Honeywell Set Temperature - Error
I’m trying to write a script that will automatically change the temperature of the house based on other criteria. So far my script looks like this:
# Turn up Heat
  heat_on:
    alias: Heat On
    sequence:
    - service: climate.set_temperature
        entity_id: climate.thermostat
        temperature: 68
        target_temp_low: 68
        target_temp_high: 78
This is not working at all. It pulls the following error:
Error doing job: Task exception was never retrieved
  File "/usr/lib/python3.6/asyncio/tasks.py", line 181, in _step
    result = coro.throw(exc)
  File "/usr/lib/python3.6/site-packages/homeassistant/core.py", line 1031, in _event_to_service_call
    yield from service_handler.func(service_call)
  File "/usr/lib/python3.6/site-packages/homeassistant/components/climate/__init__.py", line 340, in async_temperature_set_service
    yield from climate.async_set_temperature(**kwargs)
  File "/usr/lib/python3.6/asyncio/futures.py", line 331, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.6/asyncio/tasks.py", line 244, in _wakeup
    future.result()
  File "/usr/lib/python3.6/asyncio/futures.py", line 244, in result
    raise self._exception
  File "/usr/lib/python3.6/concurrent/futures/thread.py", line 55, in run
  File "/usr/lib/python3.6/site-packages/homeassistant/components/climate/honeywell.py", line 300, in set_temperature
    if getattr(self._device, "hold_{}".format(mode)) is False:
AttributeError: 'Device' object has no attribute 'hold_auto'
I’m probably not setting this up correctly but going over the Honeywell component section and the Climate section I’m still at a loss. Any thoughts on the matter?
