I have a problem with integrating my Evohome system into HA. I tried everything mentioned here, but it does not work. I used text mentioned around for configuration.yaml, it does not work.
I found this in the logs: Logger: homeassistant.components.automation
Zdroj: components/automation/config.py:131
integrace: Automatizace (dokumentace, problémy)
První výskyt: 23:03:16 (1 výskyt)
Naposledy logováno: 23:03:16
Unnamed automation could not be validated and has been disabled: extra keys not allowed @ data[‘evohome’]. Got {‘username’: ‘josef.soltesxxxxxxxx.cz’, ‘password’: ‘xxxxxxxx’} required key not provided @ data[‘actions’]. Got None required key not provided @ data[‘triggers’]. Got None
But I really don’t understand it. Can anyone help?
Actually, this was completely my BFU fault and ChatGPT actually solved it for me. I was trying to do integration, but skipped a few steps like installing HACS etc. Also, I edited wrong file, not configuration.yaml, but the very first file, which was automations.yaml. Thank you guys.
