Honeywell - heat / cool mode - Not enough arguments for format string
Aight . . . I’m tired of beating my head against this. I have a Honeywell (Total Connect Comfort, Honeywell TH8321WF1001) Thermostat.
I’m trying to implement a “home / away” automation for it (you know . . .leave the house, adjust the temperature set points).
I have tried this 2 ways. One with Node Red, where I “build my object”, which looks like this:
{"target_temp_high":68,"target_temp_low":65,"hvac_mode":"heat_cool"}
I get an error on the climate.set_tempature call. I can use the UI to change my settings, and they show on both the thermostat, and the web interface. BUT if I try to automate it using either NodeRed via a service call node, or via an automation (ignore the trigger I was going to manually call the automation anyway):
  alias: Set Thermostat
  description: ""
    - platform: device
      type: changed_states
      device_id: 829f7859dbd36186ae8dd12632a574cc
      entity_id: media_player.andrew_s_2nd_fire
      domain: media_player
  condition: []
    - service: climate.set_temperature
        hvac_mode: heat_cool
        target_temp_high: "{{ states('input_number.target_temp_high') }}"
        target_temp_low: "{{ states('input_number.target_temp_low') }}"
        entity_id: climate.thermostat
  mode: single
this automation “compiles” to this:
Executed: March 16, 2022, 11:01:52 AM
Result:
params:
  domain: climate
  service: set_temperature
  service_data:
    target_temp_high: 68
    target_temp_low: 65
    entity_id:
      - climate.thermostat
    entity_id:
running_script: false
limit: 10
And to add to the confusion . . . if I use Developer tools to “call service”: A) it works, and B) the YAML looks “identical”:
  target_temp_high: 70
  target_temp_low: 68
Am I barking up the wrong tree? Any help would be awesome!
Log:
Logger: homeassistant.components.automation.set_thermostat
Source: components/honeywell/climate.py:267
Integration: Automation (documentation, issues)
First occurred: 11:00:07 AM (8 occurrences)
Last logged: 12:55:17 PM
Set Thermostat: Error executing script. Unexpected error for call_service at pos 1: not enough arguments for format string
While executing automation automation.set_thermostat
  File "/usr/local/lib/python3.9/site-packages/requests/models.py", line 910, in json
    return complexjson.loads(self.text, **kwargs)
  File "/usr/local/lib/python3.9/site-packages/simplejson/__init__.py", line 525, in loads
    return _default_decoder.decode(s)
  File "/usr/local/lib/python3.9/site-packages/simplejson/decoder.py", line 370, in decode
    obj, end = self.raw_decode(s)
  File "/usr/local/lib/python3.9/site-packages/simplejson/decoder.py", line 400, in raw_decode
    return self.scan_once(s, idx=_w(s, idx).end())
simplejson.errors.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
  File "/usr/local/lib/python3.9/site-packages/somecomfort/client.py", line 429, in _resp_json
    return resp.json()
  File "/usr/local/lib/python3.9/site-packages/requests/models.py", line 917, in json
    raise RequestsJSONDecodeError(e.msg, e.doc, e.pos)
requests.exceptions.JSONDecodeError: [Errno Expecting value] <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<!--[if IE 8 ]>    <html class="ie8" xmlns="http://www.w3.org/1999/xhtml"> <![endif]-->
<!--[if IE 9 ]>    <html class="ie9" xmlns="http://www.w3.org/1999/xhtml"> <![endif]-->
<!--[if (gt IE 9)|!(IE)]><!-->
<html xmlns="http://www.w3.org/1999/xhtml">
<!--<![endif]-->
<head><title>
Unexpected Error
</title>
    <!--[if IE]>
        <style>
            .page {
	                height: auto !important;
        </style>
    <![endif]-->
    <script type="text/javascript" src="/portal/Scripts/jquery-1.12.0.min.js"></script>
    <script type="text/javascript" src="/portal/Scripts/jquery.unobtrusive-ajax.js"></script>
    <script type="text/javascript" src="/portal/Scripts/jquery.validate.min.js"></script>
    <script type="text/javascript" src="/portal/Scripts/jquery.validate.unobtrusive.min.js"></script>
    <script type="text/javascript" src="/portal/Scripts/jquery-ui-1.10.4.min.js"></script>
    <script type="text/javascript" src="/portal/Scripts/jquery.qtip.min.js"></script>
    <script type="text/javascript" src="/portal/Scripts/jquery.idletimer.js"></script>
    <script type="text/javascript" src="/portal/Scripts/jquery.idletimeout.js"></script>
    <link rel="stylesheet" type="text/css" href="/portal/Content/TrueHome/jquery.qtip.truehome.css" />
    <link rel="stylesheet" type="text/css" href="/portal/Content/TrueHome/jquery.ui.truhome.css" />
    <link rel="stylesheet" type="text/css" href="/portal/Content/TrueHome/Layout.css?v=2.8.42" />
    <link rel="stylesheet" type="text/css" href="/portal/Content/TrueHome/Site.css?v=2.8.42" />
    <link rel="stylesheet" type="text/css" href="/portal/Content/TrueHome/Buttons.css?v=2.8.42" />
    <link rel="stylesheet" type="text/css" href="/portal/Content/TrueHome/EditorTemplates.css?v=2.8.42" />
    <link rel="stylesheet" type="text/css" href="/portal/Content/TrueHome/ModalAjaxContentDialog.css?v=2.8.42" />
    <script type="text/javascript" src="/portal/Scripts/Common/SessionTimeoutHandler.js?v=2.8.42"></script>
    <script type="text/javascript" src="/portal/Scripts/Common/ModalAjaxContentDialog.js?v=2.8.42"></script>
    <script type="text/javascript" src="/portal/Scripts/Common/CustomEvents.js?v=2.8.42"></script>
    <script type="text/javascript" src="/portal/Scripts/Common/EditorTemplates.js?v=2.8.42"></script>
    <script type="text/javascript" src="/portal/Scripts/Common/BrowserDetect.js?v=2.8.42"></script>
    <script type="text/javascript">
        var _gaq = _gaq || [];
        _gaq.push(['_setAccount', 'UA-33271749-1']);
        _gaq.push(['_setDomainName', 'alarmnet.com']);
        _gaq.push(['_trackPageview']);
        (function ()
            var ga = document.createElement('script'); ga.type = 'text/javascript'; ga.async = true;
            ga.src = ('https:' == document.location.protocol ? 'https://ssl' : 'http://www') + '.google-analytics.com/ga.js';
            var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(ga, s);
    </script>
</head>
<body>
    <!-- dialog window markup -->
    <div id="_verticalGradientBackground">
    </div>
    <div id="_contentWrapper">
        <div id="_leftBackground">
        </div>
        <div id="_content">
            <div id="header">
                <div id="header-top">
                    <ul id="toplinks">
                        <li><a href="https://www.honeywellhome.com" target="_blank">HoneywellHome.com</a></li>
                    </ul>
                </div>
                <div id="logo">
                    <a href="/portal/">Honeywell Home - My Total Connect Comfort<span></span></a>
                </div>
            </div>
            <div id="menucontainer">
                <ul id="menu">
                    <li class="menulink"><a href="https://www.honeywellhome.com/en/support"
                        target="_blank">
                        Contact Us</a></li>
                    <li class="menudivider"></li>
                        <a href="/portal/Home/FAQs">FAQs</a></li>
                        <a href="/portal/MyAccount">My Account</a></li>
                        <a href="/portal/">Control Center</a></li>
                        <a href="/portal/Account/LogOff">Sign Out</a></li>
                    <li id="greeting">
                        Welcome
                        <b>
                            Andrew</b></li>
                </ul>
            </div>
            <div id="red-grey-line">
            </div>
            <div id="breadcrumb">
    <div class="crumbs">Unexpected Error</div>
            </div>
            <div id="main">
                <noscript>
                    <div id="NoJavaScript">
                        This site will not operate without JavaScript enabled.  Refer to the FAQs tab on this site to learn about enabling JavaScript for your browser.
                    </div>
                </noscript>
                <div id="NoCookies">
This site will not operate without Cookies enabled.   Refer to the FAQs tab on this site to learn about enabling Cookies for your browser.
                </div>
                <div id="unsupportedbrowser">
                </div>
                <div id="mainContent">
 <div id="resetpassword">
        <h1>Unexpected Error</h1>
        <div class="formfield">
            <div class="rounded-bevel-border-topleftcorner">
            </div>
            <div class="rounded-bevel-border-top">
            </div>
            <div class="rounded-bevel-border-toprightcorner">
            </div>
            <div class="rounded-bevel-border-left">
                <div class="rounded-bevel-border-right">
                    <div class="whiteborder">
                        <div class="white-border-top">
                        </div>
                        <div class="white-border-left-side">
                            <div class="white-border-right-side">
                                <div id="account-success-whitebox">
                                    <div class="account-success">
                                        </div>
                                                <img src="/portal/Images/Icons/icon_red_x.gif?v=2.8.42" alt="Error" />
                                                <div class="Success">Error</div>
                                            </div>
                                        </div>
                                        <div class="white-border-bottom">
                                        </div>
                                    </div>
                                    <div class="success-text">
                                        <p>
                                        Sorry, an error occurred while processing your request.
                                        </p>
                                    </div>
                                </div>
                            </div>
                        </div>
                        </div>
                    </div>
                    <div class="buttonarea">
                        <div class="buttonwrapper">
                            <div class="red-button-gray">
                                <a href="/portal/">Home</a>
                            </div>
                        </div>
                    </div>
                </div>
            </div>
            <div class="rounded-bevel-border-bottomleftcorner">
            </div>
            <div class="rounded-bevel-border-bottom">
            </div>
            <div class="rounded-bevel-border-bottomrightcorner">
            </div>
        </div>
    </div>
                </div>
            </div>
            <div id="gatewaylog">
            </div>
            <div id="_push">
            </div>
            <div id="_footer">
                <div>
                    Version 2.8.42 - November 10, 2020
                </div>
                <ul class="left" style="width: 700px;margin-top: 5px;">
                    <li class="rightborder">
                        <a href="/portal/Home/TermsAndConditions">Privacy Statement and End User License Agreement</a></li>
                        <a href="/portal/Home/TermsConditions">Terms &amp; Conditions</a></li>
                    <li class="rightborder"><a href="https://www.mytotalconnectcomfort.com/Account/ResetLocalisationCulture">Global Site</a></li>
                        <a href="/portal/Home/Feedback">Feedback</a></li>
                    <li><br/>&nbsp;&nbsp;<a href="https://honeywellhome.com/" target="_blank">&copy;
                        2022
                        Resideo Technologies, Inc.</a>
                        The Honeywell Home trademark is used under license from Honeywell International Inc. All rights reserved.
                    </li>
                </ul>
                <ul id="CultureControl">
<li class="rightborder"><a class="culture-link" data-ajax="false" href="/portal/Account/ChangeCulture?lang=en-US&amp;returnUrl=%2Fportal%2FError%3Faspxerrorpath%3D%2Fportal%2FDevice%2FSubmitControlScreenChanges" style="text-decoration: underline;">English</a> </li>
<li><a class="culture-link" data-ajax="false" href="/portal/Account/ChangeCulture?lang=fr-CA&amp;returnUrl=%2Fportal%2FError%3Faspxerrorpath%3D%2Fportal%2FDevice%2FSubmitControlScreenChanges" style="">Fran&#231;ais</a></li>
                </ul>
            </div>
        </div>
        <div id="_rightBackground">
        </div>
    </div>
    <div id="dialog" style="display: none">
        <div class="warning"></div>
        <ul>
            <li class="header">Your session is about to expire.</li>
            <li>You will be logged off in <span id='dialog-countdown' style='font-weight:bold'></span> seconds.</li>
            <li>Do you want to continue your session?</li>
        </ul>
    </div>
            var sessionTimeoutHandler = new SessionTimeoutHandler(
                "#dialog",
                "#dialog-countdown",
                "Yes",
                "No",
                '/portal/Account/LogOff',
                '/portal/Account/Timeout'
            sessionTimeoutHandler.Initialize();
        </script>
    <script type="text/javascript" language="javascript">
        $(function ()
            var isMobileDevice = false;
            if (BrowserDetect.browser == "Explorer" && parseFloat(BrowserDetect.version) < 8)
                $("#unsupportedbrowser").html('The web browser you are using is not supported.  A supported browser is required to use Total Connect Comfort.  The most recent versions of Chrome, Safari, Firefox and Internet Explorer may be used.  Update or download one of these browsers to use Total Connect Comfort.');
    </script>
</body>
</html>
: 0
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 367, in _async_step
    await getattr(self, handler)()
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 570, in _async_call_service_step
    await service_task
  File "/usr/src/homeassistant/homeassistant/core.py", line 1636, in async_call
    task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1673, in _execute_service
    await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
    await self.hass.helpers.service.entity_service_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 668, in entity_service_call
    future.result()  # pop exception if have
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 949, in async_request_call
    await coro
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 705, in _handle_entity_call
    await result
  File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 586, in async_service_temperature_set
    await entity.async_set_temperature(**kwargs)
  File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 444, in async_set_temperature
    await self.hass.async_add_executor_job(
  File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
  File "/usr/src/homeassistant/homeassistant/components/honeywell/climate.py", line 267, in set_temperature
    self._device.setpoint_cool = temperature
  File "/usr/local/lib/python3.9/site-packages/somecomfort/client.py", line 192, in setpoint_cool
    self._client._set_thermostat_settings(self.deviceid,
  File "/usr/local/lib/python3.9/site-packages/somecomfort/client.py", line 491, in _set_thermostat_settings
    result = self._post_json(url, data=data)
  File "/usr/local/lib/python3.9/site-packages/somecomfort/client.py", line 455, in _post_json
    return self._request_json('post', *args, **kwargs)
  File "/usr/local/lib/python3.9/site-packages/somecomfort/client.py", line 443, in _request_json
    return self._resp_json(resp, req)
  File "/usr/local/lib/python3.9/site-packages/somecomfort/client.py", line 433, in _resp_json
    _LOG.exception("Failed to de-JSON %s %s" % req, resp)
TypeError: not enough arguments for format string
Hey brokerandy25, Did you ever find a solution? My system is giving me the same error after the last Home Assistant update yesterday.
No I haven’t . . . a little research into the integration makes it look like it is actually screen scraping the Honeywell webpage. What version of HA are you running?
I’m on 2022.3.7. I see in the error message “requests.exceptions.JSONDecodeError: [Errno Expecting value]” but the data looks like html instead of json. Looks like the integration is broken. So far, I haven’t seen any other complaints about it yet.
I’m still sitting on 2022.3.3 . . . I had updated and NodeRed went sideways on me. I had to roll back. I may have to just get a different thermostat. Thankfully my energy company is subsidizing Emerson Sensi touch thermostats. Time to go pull up the email.
I’ve never logged a bug with the Home Assistant team before. I think I’ll give that a whirl. The cloud strikes again.
Turned out my thermostat lost its internet connection to the cloud for some reason. I went to mytotalconnectcomfort.com deleted and reinstalled the thermostat and all is well again. Not Home Assistant’s fault after all.
I’ll have to give that a shot . . . I’m in IT and I know that a “reboot” solves 95% of all issues. Don’t know why I didn’t think of that first :upside_down_face:
@brokerandy25 Im having the same issue. To double add to the confusion, my climate control on Lovelace works 100%. Changing the heat to cool, temperature, etc. have you found a solution yet?
I did . . . but it is “Hacky” as all get out. What I ended up doing is creating Automation in HA, and calling those automation from Node Red. The automations “talk” to Alexa and trigger the skill for TCC. I’m not thrilled with the solution, but it works. And since it works . . . I don’t feel too compelled to chase down “making it better” as it may only be triggered 2 times a day.
(As an aside . . I have some input selects that allow me to set heat / cool for the following “states”: Home / Away / Bedtime)
EX Automation:
service: media_player.play_media
  media_content_id: Change Thermostat to Cool
  media_content_type: custom
  entity_id: media_player.living_room
The Trigger is Irrelevant (but required to save the automation) as you will trigger the automation . . . uhh . . . automatically. The Entity_id is just a random Alexa that I don’t really have to listen to, because “she” will respond. “The thermostat is set to cool” . . . etc.
Then, I have a series of automation that look like this (from 66 to 74), which I reuse based upon if am I changing “heat point” or “cool point”:
  media_content_id: Set Thermostat to 70
  device_id: media_player.living_room
(Again, trigger is irrelevant . . . again)
SO . . . I set the thermostat from “heat_cool” to “heat” set the new temp, and change to “cool”, set the new temp, then set the thermostat back to “heat_cool”.
Here are my nodered nodes:
[{"id":"c536177711f49b9a","type":"tab","label":"Flow 3","disabled":false,"info":"","env":[]},{"id":"642653aa9ba694de","type":"ha-button","z":"c536177711f49b9a","name":"Home Button","version":0,"debugenabled":false,"outputs":1,"entityConfig":"827fc443735f5442","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":510,"y":620,"wires":[["0afc915a231f6e1c"]]},{"id":"0afc915a231f6e1c","type":"api-call-service","z":"c536177711f49b9a","name":"Set Thermostat to Heat","server":"12bf1601.375b1a","version":5,"debugenabled":false,"domain":"automation","service":"trigger","areaId":[],"deviceId":[],"entityId":["automation.set_thermostat_to_heat"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":530,"y":480,"wires":[["db325282cc0249bc"]]},{"id":"db325282cc0249bc","type":"trigger","z":"c536177711f49b9a","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"15","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":2,"x":730,"y":480,"wires":[[],["52afcfe7b82f3ee9"]]},{"id":"52afcfe7b82f3ee9","type":"switch","z":"c536177711f49b9a","name":"Temp to Set Heater on (low number)","property":"tempLow","propertyType":"flow","rules":[{"t":"eq","v":"66","vt":"str"},{"t":"eq","v":"67","vt":"str"},{"t":"eq","v":"68","vt":"str"},{"t":"eq","v":"69","vt":"str"},{"t":"eq","v":"70","vt":"str"},{"t":"eq","v":"71","vt":"str"}],"checkall":"true","repair":false,"outputs":6,"x":990,"y":480,"wires":[["b71b3e0130050066"],["c3b5ec7b38925946"],["1a894c38e4e57dea"],["2b2199323cca2540"],["69d7bcde4120585c"],["71b0238c48a1fdaa"]]},{"id":"b71b3e0130050066","type":"api-call-service","z":"c536177711f49b9a","name":"Set Thermostat to 66","server":"12bf1601.375b1a","version":5,"debugenabled":false,"domain":"automation","service":"trigger","areaId":[],"deviceId":[],"entityId":["automation.set_thermostat_to_66"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1300,"y":380,"wires":[["943eb7e2d28305fa"]]},{"id":"c3b5ec7b38925946","type":"api-call-service","z":"c536177711f49b9a","name":"Set Thermostat to 67","server":"12bf1601.375b1a","version":5,"debugenabled":false,"domain":"automation","service":"trigger","areaId":[],"deviceId":[],"entityId":["automation.set_thermostat_to_67"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1300,"y":420,"wires":[["943eb7e2d28305fa"]]},{"id":"1a894c38e4e57dea","type":"api-call-service","z":"c536177711f49b9a","name":"Set Thermostat to 68","server":"12bf1601.375b1a","version":5,"debugenabled":false,"domain":"automation","service":"trigger","areaId":[],"deviceId":[],"entityId":["automation.set_thermostat_to_68"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1300,"y":460,"wires":[["943eb7e2d28305fa"]]},{"id":"2b2199323cca2540","type":"api-call-service","z":"c536177711f49b9a","name":"Set Thermostat to 69","server":"12bf1601.375b1a","version":5,"debugenabled":false,"domain":"automation","service":"trigger","areaId":[],"deviceId":[],"entityId":["automation.set_thermostat_to_69"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1300,"y":500,"wires":[["943eb7e2d28305fa"]]},{"id":"69d7bcde4120585c","type":"api-call-service","z":"c536177711f49b9a","name":"Set Thermostat to 70","server":"12bf1601.375b1a","version":5,"debugenabled":false,"domain":"automation","service":"trigger","areaId":[],"deviceId":[],"entityId":["automation.lower_low_temp_summer"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1300,"y":540,"wires":[["943eb7e2d28305fa"]]},{"id":"71b0238c48a1fdaa","type":"api-call-service","z":"c536177711f49b9a","name":"Set Thermostat to 71","server":"12bf1601.375b1a","version":5,"debugenabled":false,"domain":"automation","service":"trigger","areaId":[],"deviceId":[],"entityId":["automation.set_thermostat_to_71"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1300,"y":580,"wires":[["943eb7e2d28305fa"]]},{"id":"fc57f530d238910a","type":"api-call-service","z":"c536177711f49b9a","name":"Set Thermostat to Cool","server":"12bf1601.375b1a","version":5,"debugenabled":false,"domain":"automation","service":"trigger","areaId":[],"deviceId":[],"entityId":["automation.set_thermostat_to_cool"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1810,"y":480,"wires":[["68bc307a21f59b22"]]},{"id":"943eb7e2d28305fa","type":"trigger","z":"c536177711f49b9a","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"15","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":2,"x":1590,"y":480,"wires":[[],["fc57f530d238910a"]]},{"id":"68bc307a21f59b22","type":"trigger","z":"c536177711f49b9a","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"15","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":2,"x":2010,"y":480,"wires":[[],["8746409045758b4f"]]},{"id":"8746409045758b4f","type":"switch","z":"c536177711f49b9a","name":"Temp to Set Heater on (low number)","property":"tempHigh","propertyType":"flow","rules":[{"t":"eq","v":"66","vt":"str"},{"t":"eq","v":"67","vt":"str"},{"t":"eq","v":"68","vt":"str"},{"t":"eq","v":"69","vt":"str"},{"t":"eq","v":"70","vt":"str"},{"t":"eq","v":"71","vt":"str"}],"checkall":"true","repair":false,"outputs":6,"x":2270,"y":480,"wires":[["3deb9390c318a6cb"],["1f0a89fc26db0360"],["831860ee6457c7ad"],["e0c9402e323e949f"],["eeabd654ca428b4f"],["f9db0874f714da30"]]},{"id":"3deb9390c318a6cb","type":"api-call-service","z":"c536177711f49b9a","name":"Set Thermostat to 66","server":"12bf1601.375b1a","version":5,"debugenabled":false,"domain":"automation","service":"trigger","areaId":[],"deviceId":[],"entityId":["automation.set_thermostat_to_66"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2580,"y":380,"wires":[["1d75113f412041e6"]]},{"id":"1f0a89fc26db0360","type":"api-call-service","z":"c536177711f49b9a","name":"Set Thermostat to 67","server":"12bf1601.375b1a","version":5,"debugenabled":false,"domain":"automation","service":"trigger","areaId":[],"deviceId":[],"entityId":["automation.set_thermostat_to_67"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2580,"y":420,"wires":[["1d75113f412041e6"]]},{"id":"831860ee6457c7ad","type":"api-call-service","z":"c536177711f49b9a","name":"Set Thermostat to 68","server":"12bf1601.375b1a","version":5,"debugenabled":false,"domain":"automation","service":"trigger","areaId":[],"deviceId":[],"entityId":["automation.set_thermostat_to_68"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2580,"y":460,"wires":[["1d75113f412041e6"]]},{"id":"e0c9402e323e949f","type":"api-call-service","z":"c536177711f49b9a","name":"Set Thermostat to 69","server":"12bf1601.375b1a","version":5,"debugenabled":false,"domain":"automation","service":"trigger","areaId":[],"deviceId":[],"entityId":["automation.set_thermostat_to_69"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2580,"y":500,"wires":[["1d75113f412041e6"]]},{"id":"eeabd654ca428b4f","type":"api-call-service","z":"c536177711f49b9a","name":"Set Thermostat to 70","server":"12bf1601.375b1a","version":5,"debugenabled":false,"domain":"automation","service":"trigger","areaId":[],"deviceId":[],"entityId":["automation.lower_low_temp_summer"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2580,"y":540,"wires":[["1d75113f412041e6"]]},{"id":"f9db0874f714da30","type":"api-call-service","z":"c536177711f49b9a","name":"Set Thermostat to 71","server":"12bf1601.375b1a","version":5,"debugenabled":false,"domain":"automation","service":"trigger","areaId":[],"deviceId":[],"entityId":["automation.set_thermostat_to_71"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2580,"y":580,"wires":[["1d75113f412041e6"]]},{"id":"1d75113f412041e6","type":"trigger","z":"c536177711f49b9a","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"15","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":2,"x":2850,"y":480,"wires":[[],["cc1d45389175141f","77b53f3b1eb08b43"]]},{"id":"77b53f3b1eb08b43","type":"api-call-service","z":"c536177711f49b9a","name":"","server":"12bf1601.375b1a","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_on","areaId":[],"deviceId":[],"entityId":["input_boolean.someone_is_home"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":3080,"y":520,"wires":[[]]},{"id":"cc1d45389175141f","type":"api-call-service","z":"c536177711f49b9a","name":"Set Thermostat to Auto","server":"12bf1601.375b1a","version":5,"debugenabled":false,"domain":"automation","service":"trigger","areaId":[],"deviceId":[],"entityId":["automation.set_thermostat_to_auto"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":3140,"y":360,"wires":[[]]},{"id":"827fc443735f5442","type":"ha-entity-config","server":"12bf1601.375b1a","name":"Trigger Home","version":2,"haConfig":[{"property":"name","value":"Trigger home"},{"property":"icon","value":"mdi:home-outline"},{"property":"device_class","value":""}],"entityType":"button"},{"id":"12bf1601.375b1a","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30"}]
I use the Redlink bridge for my four Honeywell thermostats so this may be different than the WiFi units. However, I was having this same issue for two of my four thermostats just as is stated in the thread.
I ended up changing the ‘Changeover’ (Heat to Cool mode) to Manual (from Automatic) in the two thermostats that were problematic, and the issue went away (found in the Installer Options section of your thermostat). While I did not have a need to disable that feature in the other two controller I went ahead for consistency and the fact that I do not use that feature.
I do not know if this is the fix (work around) or just coincidental. I only made this change today so time will tell but thought I would share my luck on the subject.
@paetzoldb1 . . . My wife would KILL me if I told her I had to not only buy ANOTHER thermostat, but also a control box . . . I’m constantly pushing the limits of the WAF anyway.
And my approach is nothing more than workaround . . . I’m pretty good at lateral thinking to solve problems . . . but the engineer in me gets mad at myself for uber-hacky solutions like I had to use. If its stupid and it works . . . it ain’t stupid . . .
I have the Redlink bridge for 2 thermostats. One of them had a changeover that was automatic, and the other manual. The manual allowed temp changes, the automatic one did not. I changed it to manual and it started allowing temperature changes via set_temperature. There is definitely something to this. Thank you for sharing.
