Does anyone else have a Ideal combi boiler and opentherm running on it?
Well, thatās annoying. The only change made, was to tweak logging and restart:
2021-11-20 07:30:30 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.07_014869_temperature, old_state=<state sensor.07_014869_temperature=unavailable; restored=True, state_class=measurement, supported_features=0, device_class=temperature, unit_of_measurement=Ā°C, friendly_name=Stored Hot Water @ 2021-11-20T07:25:37.272702+00:00>, new_state=<state sensor.07_014869_temperature=67.9; state_class=measurement, controller_id=01:050858, device_id=07:014869, domain_id=FA, domain_name=Stored HW, unit_of_measurement=Ā°C, friendly_name=Stored Hot Water, device_class=temperature @ 2021-11-20T07:30:30.376748+00:00>>
Prior to that, over the course of about 7-10days since I upgraded from 0.14.x ā 0.16.x, HA was probably restarted 4-5 times in total (trying with restore_state: false) and it was missing every time. Typical!
I note some others further up this thread/topic mentioned that it comes and goes, this is the first time it has appeared for me on 0.16.x, so I guess we shall see - will leave the logging enabled for now.
There was an issue with an earlier buildā¦ was that it?
Went unavailable again, even though I can see the broadcast packets from the 07 device:
[core-ssh config]$ grep 014869 home-assistant.log|grep temp
2021-11-20 07:25:30 INFO (MainThread) [ramses_rf.message] || DHW:014869 | | I | dhw_temp | || {'temperature': 67.9}
2021-11-20 07:25:37 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.07_014869_temperature, old_state=None, new_state=<state sensor.07_014869_temperature=unavailable; restored=True, state_class=measurement, supported_features=0, device_class=temperature, unit_of_measurement=Ā°C, friendly_name=Stored Hot Water @ 2021-11-20T07:25:37.272702+00:00>>
2021-11-20 07:30:30 INFO (MainThread) [custom_components.evohome_cc.sensor] Found a Sensor (temperature), id=07:014869
2021-11-20 08:30:31 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.07_014869_temperature, old_state=<state sensor.07_014869_temperature=67.9; state_class=measurement, controller_id=01:050858, device_id=07:014869, domain_id=FA, domain_name=Stored HW, unit_of_measurement=Ā°C, friendly_name=Stored Hot Water, device_class=temperature @ 2021-11-20T07:30:30.376748+00:00>, new_state=<state sensor.07_014869_temperature=unavailable; state_class=measurement, unit_of_measurement=Ā°C, friendly_name=Stored Hot Water, device_class=temperature @ 2021-11-20T08:30:31.318806+00:00>>
2021-11-20 09:05:48 INFO (MainThread) [ramses_rf.message] || DHW:014869 | | I | dhw_temp | || {'temperature': 66.86}
2021-11-20 09:10:03 INFO (MainThread) [ramses_rf.message] || DHW:014869 | | I | dhw_temp | || {'temperature': 65.82}
2021-11-20 09:10:48 INFO (MainThread) [ramses_rf.message] || DHW:014869 | | I | dhw_temp | || {'temperature': 64.59}
2021-11-20 09:11:18 INFO (MainThread) [ramses_rf.message] || DHW:014869 | | I | dhw_temp | || {'temperature': 61.94}
2021-11-20 09:12:18 INFO (MainThread) [ramses_rf.message] || DHW:014869 | | I | dhw_temp | || {'temperature': 51.87}
2021-11-20 09:13:48 INFO (MainThread) [ramses_rf.message] || DHW:014869 | | I | dhw_temp | || {'temperature': 40.59}
I have some things to do this morning, will package up the logs and get them over later on/tomorrow.
Iām seeing the same with the latest build
For those with unavailable
sensors, please us this logging your configuration.yaml:
logger:
default: warn
logs:
homeassistant.core: debug
# custom_components.evohome_cc: info
custom_components.evohome_cc.sensor: info
ramses_rf.message: info
ramses_rf.protocol.message: info
You need to restart, and run for an hour - then provide me the HA log, and the corresponding packet.log.
I am still trying to work out whatās going onā¦
Have sent you an email.
I donāt get it, for months it works ok but at the moment there is nothing happening anymore. I dont see any climate or sensors entities anymore.
Logging gave this back:
2021-11-21 11:12:19 INFO (MainThread) [custom_components.evohome_cc] Params = {'system': {'tpi_params': None, 'system_mode': None, 'language': None}, 'stored_hotwater': {}, 'underfloor_heating': {}, 'zones': {}}
2021-11-21 11:12:19 INFO (MainThread) [custom_components.evohome_cc] Status = {'system': {'heat_demand': None, 'heat_demands': None, 'relay_demands': None, 'relay_failsafes': None}, 'faultlog': None, 'stored_hotwater': {}, 'underfloor_heating': {}, 'zones': {}, 'schedule_outdated': True}
It looks like he dont get any info anymore.
Are you using a HGI80?
Yes i use a HGI80 (I have a opentherm system)
Yes i use a HGI80
It looks like your duty cycle is blown - the HGI80 will no longer transmit until it resets itself, or it is reset (disconnected from / reconnected to USB).
ramses_rf is pretty pushy - that is why the cache is so important - without it, it sends lots of packets in a short time, and multiple back-to-back restarts of HA can exceed the limit imposed by the HGI80.
If youāre using a Honeywell HGI80, donāt do multiple-back-to-back restart of HA with
All, I am only interested if a sensor is permanently unavailable not temporarily / infrequently unavailable.
Your system is misconfigured (below is slightly edited for readability):
(venv) dbonnes@vm-builder ~/c/ramses_rf (master)> cat .secrets/lloyda/2021-11-21.log | grep 'RP.* 000C ... 0[03]' | tail -2 | python client.py -ns parse
08:54:42.127 || CTL:185426 | HGI:136212 | RP | zone_devices | 0008 || {'zone_idx': '00', '_device_class': '08', 'device_class': 'rad_actuators', 'devices': ['04:003278', '04:003222', '04:003192']}
08:54:43.957 || CTL:185426 | HGI:136212 | RP | zone_devices | 0308 || {'zone_idx': '03', '_device_class': '08', 'device_class': 'rad_actuators', 'devices': ['04:003286', '04:003192']}
TRV 04:003192
is an actuator in two different zones.
You will have to destroy & re-create the zone that shouldnāt have that TRV in it.
The nature of evohome is that it is very easy to have a misconfigured system.
If I notice an error in your system configuration, that does not necessarily mean the rest of it is fine. It is up to you to check
A big hint would be something like this in your log files:
Inconsistent state: 04:003192 (TRV) changed parent: 01:185426_00 (radiator_valve) to 01:185426_03 (radiator_valve), (try restarting the client library)
When my system is back in service i will send you a log. I misread your message. I use a arduino nano for evofw.
Can all those with issues upgrade to 0.16.12 and weāll try to sort these issues out using that versionā¦
For unavailable
sensors, I am only interested if sensors are permanently unavailable, and Iām not concerned if theyāre unavailable at times (the RF protocol has no QoS).
I am interested in all zone issues.
You need to use this logging:
logger:
default: warn
logs:
I need a fresh restart of HA that runs for at least an hour. I need the HA log, the packet log(s), and your configuration of evohome_cc
in configuration.yaml.
To be clear, the HA log, and the corresponding packet log must include the restart of HA.
You must have restore_state: false
if you have changed your evohomeās configuration (added/removed a zone, added/removed/moved a device).
Please PM with the above, and a clear description of what is going wrong. Please donāt say: āIām having the same problems as everyone elseā, or āIāve got unavailable sensorsā - your message will be ignored, sorry.
The better job you do of the above, the more likely it will be that it is your system Iāll look at first.
Thanks. Yes spotted that this morning and deleted both zones. Not setting restore_state to false caught me out at first, but now sorted.
This version has fixed all my errors and warnings.
Thanks for the hard work.
I need a fresh restart of HA that runs for at least an hour. I need the HA log, the packet log, and your configuration of
evohome_cc
Someone has kindly sent me a packet log that does not satisfy the above criteria.
Can all those with issues upgrade to 0.16.11 and weāll try to sort these issues out using that versionā¦
Please now use 0.16.12 - it has increased logging that will highlight those with poor reception.
In your logs you may see:
WARNING ... [ramses_rf.protocol.transport] ... QoS: IS_EXPIRED (giving up) ...
WARNING ... [ramses_rf.entities] ... Sending now deprecated for 01:000730 ...
