timgp
(Tim Glover-Poultney)
October 7, 2020, 10:09am
1
Hi!
I have the Evohome integration working well and reporting the various temperatures of my zones, and I can turn the hot water on and off from the HASS UI by moving operation
to on
However, I can’t work out how to achieve this in an automation. Ideally I’d like to make a switch that I expose in Homekit so I can use Siri to control the hot water.
Here’s how the entity presents:
water_heater.dhw_controller
min_temp: 43.3
max_temp: 60
operation_list:
- auto
- 'on'
- 'off'
current_temperature: 58.9
temperature: null
target_temp_high: null
target_temp_low: null
operation_mode: 'on'
away_mode: 'off'
status:
setpoints:
this_sp_from: '2020-10-07T06:50:00+01:00'
this_sp_state: 'Off'
next_sp_from: '2020-10-07T17:30:00+01:00'
next_sp_state: 'On'
dhw_id: '2653202'
active_faults: []
state_status:
state: 'On'
mode: TemporaryOverride
until: '2020-10-07T17:30:00+01:00'
temperature_status:
temperature: 58
is_available: true
friendly_name: DHW controller
icon: 'mdi:thermometer-lines'
supported_features: 6
Does anyone have any suggestions please?
timgp
October 7, 2020, 10:44am
2
I was hopeful I might be able to use the Water Heater
service, but this doesn’t seem to work.
timgp
October 15, 2020, 2:46pm
3
Cracked it.
service: water_heater.set_operation_mode
entity_id: water_heater.dhw_controller
nwootton
(Nick W)
April 28, 2021, 8:41am
4
Hi @timgp
Does this still work for the EvoHome hot water system? I’ve tried using
- service: water_heater.set_operation_mode
and
but neither actually trigger the hot water. No obvious errors and other calls to the zones work as expected.
bodobadi
(Balazs Bolygo)
May 26, 2021, 10:27am
5
I cant seem to be able to trigger the hot water to on. Anyone able to help on this front?
alias: Hot Water Warning
description: ‘’
platform: numeric_state
attribute: current_temperature
below: ‘30’
condition: []
device_id: 1e4f07c03e0242eda05498fdbb872da7
domain: mobile_app
type: notify
title: ‘’
message: Water Temperature is LOW - water_heater.dhw_controller.current_temperature
service: water_heater.turn_on
mode: single
Troon
(Troon)
May 26, 2021, 10:31am
6
Please use the </> button when pasting code. Your automation as pasted is completely broken but might be fine in reality.
I can’t see a water_heater.turn_on
service listed: why do you think this will work?
bodobadi
(Balazs Bolygo)
May 28, 2021, 5:52am
7
- id: '1620853040880'
description: ''
- platform: numeric_state
below: '30'
condition: []
- device_id: 1e4f07c03e0242eda05498fdbb872da7
domain: mobile_app
type: notify
title: ''
- service: water_heater.turn_on
mode: single
bodobadi
(Balazs Bolygo)
May 28, 2021, 5:53am
8
Its listed on my automations as a service.
Troon
(Troon)
May 28, 2021, 7:57am
10
Fair enough. Does it work as you want if you call it directly from Developer Tools / Services?
bodobadi
(Balazs Bolygo)
June 16, 2021, 7:19am
11
No it doesnt for some reason.
Hey,
this is all working great for me now.
This service works
service: water_heater.turn_off
I then made these scripts, to use in automations and via Alexa.
######## Hot Water On/Of ########
script_hot_water_turn_on:
sequence:
script_hot_water_turn_off:
sequence:
- service: water_heater.turn_off
