Honeywell CH/DHW via RF - evohome, sundial, hometronics, chronotherm
Hi I bought a nanocul about six months ago but after following the project for a week or so figured it would be a bit of a mountain for me given my skillset at that time and I would wait for more stability, a HACS version and hopefully a decent walk through install instructions. Every day I follow this and it feels like that point is getting closer. So I have a couple of questions at this stage, my boiler is not particularly close to my HA install server but should be adequate to receive RF signals, I have a Sonoff RF bridge similarly distanced which works. Any advice on distance? Also is there likely to be a full hardware/software guide? Thanks
For a nanoCUL 868Mhz bought on eBay:
  1. Install Arduino IDE, on a mac/Windows/Linux computer/laptop:
  1. Run Arduino IDE
  2. Go to Files → Preferences (Preferences under Arduino on macOS)
  3. In the ‘Additional Board Managers URLs’ paste in the below:
https://raw.githubusercontent.com/ghoti57/evofw3_avr/master/package_evofw3_boards_index.json
  1. OK
  2. Tools → Board → Board Manager
  3. Search for ‘evofw3’
  4. Install
  5. Download evofw3: below link, green Code button, download zip:
  1. Extract zip
  2. Open the evofw3 ‘sketch’ (evofw3.ino) in the Arduino IDE
  3. Plug your nanoCUL into a USB port on your computer with Arduino IDE
  4. Configure Tools → Board, Processor, Pinout, Port as per the below:
  1. Sketch → Upload
  2. Wait until it finishes.
  3. Plug into Home Assistant
  4. If you’re running HAC, then Community → Integrations → 3 dots → Custom Repository → Add below as Integration
  1. Install ‘Honeywell RF (RAMSES II protocol)’ in HAC
  2. Add the appropriate lines to your configuration.yml as per the 'Example Configuration
Create new page · zxdavb/ramses_cc Wiki · GitHub
… think that was it, more or less :slight_smile:
Wow!!! Very impressive. Perhaps that should go on the wiki.
nope, letting it run for some time does not solve it for me, been running at least 24h now. I’ll do a refresh of the nanocul later, but I flashed it only 2 or 3 days ago with the latest fw, so don’t think that’s gonna help. But assumptions are etc, so will give it a try
Just out of curiosity, I deleted the various Entities, uninstalled and reinstalled the plugin, restarted HA on the hour at 18:00.
It took until 18:47 for the first ‘name’ (Living Room) to be populated/retrieved/scanned/something-or-other for me… the others then followed shortly after.
2021-02-15 18:47:13 DEBUG (MainThread) [custom_components.evohome_cc] Params = {'system': {'mode': {'system_mode': 'auto', 'until': None}, 'language': None, 'heating_control': {}}, 'stored_hotwater': None, 'zones': {'00': {'name': 'Living Room', 'mode': {'zone_idx': '00', 'mode': 'follow_schedule', 'setpoint': 24.0}, 'zone_config': {'min_temp': 5.0, 'max_temp': 35.0, 'local_override': True, 'openwindow_function': True, 'multiroom_mode': False}},
Prior to this, it just showed:
{'name': None,
I can’t seem to get the zone names to appear,
evohome_rf uses three distinct means for collecting data, such as zone temps, etc.
  • schema file (broken at the moment)
  • eavesdropping (it captures the packets between the controller and other devices)
  • discovery (by sending a packet to a controller asking a quesion)
For a typical system, discovery takes 2 minutes (not, say, 47 minutes).
If you don’t any zone names (discovery isn’t working) and a name appears when you push the button on a TRV (specifically a HR82UK) (eavesdropping is working), then your evofw3/nanoCUL is not sending packets & you need to check your settings when you flash the firmware.
25% seems a bit high - what are others getting?
My system is 0.1%
Think you might be right, seem to be seeing a similar problem to the below - my understanding, is that they suspect the nanoCUL is not sending packets. I see the same with evohome_cc, an override does not change the zone temp and yet I can see all zone temperatures, etc.
If you look in the HA log, you will see at lot of messages with EXPIRED:
21:30:07.782 PktProtocolQos.send_data(RQ|01:145038|0418|0A): boff=1, want=RQ|01:145038|0418|0A, tout=2021-02-15 21:30:07.881995: RE-SENT (1/3)
21:30:08.238 PktProtocolQos.send_data(RQ|01:145038|0418|0A): boff=2, want=RQ|01:145038|0418|0A, tout=2021-02-15 21:30:08.438305: RE-SENT (2/3)
21:30:09.093 PktProtocolQos.send_data(RQ|01:145038|0418|0A): boff=3, want=RQ|01:145038|0418|0A, tout=2021-02-15 21:30:09.492816: RE-SENT (3/3)
21:30:10.750 PktProtocolQos.send_data(RQ|01:145038|0418|0A): boff=3, want=RP|01:145038|0418|0A, tout=2021-02-15 21:30:10.745596: EXPIRED
2021-02-15 21:30:16 WARNING (MainThread) [evohome_rf.transport] PktProtocolQos.send_data(RQ|13:215029|3EF1|00): boff=1, want=RQ|13:215029|3EF1|00, tout=2021-02-15 21:30:16.528318: RE-SENT (1/1)
2021-02-15 21:30:17 ERROR (MainThread) [evohome_rf.transport] PktProtocolQos.send_data(RQ|13:215029|3EF1|00): boff=1, want=RP|13:215029|3EF1|00, tout=2021-02-15 21:30:17.126126: EXPIRED
2021-02-15 21:30:17 WARNING (MainThread) [evohome_rf.transport] PktProtocolQos.send_data(RQ|13:246213|0008|00): boff=1, want=RQ|13:246213|0008|00, tout=2021-02-15 21:30:17.459575: RE-SENT (1/1)
2021-02-15 21:30:17 WARNING (MainThread) [evohome_rf.transport] PktProtocolQos.send_data(RQ|13:246213|3EF1|00): boff=1, want=RQ|13:246213|3EF1|00, tout=2021-02-15 21:30:17.888515: RE-SENT (1/1)
2021-02-15 21:30:17 ERROR (MainThread) [evohome_rf.transport] PktProtocolQos.send_data(RQ|13:246213|3EF1|00): boff=1, want=RQ|13:246213|3EF1|00, tout=2021-02-15 21:30:17.888515: EXPIRED
2021-02-15 21:31:06 WARNING (MainThread) [evohome_rf.transport] PktProtocolQos.send_data(RQ|13:246213|0008|00): boff=1, want=RQ|13:246213|0008|00, tout=2021-02-15 21:31:07.068531: RE-SENT (1/1)
2021-02-15 21:31:07 WARNING (MainThread) [evohome_rf.transport] PktProtocolQos.send_data(RQ|13:246213|3EF1|00): boff=1, want=RQ|13:246213|3EF1|00, tout=2021-02-15 21:31:07.336557: RE-SENT (1/1)
This is bad news:
21:20:44.166 PktProtocolQos.send_data(RQ|01:204708|10E0|00): boff=1, want=RQ|01:204708|10E0|00, tout=2021-02-15 21:20:44.266409: RE-SENT (1/3)
21:20:44.204 || HGI:003618 | CTL:204708 | RQ | device_info | 00 || {}
21:20:44.611 PktProtocolQos.send_data(RQ|01:204708|10E0|00): boff=2, want=RQ|01:204708|10E0|00, tout=2021-02-15 21:20:44.810766: RE-SENT (2/3)
21:20:44.636 || HGI:003618 | CTL:204708 | RQ | device_info | 00 || {}
21:20:45.443 PktProtocolQos.send_data(RQ|01:204708|10E0|00): boff=3, want=RQ|01:204708|10E0|00, tout=2021-02-15 21:20:45.843070: RE-SENT (3/3)
21:20:45.485 || HGI:003618 | CTL:204708 | RQ | device_info | 00 || {}
21:20:47.090 PktProtocolQos.send_data(RQ|01:204708|10E0|00): boff=3, want=RP|01:204708|10E0|00, tout=2021-02-15 21:20:47.086022: EXPIRED
Note the code: 10E0.
The point is: there is a difference between all Tx failing, and some pkts failing - and 0008 / 3EF1 can fail, even when everything else is OK.
packets that are 100% expected to work are 0004, 0005, 000C, 2309, 2E04, 30C9…
This may or may not be relevant, but I have an HGI80 connected to Domoticz and I’m seeing the same symptoms. Reading of the devices is perfect, but when you try to set anything (temperature, mode) then Domoticz thinks it has done it, but after a few minutes the Domoticz device’s values jump back to match the real-world controller. I thought I was going crazy and it was perhaps just my setup - this 100% used to work at some point, but I guess an update broke things. I’ve no idea when because I only tend to Domoticz for monitoring and not controlling.
I’ve also noted that my control via evohome_cc is not working either (I did think it was working, but was probably not paying attention as Home Assistant is new to me) - if I set a temperature on an entity with the arrows on the card then the value in the textbox disappears, eventually updated again to match the controller’s values.
Looks like I have the same issue… And it seems it is (?) related to HGI80… As I also use HGI80.
great! only thing missing is the Arduino tool config is this setting:
bootloader: “old bootloader”
the standard bootloader setting gives a failure in my case.
Ok, removed the Evohome_cc integration, did a clean pip install, same problem as the first time: I follow the instructions to the letter, and the install puts an Evohome_cc folder in custom_components, containing another custom_components folder with an Evohome_cc folder in it containing the python files. Moving the python files to the /config/custom_components/evohome_cc folder solves the problem, I can restart and after adding the Evohome_cc settings to configuration.yaml the integration works. But still no zone names, not even after an hour. Did a refresh of the nanocul with (again) the 0.6.7 evofw3 firmware, still no zone names after appr 30 minutes.
What am I doing wrong?
Using core-2021.2.3 Hass supervised in a docker on ubuntu 20.04.1 LTS.
We seem to suspect that the devices are not transmitting, have a quick read on the ~10 post above this.
And then:
Names not appearing, potentially, seems to be a symptom of the device not TX-ing.
yeah, that’s why I removed the integration and did a fresh install, and reflashed the nanocul with Arduino IDE set up like mentioned in earlier posts (although I notices my settings were already correct). Reflashing the nanocul should be the solution for the not transmitting problem, correct?
Packet logging set to debug, this is wat I get (still no zone names in HA):
2021-02-17T09:24:53.546972 091 RP — 10:071257 01:161604 --:------ 3220 005 00C0110000
2021-02-17T09:24:53.729004 071 RQ — 01:161604 10:071257 --:------ 3220 005 0000120000
2021-02-17T09:24:54.071116 092 RP — 10:071257 01:161604 --:------ 3220 005 00C01201B3
2021-02-17T09:24:54.729391 070 RQ — 01:161604 10:071257 --:------ 3220 005 0080190000
2021-02-17T09:24:55.150521 090 RP — 10:071257 01:161604 --:------ 3220 005 00401941F0
2021-02-17T09:24:55.328575 070 RQ — 01:161604 10:071257 --:------ 3220 005 00801A0000
2021-02-17T09:24:55.929721 071 RQ — 01:161604 10:071257 --:------ 3220 005 00801C0000
2021-02-17T09:24:56.246866 090 RP — 10:071257 01:161604 --:------ 3220 005 00C01C2FD7
2021-02-17T09:24:56.765994 091 RP — 10:071257 01:161604 --:------ 3220 005 004073031E
2021-02-17T09:24:57.460247 088 I — --:------ --:------ 10:071257 1FD4 003 00D6AF
2021-02-17T09:25:08.779028 070 I — 01:161604 --:------ 01:161604 1F09 003 FF0532
2021-02-17T09:25:08.810073 072 I — 01:161604 --:------ 01:161604 2309 027 0006400105DC0208020305DC0405140505DC0803E80908340A05DC
2021-02-17T09:25:08.833045 071 I — 01:161604 --:------ 01:161604 30C9 027 00078A01072F0207C90306C70406600507E50804AD0907D70A0707
2021-02-17T09:25:09.211155 082 I — 04:167390 --:------ 04:167390 30C9 003 0004BC
2021-02-17T09:25:13.727776 071 I — 01:161604 --:------ 01:161604 3B00 002 FCC8
2021-02-17T09:25:20.211949 082 I — 04:167390 --:------ 01:161604 1060 003 08FF01
2021-02-17T09:25:20.222891 083 I — 04:167390 --:------ 04:167390 1060 003 00FF01
2021-02-17T09:27:53.775511 082 I — 04:046807 --:------ 01:161604 3150 002 025A
2021-02-17T09:28:00.209626 082 I — 04:167390 --:------ 04:167390 30C9 003 0004C4
2021-02-17T09:28:28.939221 089 I — --:------ --:------ 10:071257 1FD4 003 00D6B6
2021-02-17T09:28:39.362721 074 RQ — 01:161604 10:071257 --:------ 3EF0 001 00
2021-02-17T09:28:41.259413 079 I — 04:122195 --:------ 04:122195 30C9 003 0009AF
2021-02-17T09:28:44.351393 081 I — 04:017582 --:------ 01:161604 3150 002 0100
2021-02-17T09:28:50.209359 083 I — 04:167390 --:------ 01:161604 2309 003 0803E8
2021-02-17T09:28:54.706917 066 I — 22:057582 --:------ 22:057582 0008 002 0090
2021-02-17T09:28:56.706546 065 I — 22:057582 --:------ 22:057582 0008 002 0090
2021-02-17T09:29:20.710674 083 I — 04:167390 --:------ 01:161604 1060 003 08FF01
2021-02-17T09:29:20.720830 081 I — 04:167390 --:------ 04:167390 1060 003 00FF01
I’m using HR92 TRV’s, pressing the button on those only turns on the display light, what can I do to trigger these? I turned the knob to set a temporary temperature on them, still no zone names.
thanks again.
If you set a temperature override/change in HA, does it actually make it to Evohome?
If not, the core problem is the device not transmitting - as far I’m aware, people in a similar situation (myself included) have not found a fix.
In the post of the evofw3 github page, I think, all of the people posting bought the same nanoCUL from the same seller on eBay - this may or may not be relevant, i.e it’s possible there is a dodgy hardware batch. Some who made their own device with components, did not see the problem as far as I recall.
I recently bought a new nanoCUL ( 1 week old) and it seems to be working on and off … I do noticed that I have high value reception, value what could mean that there is a bad reception.
Ok, looks like it’s working, maybe I was to impatient, because zone names are appearing in “entities” now. Also I maybe overlooked them because it is cluttered with these entities (probably 9 zones x 4 sensors/binary), can I delete those or hide them?
04:122187 battery
binary_sensor.04_122187_battery
04:122187 heat_demand
sensor.04_122187_heat_demand
04:122187 temperature
sensor.04_122187_temperature
04:122187 window
binary_sensor.04_122187_window
04:122191 battery
binary_sensor.04_122191_battery
04:122191 heat_demand
etc
