zxdavb
(David Bonnes)
November 18, 2021, 7:41pm
1848
No, The schema is simply invalid.
Did the following error message not appear in your HA log?:
Inconsistent state: 04:055510 (TRV) changed parent: 01:050858_02 (radiator_valve) to 01:050858_03 (radiator_valve), (try restarting the client library)
… I guess I can change the message:
Inconsistent schema: 04:055510 (TRV) changed parent...
Looking at your schema, I can see why there may be confusion:
devices:
- '04:055480'
devices
means sensors and/or actuators. 04:055480
is the sensor, but not one of the actuators.
It didn’t add the other actuator - it gave up instead.
Cinamon
November 18, 2021, 7:42pm
1849
With the latest version the integration don’t start anymore:
My config:
evohome_cc:
serial_port: /dev/ttyUSB-EVOHOME
scan_interval: 60
packet_log:
file_name: evohome_cc.log
rotate_bytes: null
rotate_backups: 3
restore_state: true
ramses_rf:
enforce_known_list: true
max_zones: 9
schema:
controller: 01:087939
system:
heating_control: 10:078099
known_list:
- 01:087939 # Controller
- 04:225661 # Badkamer
- 04:225663 # Slaapkamer Evi
- 02:017205 # Woonkamer
- 04:023992 # Kastenkamer
- 04:059569 # Slaapkamer
- 04:225657 # Toilet
- 04:024000 # Slaapkamer Nova
- 10:078099 # Heating control
- 18:073736 # Vloerverwarming (UFH)
log file:
2021-11-18T20:36:52.877459 # ramses_rf 0.16.7
zxdavb
(David Bonnes)
November 18, 2021, 7:45pm
1850
You’ll have to increase logging in HA & see what eventuates: Troubleshooting
Cinamon
November 18, 2021, 7:52pm
1851
Before the update there was no problem. I have now increase the logging.
zxdavb
(David Bonnes)
November 18, 2021, 7:53pm
1852
You can also downgrade via HACS.
zxdavb
(David Bonnes)
November 18, 2021, 8:32pm
1854
@iMiMx I’ve tweaked my code for you:
"02": {
"_name": "Utility",
"heating_type": "radiator_valve",
"sensor": "04:055510",
"devices": [
"04:055510"
"_sensor": "04:055510",
"_actuators": [
"04:055510"
"03": {
"_name": "Guest Bed",
"sensor": "04:055480",
"devices": [
"04:055480"
"_sensor": "04:055480",
"_actuators": [
"04:055510"
I will make a permanent change from "devices":
to "actuators":
in the future.
(_sensor
determines the sensor a different way to sensor
wim001
(Wim001)
November 19, 2021, 5:57am
1855
Hi I have a question ha works on virtalbox on Ubuntu must I also update python on Ubuntu or not ?
bishop
November 19, 2021, 7:57am
1856
I think you do not need to update python. In my case I was trying to run the code on a test machine which is different from my machine running HA. That’s why I had an out of date python version on it. If your machine is already running HA, it should have a fairly up to date version of python already (since it is necessary for HA) and so you should not have a problem.
zxdavb
(David Bonnes)
November 19, 2021, 10:45am
1857
@cinnamon How did you get on? Is it working now, or does the previous version start, but this one does not?
iMiMx
(iMx)
November 19, 2021, 1:51pm
1858
On the troubleshooting link… ‘s/evohome_rf/ramses_rf/g’
zxdavb
(David Bonnes)
November 19, 2021, 1:55pm
1859
The beauty of it is that it is a wiki!
iMiMx
(iMx)
November 19, 2021, 3:25pm
1860
Going back to the original issue, no sensor.07_014869_temperature data.
In the logs, I see the below:
2021-11-19 14:54:47 INFO (MainThread) [ramses_rf.message] || DHW:014869 | | I | dhw_temp | || {'temperature': 17.35}
I assume, hopefully correctly, that this is the hot water device broadcasting the temperature - and thus the nanoCUL can ‘hear’ the device.
And yet sensor.07_014869_temperature remains unavailable and has done since I upgraded from 0.14.x.
P.S. I deleted and recreated zone 03 and do not see any more Inconsistent State in the logs, much obliged.
zxdavb
(David Bonnes)
November 19, 2021, 4:35pm
1861
@iMiMx What do you see for the state graph? Mine is OK (below) - you’ll see it is updated at least every hour…
(don’t worry about the temps - it’s not connected to a real DHW cylinder)
iMiMx
(iMx)
November 19, 2021, 4:55pm
1862
Nada.
I see the broadcasts though:
[core-ssh config]$ grep DHW home-assistant.log
2021-11-19 14:02:58 INFO (MainThread) [custom_components.evohome_cc.water_heater] Found a DHW controller, id=01:050858_HW
2021-11-19 15:54:47 INFO (MainThread) [ramses_rf.message] || DHW:014869 | | I | dhw_temp | || {'temperature': 17.35}
2021-11-19 16:33:33 INFO (MainThread) [ramses_rf.message] || DHW:014869 | | I | dhw_temp | || {'temperature': 28.2}
2021-11-19 16:37:18 INFO (MainThread) [ramses_rf.message] || DHW:014869 | | I | dhw_temp | || {'temperature': 38.94}
2021-11-19 16:45:48 INFO (MainThread) [ramses_rf.message] || DHW:014869 | | I | dhw_temp | || {'temperature': 59.25}
2021-11-19 16:53:18 INFO (MainThread) [ramses_rf.message] || DHW:014869 | | I | dhw_temp | || {'temperature': 66.05}
I did restore_state: false already, after deleting/recreating the inconsistent state zone 03.
wim001
(Wim001)
November 19, 2021, 4:57pm
1863
Thanks for the answer
Regular are different things of line and sometimes it comes back and the temp of the zone goes high
Iamb running the latest Ramses RF
evoboff
(evoboff)
November 19, 2021, 5:06pm
1864
Grateful if anyone is able to help me out - since the recent set of upgrades I’m no longer able to see any of Opentherm heating control (10:124973) parameters, they all return as “Unavailable”.
Possibly related, I do not believe my UFH heating zones are correctly configured given the empty value in the schema (below). Do I need to add my HCE80 (02:001786) into my config file, if so in what format?
underfloor_heating: {}
extracted from:
system:
heating_control: '10:124973'
orphans: []
stored_hotwater: {}
zones:
'00':
_name: Living
heating_type: radiator_valve
sensor: null
devices:
- '04:254312'
'01':
_name: Small
sensor: '22:150839'
devices:
- '04:254306'
- '22:150839'
'02':
_name: Kitchen
heating_type: underfloor_heating
sensor: '34:175809'
devices:
- '34:175809'
'03':
_name: Main
sensor: '22:210057'
devices:
- '04:254288'
- '22:210057'
'04':
_name: Diner
sensor: '34:176169'
devices:
- '34:176169'
'05':
_name: Bedroom
sensor: '22:206071'
devices:
- '04:127635'
- '22:206071'
'06':
_name: Family
sensor: '34:098094'
devices:
- '04:173599'
- '34:098094'
'09':
_name: Guest
sensor: '22:022442'
devices:
- '04:173603'
- '22:022442'
Config file below:
# Evohome
evohome_cc:
serial_port: /dev/ttyACM0
packet_log: packet.log
# restore_state: false
ramses_rf:
schema:
controller: 01:081046
system:
heating_control: 10:124973
known_list:
- 01:081046
- 02:001786
- 04:254312
- 04:254306
- 04:254288
- 04:127635
- 04:173599
- 04:173603
- 10:124973
- 18:132629
- 22:150839
- 22:150839
- 22:210057
- 22:206071
- 22:022442
- 34:175809
- 34:176169
- 34:098094
zxdavb
(David Bonnes)
November 19, 2021, 7:20pm
1865
Do you have any of these messages in your HA logs:
2021-11-19 19:18:37 WARNING (MainThread) [ramses_rf.devices] RP --- 10:048122 18:006402 --:------ 3220 005 00C0121980 << OpenTherm: deprecating msg_id 0x12: it appears unsupported
Do you have any such sensors, not even one?
Please send me a packet log.
zxdavb
(David Bonnes)
November 19, 2021, 7:37pm
1866
This is a bug (actually, it just hasn’t been implemented) in ramses_rf .
In future, it may look like this:
'04':
_name: Diner
sensor: '34:176169'
actuators:
- '02:001786_05'
zxdavb
(David Bonnes)
November 19, 2021, 7:57pm
1867
@iMiMx Please send me a HA log, and your config, so I can get to the bottom of the missing sensor.
You will need this logging:
logger:
default: warn
logs:
homeassistant.core: debug # to see: Event state_changed, or not
ramses_rf.message: info # MSGs rcvd (excl. RQ/18:), is the one you usually want
I will need the contemporaneous packet log.
zxdavb
(David Bonnes)
November 19, 2021, 10:42pm
1868
@iMiMx
Use this logging instead:
logger:
default: warn
logs:
# custom_components.evohome_cc: info
custom_components.evohome_cc.sensor: info
