Honeywell Domonial (e.g. Sector Alarm) sensors
Is there anyway this project could be integrated into Home Assistant? I have Sector Alarm installed in my house. Unfortunately, the Honeywell Domonial platform that is used is a pretty closed protocol, which means it is currently not possible to integrate the different alarm sensors with HA. However, I found this project by a guy using OpenHAB: https://community.openhab.org/t/honeywell-wireless-security-sensors-w-sdr-and-mqtt/21542
He has coded a solution that enables reading sensor data through a SDR-RTL dongel or similar and then connected it with OpenHAB via a mosquitto or other MQTT broker.
I thought this would be an excellent addition to HA, as Honeywell Domonial is a rather common home alarm platform rebranded by different alarm providers including Sector Alarm.
Hi Thomas
Did you get any further on this?
Yes, there is an integration available here.
Thank you so much!
