evohome_cc] Status = {'system': {'datetime': None}, 'stored_hotwater': None, 'zones': {'00': {'setpoint': None, 'temperature': None, 'heat_demand': 0.0, 'open_window': None}, '01': {'setpoint': None, 'temperature': None}, '02': {'setpoint': None, 'temperature': None}, '03': {'setpoint': None, 'temperature': None}, '04': {'setpoint': None, 'temperature': None}, '05': {'setpoint': None, 'temperature': None}, '06': {'setpoint': None, 'temperature': None, 'heat_demand': 0.0, 'open_window': None}, '07': {'setpoint': None, 'temperature': None}, '08': {'setpoint': None, 'temperature': None, 'heat_demand': None, 'open_window': None}}, 'devices': {'04:048656': {'temperature': None, 'setpoint': None, 'heat_demand': None, 'battery_state': {}, 'window_state': False}, '04:190958': {'temperature': None, 'setpoint': None, 'heat_demand': 0.0, 'battery_state': {}, 'window_state': None}, '04:191054': {'temperature': None, 'setpoint': None, 'heat_demand': 0.0, 'battery_state': {}, 'window_state': None}, '04:191058': {'temperature': None, 'setpoint': None, 'heat_demand': 0.0, 'battery_state': {}, 'window_state': None}}}
2020-10-03 13:21:56 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2020-10-03 13:21:56 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.evohome_cc
2020-10-03 13:21:56 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.evohome_cc
2020-10-03 13:21:56 WARNING (MainThread) [custom_components.evohome_cc.sensor] Found a Sensor (heat demand), id=04:190958, zone=01:138490_06 (RAD)
2020-10-03 13:21:56 WARNING (MainThread) [custom_components.evohome_cc.sensor] Found a Sensor (heat demand), id=04:191054, zone=01:138490_00 (RAD)
2020-10-03 13:21:56 WARNING (MainThread) [custom_components.evohome_cc.sensor] Found a Sensor (heat demand), id=04:191058, zone=01:138490_00 (RAD)
2020-10-03 13:21:56 WARNING (MainThread) [custom_components.evohome_cc.sensor] Found a Sensor (temp), id=04:190958, zone=01:138490_06 (RAD)
2020-10-03 13:21:56 WARNING (MainThread) [custom_components.evohome_cc.sensor] Found a Sensor (temp), id=04:191054, zone=01:138490_00 (RAD)
2020-10-03 13:21:56 WARNING (MainThread) [custom_components.evohome_cc.sensor] Found a Sensor (temp), id=04:191058, zone=01:138490_00 (RAD)
2020-10-03 13:21:56 WARNING (MainThread) [custom_components.evohome_cc.binary_sensor] Found a Binary Sensor (battery), id=04:190958, zone=01:138490_06 (RAD)
2020-10-03 13:21:56 WARNING (MainThread) [custom_components.evohome_cc.binary_sensor] Found a Binary Sensor (battery), id=04:191054, zone=01:138490_00 (RAD)
2020-10-03 13:21:56 WARNING (MainThread) [custom_components.evohome_cc.binary_sensor] Found a Binary Sensor (battery), id=04:191058, zone=01:138490_00 (RAD)
2020-10-03 13:21:56 WARNING (MainThread) [custom_components.evohome_cc.binary_sensor] Found a Binary Sensor (window), id=04:190958, zone=01:138490_06 (RAD)
2020-10-03 13:21:56 WARNING (MainThread) [custom_components.evohome_cc.binary_sensor] Found a Binary Sensor (window), id=04:191054, zone=01:138490_00 (RAD)
2020-10-03 13:21:56 WARNING (MainThread) [custom_components.evohome_cc.binary_sensor] Found a Binary Sensor (window), id=04:191058, zone=01:138490_00 (RAD)
2020-10-03 13:21:56 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up evohome_cc platform for sensor
2020-10-03 13:22:56 WARNING (MainThread) [custom_components.evohome_cc] Schema = {'controller': '01:138490', 'system': {'heating_control': None, 'orphans': []}, 'stored_hotwater': None, 'ufh_controllers': {}, 'zones': {'00': {'heating_type': 'radiator_valve', 'sensor': None, 'devices': ['04:191054', '04:191058']}, '01': {'heating_type': None, 'sensor': None, 'devices': []}, '02': {'heating_type': None, 'sensor': None, 'devices': []}, '03': {'heating_type': None, 'sensor': None, 'devices': []}, '04': {'heating_type': 'radiator_valve', 'sensor': '04:190962', 'devices': ['04:190962']}, '05': {'heating_type': None, 'sensor': None, 'devices': []}, '06': {'heating_type': 'radiator_valve', 'sensor': None, 'devices': ['04:190958']}, '07': {'heating_type': None, 'sensor': None, 'devices': []}, '08': {'heating_type': 'radiator_valve', 'sensor': None, 'devices': ['04:048656']}}, 'device_info': {}}
2020-10-03 13:22:56 WARNING (MainThread) [custom_components.evohome_cc] Params = {'system': {'mode': None, 'language': None, 'heating_control': {}}, 'stored_hotwater': None, 'zones': {'00': {'name': None, 'mode': None, 'zone_config': None}, '01': {'name': None, 'mode': None, 'zone_config': None}, '02': {'name': None, 'mode': None, 'zone_config': None}, '03': {'name': None, 'mode': None, 'zone_config': None}, '04': {'name': None, 'mode': None, 'zone_config': None}, '05': {'name': None, 'mode': None, 'zone_config': None}, '06': {'name': None, 'mode': None, 'zone_config': None}, '07': {'name': None, 'mode': None, 'zone_config': None}, '08': {'name': None, 'mode': None, 'zone_config': None}}}
2020-10-03 13:22:56 WARNING (MainThread) [custom_components.evohome_cc] Status = {'system': {'datetime': None}, 'stored_hotwater': None, 'zones': {'00': {'setpoint': None, 'temperature': None, 'heat_demand': 0.0, 'open_window': None}, '01': {'setpoint': None, 'temperature': None}, '02': {'setpoint': None, 'temperature': None}, '03': {'setpoint': None, 'temperature': None}, '04': {'setpoint': None, 'temperature': None, 'heat_demand': None, 'open_window': None}, '05': {'setpoint': None, 'temperature': None}, '06': {'setpoint': None, 'temperature': None, 'heat_demand': 0.0, 'open_window': None}, '07': {'setpoint': None, 'temperature': None}, '08': {'setpoint': None, 'temperature': None, 'heat_demand': None, 'open_window': None}}, 'devices': {'04:048656': {'temperature': None, 'setpoint': None, 'heat_demand': None, 'battery_state': {}, 'window_state': False}, '04:190958': {'temperature': None, 'setpoint': None, 'heat_demand': 0.0, 'battery_state': {}, 'window_state': None}, '04:190962': {'temperature': 17.13, 'setpoint': None, 'heat_demand': None, 'battery_state': {}, 'window_state': None}, '04:191054': {'temperature': None, 'setpoint': None, 'heat_demand': 0.0, 'battery_state': {}, 'window_state': None}, '04:191058': {'temperature': None, 'setpoint': None, 'heat_demand': 0.0, 'battery_state': {}, 'window_state': None}}}
2020-10-03 13:22:56 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2020-10-03 13:22:56 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.evohome_cc
2020-10-03 13:22:56 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.evohome_cc
2020-10-03 13:22:56 WARNING (MainThread) [custom_components.evohome_cc.sensor] Found a Sensor (heat demand), id=04:190962, zone=01:138490_04 (RAD)
2020-10-03 13:22:56 WARNING (MainThread) [custom_components.evohome_cc.sensor] Found a Sensor (temp), id=04:190962, zone=01:138490_04 (RAD)
2020-10-03 13:22:56 WARNING (MainThread) [custom_components.evohome_cc.binary_sensor] Found a Binary Sensor (battery), id=04:190962, zone=01:138490_04 (RAD)
2020-10-03 13:22:56 WARNING (MainThread) [custom_components.evohome_cc.binary_sensor] Found a Binary Sensor (window), id=04:190962, zone=01:138490_04 (RAD)
2020-10-03 13:22:56 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up evohome_cc platform for sensor
So v0.2.4 has just been pushed - this is a complete re-write of the engine that deals with the serial device, so much better now - faster, and QoS seems to be working now!
…and there is an error:
Answer: There seem to be a delay where HA is failing to install evohome_rf v0.2.4 when indicated to do so by evhome_cc v0.2.4 - you can manually install it:
pip install evohome_rf==0.2.4
if you know how to do that, or just restart HA a few times…
