Still not getting any humidity data from the thermostat.
I tried a heal operation and noticed that Node033 was responding along side several other nodes. Currently I don’t have a Node033 in my setup but probably had one at some point and was removed/re-added.
Do other people see this behavior normally (where a nonexistent node shows up in the logs when healing the network)?
Here’s the log from my most recent heal (removed several lines so it would fit in the post).
2020-01-11 10:21:34.940 Detail, Node001, Queuing (Controller) Request Node Neighbor Update
2020-01-11 10:21:34.940 Detail, Node007, Queuing (Controller) Request Node Neighbor Update
2020-01-11 10:21:34.941 Detail, Node008, Queuing (Controller) Request Node Neighbor Update
2020-01-11 10:21:34.941 Detail, Node009, Queuing (Controller) Request Node Neighbor Update
2020-01-11 10:21:34.941 Detail, Node010, Queuing (Controller) Request Node Neighbor Update
2020-01-11 10:21:34.941 Info, Requesting Neighbor Update for node 1
2020-01-11 10:21:34.941 Detail, Node012, Queuing (Controller) Request Node Neighbor Update
2020-01-11 10:21:34.941 Detail, Node019, Queuing (Controller) Request Node Neighbor Update
2020-01-11 10:21:34.941 Detail, Node020, Queuing (Controller) Request Node Neighbor Update
2020-01-11 10:21:34.941 Detail, Node021, Queuing (Controller) Request Node Neighbor Update
2020-01-11 10:21:34.941 Detail, Node022, Queuing (Controller) Request Node Neighbor Update
2020-01-11 10:21:34.941 Detail, Node027, Queuing (Controller) Request Node Neighbor Update
2020-01-11 10:21:34.941 Detail, Node029, Queuing (Controller) Request Node Neighbor Update
2020-01-11 10:21:34.941 Detail, Node030, Queuing (Controller) Request Node Neighbor Update
2020-01-11 10:21:34.941 Detail, Node031, Queuing (Controller) Request Node Neighbor Update
2020-01-11 10:21:34.941 Detail, Node032, Queuing (Controller) Request Node Neighbor Update
2020-01-11 10:21:34.941 Detail, Node034, Queuing (Controller) Request Node Neighbor Update
2020-01-11 10:21:34.941 Detail, Node037, Queuing (Controller) Request Node Neighbor Update
2020-01-11 10:21:34.941 Detail, Node001, Queuing (Command) ControllerCommand_RequestNodeNeighborUpdate (Node=1): 0x01, 0x05, 0x00, 0x48, 0x01, 0x8e, 0x3d
2020-01-11 10:21:34.941 Detail, Notification: ControllerCommand - Starting
2020-01-11 10:21:34.942 Detail,
2020-01-11 10:21:34.942 Info, Node001, Sending (Command) message (Callback ID=0x8e, Expected Reply=0x48) - ControllerCommand_RequestNodeNeighborUpdate (Node=1): 0x01, 0x05, 0x00, 0x48, 0x01, 0x8e, 0x3d
2020-01-11 10:21:34.973 Detail, Node001, Received: 0x01, 0x05, 0x00, 0x48, 0x8e, 0x21, 0x1d
2020-01-11 10:21:34.973 Info, Node001, REQUEST_NEIGHBOR_UPDATE_STARTED
2020-01-11 10:21:34.973 Detail, Node033, Expected callbackId was received
2020-01-11 10:21:34.973 Detail, Node033, Expected reply was received
2020-01-11 10:21:34.974 Detail, Node033, Message transaction complete
2020-01-11 10:21:34.974 Detail, Node001, Removing current message
2020-01-11 10:21:34.974 Detail, Notification: ControllerCommand - InProgress
2020-01-11 10:21:34.974 Info, WriteNextMsg Controller nothing to do
2020-01-11 10:21:43.767 Detail, Received: 0x01, 0x05, 0x00, 0x48, 0x8e, 0x23, 0x1f
2020-01-11 10:21:43.767 Warning, WARNING: REQUEST_NEIGHBOR_UPDATE_FAILED
2020-01-11 10:21:43.767 Detail, Notification: ControllerCommand - Failed
2020-01-11 10:21:43.774 Info, Requesting Neighbor Update for node 19
2020-01-11 10:21:43.775 Detail, Node019, Queuing (Command) ControllerCommand_RequestNodeNeighborUpdate (Node=19): 0x01, 0x05, 0x00, 0x48, 0x13, 0x94, 0x35
2020-01-11 10:21:43.775 Detail, Notification: ControllerCommand - Starting
2020-01-11 10:21:43.775 Info, Node019, Sending (Command) message (Callback ID=0x94, Expected Reply=0x48) - ControllerCommand_RequestNodeNeighborUpdate (Node=19): 0x01, 0x05, 0x00, 0x48, 0x13, 0x94, 0x35
2020-01-11 10:21:43.806 Detail, Node019, Received: 0x01, 0x05, 0x00, 0x48, 0x94, 0x21, 0x07
2020-01-11 10:21:43.806 Info, Node019, REQUEST_NEIGHBOR_UPDATE_STARTED
2020-01-11 10:21:43.806 Detail, Node033, Expected callbackId was received
2020-01-11 10:21:43.806 Detail, Node033, Expected reply was received
2020-01-11 10:21:43.806 Detail, Node033, Message transaction complete
2020-01-11 10:21:43.806 Detail, Node019, Removing current message
2020-01-11 10:21:43.806 Detail, Notification: ControllerCommand - InProgress
2020-01-11 10:21:43.807 Info, WriteNextMsg Controller nothing to do
2020-01-11 10:21:45.800 Detail, Received: 0x01, 0x05, 0x00, 0x48, 0x94, 0x21, 0x07
2020-01-11 10:21:45.800 Info, REQUEST_NEIGHBOR_UPDATE_STARTED
2020-01-11 10:21:45.800 Detail, Notification: ControllerCommand - InProgress
2020-01-11 10:21:51.956 Detail, Received: 0x01, 0x05, 0x00, 0x48, 0x94, 0x22, 0x04
2020-01-11 10:21:51.957 Detail,
2020-01-11 10:21:51.957 Info, REQUEST_NEIGHBOR_UPDATE_DONE
2020-01-11 10:21:51.957 Detail, Requesting routing info (neighbor list) for Node 19
2020-01-11 10:21:51.957 Detail, Node019, Queuing (Command) Get Routing Info (Node=19): 0x01, 0x07, 0x00, 0x80, 0x13, 0x00, 0x00, 0x03, 0x68
2020-01-11 10:21:51.957 Detail, Notification: ControllerCommand - Completed
2020-01-11 10:21:51.958 Detail,
2020-01-11 10:21:51.958 Info, Node019, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=19): 0x01, 0x07, 0x00, 0x80, 0x13, 0x00, 0x00, 0x03, 0x68
2020-01-11 10:21:51.966 Detail, Node019, Received: 0x01, 0x20, 0x01, 0x80, 0x00, 0x00, 0x38, 0x44, 0x12, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30
2020-01-11 10:21:51.967 Info, Node019, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2020-01-11 10:21:51.967 Info, Node019, Neighbors of this node are:
2020-01-11 10:21:51.967 Info, Node019, Node 20
2020-01-11 10:21:51.967 Info, Node019, Node 21
2020-01-11 10:21:51.967 Info, Node019, Node 22
2020-01-11 10:21:51.967 Info, Node019, Node 27
2020-01-11 10:21:51.967 Info, Node019, Node 31
2020-01-11 10:21:51.967 Info, Node019, Node 34
2020-01-11 10:21:51.967 Info, Node019, Node 37
2020-01-11 10:21:51.967 Detail, Expected reply was received
2020-01-11 10:21:51.967 Detail, Message transaction complete
2020-01-11 10:21:51.967 Detail, Node019, Removing current message
2020-01-11 10:21:51.968 Info, Requesting Neighbor Update for node 20
2020-01-11 10:21:51.968 Detail, Node020, Queuing (Command) ControllerCommand_RequestNodeNeighborUpdate (Node=20): 0x01, 0x05, 0x00, 0x48, 0x14, 0x95, 0x33
2020-01-11 10:21:51.968 Detail, Notification: ControllerCommand - Starting
2020-01-11 10:21:51.969 Detail,
2020-01-11 10:21:51.969 Info, Node020, Sending (Command) message (Callback ID=0x95, Expected Reply=0x48) - ControllerCommand_RequestNodeNeighborUpdate (Node=20): 0x01, 0x05, 0x00, 0x48, 0x14, 0x95, 0x33
2020-01-11 10:21:51.999 Detail, Node020, Received: 0x01, 0x05, 0x00, 0x48, 0x95, 0x21, 0x06
2020-01-11 10:21:51.999 Info, Node020, REQUEST_NEIGHBOR_UPDATE_STARTED
2020-01-11 10:21:51.999 Detail, Node033, Expected callbackId was received
2020-01-11 10:21:51.999 Detail, Node033, Expected reply was received
2020-01-11 10:21:51.999 Detail, Node033, Message transaction complete
2020-01-11 10:21:51.999 Detail, Node020, Removing current message
2020-01-11 10:21:52.000 Detail, Notification: ControllerCommand - InProgress
2020-01-11 10:21:52.000 Info, WriteNextMsg Controller nothing to do
2020-01-11 10:21:53.488 Detail, Received: 0x01, 0x05, 0x00, 0x48, 0x95, 0x21, 0x06
2020-01-11 10:21:53.489 Detail,
2020-01-11 10:21:53.489 Info, REQUEST_NEIGHBOR_UPDATE_STARTED
2020-01-11 10:21:53.489 Detail, Notification: ControllerCommand - InProgress
2020-01-11 10:22:00.008 Detail, Received: 0x01, 0x05, 0x00, 0x48, 0x95, 0x22, 0x05
2020-01-11 10:22:00.009 Detail,
2020-01-11 10:22:00.009 Info, REQUEST_NEIGHBOR_UPDATE_DONE
2020-01-11 10:22:00.009 Detail, Requesting routing info (neighbor list) for Node 20
2020-01-11 10:22:00.009 Detail, Node020, Queuing (Command) Get Routing Info (Node=20): 0x01, 0x07, 0x00, 0x80, 0x14, 0x00, 0x00, 0x03, 0x6f
2020-01-11 10:22:00.009 Detail, Notification: ControllerCommand - Completed
2020-01-11 10:22:00.012 Detail,
2020-01-11 10:22:00.012 Info, Node020, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=20): 0x01, 0x07, 0x00, 0x80, 0x14, 0x00, 0x00, 0x03, 0x6f
2020-01-11 10:22:00.018 Detail, Node020, Received: 0x01, 0x20, 0x01, 0x80, 0x01, 0x00, 0x34, 0xc4, 0x12, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xbd
2020-01-11 10:22:00.019 Detail,
2020-01-11 10:22:00.019 Info, Node020, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2020-01-11 10:22:00.019 Info, Node020, Neighbors of this node are:
2020-01-11 10:22:00.019 Info, Node020, Node 1
2020-01-11 10:22:00.019 Info, Node020, Node 19
2020-01-11 10:22:00.019 Info, Node020, Node 21
2020-01-11 10:22:00.019 Info, Node020, Node 22
2020-01-11 10:22:00.019 Info, Node020, Node 27
2020-01-11 10:22:00.019 Info, Node020, Node 31
2020-01-11 10:22:00.019 Info, Node020, Node 32
2020-01-11 10:22:00.019 Info, Node020, Node 34
2020-01-11 10:22:00.019 Info, Node020, Node 37
2020-01-11 10:22:00.019 Detail, Expected reply was received
2020-01-11 10:22:00.019 Detail, Message transaction complete
2020-01-11 10:22:00.020 Detail,
2020-01-11 10:22:00.020 Detail, Node020, Removing current message
2020-01-11 10:22:00.020 Info, Requesting Neighbor Update for node 21
2020-01-11 10:22:00.020 Detail, Node021, Queuing (Command) ControllerCommand_RequestNodeNeighborUpdate (Node=21): 0x01, 0x05, 0x00, 0x48, 0x15, 0x96, 0x31
2020-01-11 10:22:07.478 Detail, Node002, Expected reply was received
2020-01-11 10:22:07.478 Detail, Node002, Message transaction complete
2020-01-11 10:22:07.478 Detail, Node021, Removing current message
2020-01-11 10:22:07.478 Info, Requesting Neighbor Update for node 22
2020-01-11 10:22:07.478 Detail, Node022, Queuing (Command) ControllerCommand_RequestNodeNeighborUpdate (Node=22): 0x01, 0x05, 0x00, 0x48, 0x16, 0x97, 0x33
2020-01-11 10:22:07.478 Detail, Notification: ControllerCommand - Starting
2020-01-11 10:22:07.479 Detail,
2020-01-11 10:22:07.479 Info, Node022, Sending (Command) message (Callback ID=0x97, Expected Reply=0x48) - ControllerCommand_RequestNodeNeighborUpdate (Node=22): 0x01, 0x05, 0x00, 0x48, 0x16, 0x97, 0x33
2020-01-11 10:22:07.510 Detail, Node022, Received: 0x01, 0x05, 0x00, 0x48, 0x97, 0x21, 0x04
2020-01-11 10:22:07.510 Info, Node022, REQUEST_NEIGHBOR_UPDATE_STARTED
2020-01-11 10:22:07.510 Detail, Node033, Expected callbackId was received
2020-01-11 10:22:07.510 Detail, Node033, Expected reply was received
2020-01-11 10:22:07.510 Detail, Node033, Message transaction complete
2020-01-11 10:22:07.510 Detail, Node022, Removing current message
2020-01-11 10:22:07.510 Detail, Notification: ControllerCommand - InProgress
2020-01-11 10:22:07.511 Info, WriteNextMsg Controller nothing to do
2020-01-11 10:22:07.968 Detail, Received: 0x01, 0x05, 0x00, 0x48, 0x97, 0x21, 0x04
2020-01-11 10:22:07.968 Info, REQUEST_NEIGHBOR_UPDATE_STARTED
2020-01-11 10:22:07.968 Detail, Notification: ControllerCommand - InProgress
2020-01-11 10:22:14.921 Detail, Received: 0x01, 0x05, 0x00, 0x48, 0x97, 0x22, 0x07
2020-01-11 10:22:14.922 Detail,
2020-01-11 10:22:14.922 Info, REQUEST_NEIGHBOR_UPDATE_DONE
2020-01-11 10:22:14.922 Detail, Requesting routing info (neighbor list) for Node 22
2020-01-11 10:22:14.922 Detail, Node022, Queuing (Command) Get Routing Info (Node=22): 0x01, 0x07, 0x00, 0x80, 0x16, 0x00, 0x00, 0x03, 0x6d
2020-01-11 10:22:14.922 Detail, Notification: ControllerCommand - Completed
2020-01-11 10:22:14.923 Detail,
2020-01-11 10:22:14.923 Info, Node022, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=22): 0x01, 0x07, 0x00, 0x80, 0x16, 0x00, 0x00, 0x03, 0x6d
2020-01-11 10:22:14.931 Detail, Node022, Received: 0x01, 0x20, 0x01, 0x80, 0x01, 0x02, 0x1c, 0xf4, 0x12, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xa7
2020-01-11 10:22:14.932 Detail,
2020-01-11 10:22:14.932 Info, Node022, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2020-01-11 10:22:14.932 Info, Node022, Neighbors of this node are:
2020-01-11 10:22:14.932 Info, Node022, Node 1
2020-01-11 10:22:14.932 Info, Node022, Node 10
2020-01-11 10:22:14.932 Info, Node022, Node 19
2020-01-11 10:22:14.932 Info, Node022, Node 20
2020-01-11 10:22:14.932 Info, Node022, Node 21
2020-01-11 10:22:14.932 Info, Node022, Node 27
2020-01-11 10:22:14.932 Info, Node022, Node 29
2020-01-11 10:22:14.932 Info, Node022, Node 30
2020-01-11 10:22:14.932 Info, Node022, Node 31
2020-01-11 10:22:14.932 Info, Node022, Node 32
2020-01-11 10:22:14.932 Info, Node022, Node 34
2020-01-11 10:22:14.933 Info, Node022, Node 37
2020-01-11 10:22:14.933 Detail, Node002, Expected reply was received
2020-01-11 10:22:14.933 Detail, Node002, Message transaction complete
2020-01-11 10:22:14.933 Detail, Node022, Removing current message
2020-01-11 10:22:14.933 Info, Requesting Neighbor Update for node 27
2020-01-11 10:22:14.933 Detail, Node027, Queuing (Command) ControllerCommand_RequestNodeNeighborUpdate (Node=27): 0x01, 0x05, 0x00, 0x48, 0x1b, 0x98, 0x31
2020-01-11 10:22:14.933 Detail, Notification: ControllerCommand - Starting
2020-01-11 10:22:14.934 Detail,
2020-01-11 10:22:14.934 Info, Node027, Sending (Command) message (Callback ID=0x98, Expected Reply=0x48) - ControllerCommand_RequestNodeNeighborUpdate (Node=27): 0x01, 0x05, 0x00, 0x48, 0x1b, 0x98, 0x31
2020-01-11 10:22:14.964 Detail, Node027, Received: 0x01, 0x05, 0x00, 0x48, 0x98, 0x21, 0x0b
2020-01-11 10:22:14.964 Info, Node027, REQUEST_NEIGHBOR_UPDATE_STARTED
2020-01-11 10:22:14.964 Detail, Node033, Expected callbackId was received
2020-01-11 10:22:14.964 Detail, Node033, Expected reply was received
2020-01-11 10:22:14.965 Detail, Node033, Message transaction complete
2020-01-11 10:22:14.965 Detail, Node027, Removing current message
2020-01-11 10:22:14.965 Detail, Notification: ControllerCommand - InProgress
2020-01-11 10:22:14.965 Info, WriteNextMsg Controller nothing to do
2020-01-11 10:22:15.158 Detail, Received: 0x01, 0x05, 0x00, 0x48, 0x98, 0x21, 0x0b
2020-01-11 10:22:15.158 Info, REQUEST_NEIGHBOR_UPDATE_STARTED
2020-01-11 10:22:15.158 Detail, Notification: ControllerCommand - InProgress
2020-01-11 10:22:20.001 Detail, Node027, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x1b, 0x06, 0x31, 0x05, 0x01, 0x2a, 0x02, 0xb2, 0x45
2020-01-11 10:22:20.001 Info, Node027, Received SensorMultiLevel report from node 27, instance 1, Temperature: value=69.0F
2020-01-11 10:22:20.002 Detail, Node027, Refreshed Value: old value=69.0, new value=69.0, type=decimal
2020-01-11 10:22:20.002 Detail, Node027, Changes to this value are not verified
2020-01-11 10:22:20.002 Detail, Node027, Notification: ValueChanged
2020-01-11 10:22:20.029 Detail, Node027, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x1b, 0x06, 0x31, 0x05, 0x05, 0x22, 0x01, 0x2c, 0xd4
2020-01-11 10:22:20.029 Info, Node027, Received SensorMultiLevel report from node 27, instance 1, Relative Humidity: value=30.0%
2020-01-11 10:22:20.029 Detail, Node027, Initial read of value
2020-01-11 10:22:20.029 Detail, Node027, Notification: ValueChanged
2020-01-11 10:22:20.056 Detail, Node027, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x1b, 0x06, 0x43, 0x03, 0x01, 0x2a, 0x02, 0xb2, 0x31
2020-01-11 10:22:20.057 Detail,
2020-01-11 10:22:20.057 Detail, Node027, Refreshed Value: old value=69.0, new value=69.0, type=decimal
2020-01-11 10:22:20.057 Detail, Node027, Changes to this value are not verified
2020-01-11 10:22:20.057 Info, Node027, Received thermostat setpoint report: Setpoint Heating 1 = 69.0F
2020-01-11 10:22:20.057 Detail, Node027, Notification: ValueChanged
2020-01-11 10:22:20.083 Detail, Node027, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x1b, 0x03, 0x44, 0x03, 0x00, 0xad
2020-01-11 10:22:20.083 Detail, Node027, Refreshed Value: old value=0, new value=0, type=list
2020-01-11 10:22:20.083 Detail, Node027, Changes to this value are not verified
2020-01-11 10:22:20.083 Info, Node027, Received thermostat fan mode: Auto Low
2020-01-11 10:22:20.083 Detail, Node027, Notification: ValueChanged
2020-01-11 10:22:43.240 Detail, Node010, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x0a, 0x02, 0x84, 0x07, 0x78
2020-01-11 10:22:43.241 Detail,
2020-01-11 10:22:43.241 Info, Node010, Received Wakeup Notification from node 10
2020-01-11 10:22:43.241 Info, Node010, Node 10 has been marked as awake
2020-01-11 10:22:43.241 Detail, Node010, Queuing (Controller) Delete All Return Routes
2020-01-11 10:22:43.241 Detail, Node010, Queuing (Controller) Assign Return Route
2020-01-11 10:22:43.241 Detail, Node010, Queuing (Query) Query Stage Complete (CacheLoad)
2020-01-11 10:22:43.241 Detail, Node010, Queuing (Controller) Request Node Neighbor Update
2020-01-11 10:22:43.241 Detail, Node010, Notification: Notification - Node Awake
2020-01-11 10:22:43.247 Info, WriteNextMsg Controller nothing to do
2020-01-11 10:22:45.960 Detail, Received: 0x01, 0x05, 0x00, 0x48, 0x98, 0x22, 0x08
2020-01-11 10:22:45.961 Detail,
2020-01-11 10:22:45.961 Info, REQUEST_NEIGHBOR_UPDATE_DONE
2020-01-11 10:22:45.961 Detail, Requesting routing info (neighbor list) for Node 27
2020-01-11 10:22:45.961 Detail, Node027, Queuing (Command) Get Routing Info (Node=27): 0x01, 0x07, 0x00, 0x80, 0x1b, 0x00, 0x00, 0x03, 0x60
2020-01-11 10:22:45.961 Detail, Notification: ControllerCommand - Completed
2020-01-11 10:22:45.962 Detail,
2020-01-11 10:22:45.962 Info, Node027, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=27): 0x01, 0x07, 0x00, 0x80, 0x1b, 0x00, 0x00, 0x03, 0x60
2020-01-11 10:22:45.970 Detail, Node027, Received: 0x01, 0x20, 0x01, 0x80, 0x01, 0x00, 0x30, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xaf
2020-01-11 10:22:45.971 Info, Node027, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2020-01-11 10:22:45.971 Info, Node027, Neighbors of this node are:
2020-01-11 10:22:45.971 Info, Node027, Node 1
2020-01-11 10:22:45.971 Info, Node027, Node 21
2020-01-11 10:22:45.971 Info, Node027, Node 22
2020-01-11 10:22:45.971 Info, Node027, Node 31
2020-01-11 10:22:45.971 Info, Node027, Node 32
2020-01-11 10:22:45.971 Detail, Expected reply was received
2020-01-11 10:22:45.971 Detail, Message transaction complete
2020-01-11 10:22:45.971 Detail, Node027, Removing current message
2020-01-11 10:22:45.971 Info, Requesting Neighbor Update for node 29
2020-01-11 10:22:45.972 Detail,
2020-01-11 10:22:45.972 Detail, Node029, Queuing (Controller) Request Node Neighbor Update
2020-01-11 10:22:45.972 Detail, Notification: ControllerCommand - Starting
2020-01-11 10:22:45.972 Detail, Notification: ControllerCommand - Sleeping
2020-01-11 10:22:45.973 Info, Requesting Neighbor Update for node 30
2020-01-11 10:22:45.973 Detail,
2020-01-11 10:22:45.973 Detail, Node030, Queuing (Controller) Request Node Neighbor Update
2020-01-11 10:22:45.973 Detail, Notification: ControllerCommand - Starting
2020-01-11 10:22:45.973 Detail, Notification: ControllerCommand - Sleeping
2020-01-11 10:22:45.974 Info, Requesting Neighbor Update for node 31
2020-01-11 10:22:45.974 Detail, Node031, Queuing (Command) ControllerCommand_RequestNodeNeighborUpdate (Node=31): 0x01, 0x05, 0x00, 0x48, 0x1f, 0x9b, 0x36
2020-01-11 10:22:45.974 Detail, Notification: ControllerCommand - Starting
2020-01-11 10:22:45.975 Detail,
2020-01-11 10:22:45.975 Info, Node031, Sending (Command) message (Callback ID=0x9b, Expected Reply=0x48) - ControllerCommand_RequestNodeNeighborUpdate (Node=31): 0x01, 0x05, 0x00, 0x48, 0x1f, 0x9b, 0x36
2020-01-11 10:22:46.005 Detail, Node031, Received: 0x01, 0x05, 0x00, 0x48, 0x9b, 0x21, 0x08
2020-01-11 10:22:46.006 Detail,
2020-01-11 10:22:46.006 Info, Node031, REQUEST_NEIGHBOR_UPDATE_STARTED
2020-01-11 10:22:46.006 Detail, Node033, Expected callbackId was received
2020-01-11 10:22:46.006 Detail, Node033, Expected reply was received
2020-01-11 10:22:46.006 Detail, Node033, Message transaction complete
2020-01-11 10:22:46.006 Detail, Node031, Removing current message
2020-01-11 10:22:46.006 Detail, Notification: ControllerCommand - InProgress
2020-01-11 10:22:46.010 Info, WriteNextMsg Controller nothing to do
2020-01-11 10:22:46.281 Detail, Received: 0x01, 0x05, 0x00, 0x48, 0x9b, 0x21, 0x08
2020-01-11 10:22:46.281 Info, REQUEST_NEIGHBOR_UPDATE_STARTED
2020-01-11 10:22:46.281 Detail, Notification: ControllerCommand - InProgress
2020-01-11 10:22:52.805 Detail, Received: 0x01, 0x05, 0x00, 0x48, 0x9b, 0x22, 0x0b
2020-01-11 10:22:52.806 Detail,
2020-01-11 10:22:52.806 Info, REQUEST_NEIGHBOR_UPDATE_DONE
2020-01-11 10:22:52.806 Detail, Requesting routing info (neighbor list) for Node 31
2020-01-11 10:22:52.806 Detail, Node031, Queuing (Command) Get Routing Info (Node=31): 0x01, 0x07, 0x00, 0x80, 0x1f, 0x00, 0x00, 0x03, 0x64
2020-01-11 10:22:52.806 Detail, Notification: ControllerCommand - Completed
2020-01-11 10:22:52.807 Detail,
2020-01-11 10:22:52.807 Info, Node031, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=31): 0x01, 0x07, 0x00, 0x80, 0x1f, 0x00, 0x00, 0x03, 0x64
2020-01-11 10:22:52.815 Detail, Node031, Received: 0x01, 0x20, 0x01, 0x80, 0x01, 0x02, 0x3c, 0xb4, 0x12, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc7
2020-01-11 10:22:52.815 Info, Node031, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2020-01-11 10:22:52.815 Info, Node031, Neighbors of this node are:
2020-01-11 10:22:52.815 Info, Node031, Node 1
2020-01-11 10:22:52.816 Info, Node031, Node 10
2020-01-11 10:22:52.816 Info, Node031, Node 19
2020-01-11 10:22:52.816 Info, Node031, Node 20
2020-01-11 10:22:52.816 Info, Node031, Node 21
2020-01-11 10:22:52.816 Info, Node031, Node 22
2020-01-11 10:22:52.816 Info, Node031, Node 27
2020-01-11 10:22:52.816 Info, Node031, Node 29
2020-01-11 10:22:52.816 Info, Node031, Node 30
2020-01-11 10:22:52.816 Info, Node031, Node 32
2020-01-11 10:22:52.816 Info, Node031, Node 34
2020-01-11 10:22:52.816 Info, Node031, Node 37
2020-01-11 10:22:52.816 Detail, Node002, Expected reply was received
2020-01-11 10:22:52.816 Detail, Node002, Message transaction complete
2020-01-11 10:22:52.817 Detail, Node031, Removing current message
2020-01-11 10:22:52.817 Info, Requesting Neighbor Update for node 32
2020-01-11 10:22:52.817 Detail, Node032, Queuing (Command) ControllerCommand_RequestNodeNeighborUpdate (Node=32): 0x01, 0x05, 0x00, 0x48, 0x20, 0x9c, 0x0e
2020-01-11 10:22:52.817 Detail, Notification: ControllerCommand - Starting
2020-01-11 10:22:52.818 Detail,
2020-01-11 10:22:52.818 Info, Node032, Sending (Command) message (Callback ID=0x9c, Expected Reply=0x48) - ControllerCommand_RequestNodeNeighborUpdate (Node=32): 0x01, 0x05, 0x00, 0x48, 0x20, 0x9c, 0x0e
2020-01-11 10:22:52.848 Detail, Node032, Received: 0x01, 0x05, 0x00, 0x48, 0x9c, 0x21, 0x0f
2020-01-11 10:22:52.848 Info, Node032, REQUEST_NEIGHBOR_UPDATE_STARTED
2020-01-11 10:22:52.849 Detail, Node033, Expected callbackId was received
2020-01-11 10:22:52.849 Detail, Node033, Expected reply was received
2020-01-11 10:22:52.849 Detail, Node033, Message transaction complete
2020-01-11 10:22:52.849 Detail, Node032, Removing current message
2020-01-11 10:22:52.849 Detail, Notification: ControllerCommand - InProgress
2020-01-11 10:22:52.849 Info, WriteNextMsg Controller nothing to do
2020-01-11 10:22:53.490 Detail, Received: 0x01, 0x05, 0x00, 0x48, 0x9c, 0x21, 0x0f
2020-01-11 10:22:53.491 Info, REQUEST_NEIGHBOR_UPDATE_STARTED
2020-01-11 10:22:53.491 Detail, Notification: ControllerCommand - InProgress
2020-01-11 10:22:53.778 Detail, Received: 0x01, 0x05, 0x00, 0x48, 0x9c, 0x21, 0x0f
2020-01-11 10:22:53.778 Info, REQUEST_NEIGHBOR_UPDATE_STARTED
2020-01-11 10:22:53.778 Detail, Notification: ControllerCommand - InProgress
2020-01-11 10:23:04.633 Detail, Received: 0x01, 0x05, 0x00, 0x48, 0x9c, 0x22, 0x0c
2020-01-11 10:23:04.634 Detail,
2020-01-11 10:23:04.634 Info, REQUEST_NEIGHBOR_UPDATE_DONE
2020-01-11 10:23:04.634 Detail, Requesting routing info (neighbor list) for Node 32
2020-01-11 10:23:04.634 Detail, Node032, Queuing (Command) Get Routing Info (Node=32): 0x01, 0x07, 0x00, 0x80, 0x20, 0x00, 0x00, 0x03, 0x5b
2020-01-11 10:23:04.634 Detail, Notification: ControllerCommand - Completed
2020-01-11 10:23:04.635 Detail,
2020-01-11 10:23:04.635 Info, Node032, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=32): 0x01, 0x07, 0x00, 0x80, 0x20, 0x00, 0x00, 0x03, 0x5b
2020-01-11 10:23:04.643 Detail, Node032, Received: 0x01, 0x20, 0x01, 0x80, 0x01, 0x02, 0x28, 0x64, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x13
2020-01-11 10:23:04.643 Info, Node032, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2020-01-11 10:23:04.644 Info, Node032, Neighbors of this node are:
2020-01-11 10:23:04.644 Info, Node032, Node 1
2020-01-11 10:23:04.644 Info, Node032, Node 10
2020-01-11 10:23:04.644 Info, Node032, Node 20
2020-01-11 10:23:04.644 Info, Node032, Node 22
2020-01-11 10:23:04.644 Info, Node032, Node 27
2020-01-11 10:23:04.644 Info, Node032, Node 30
2020-01-11 10:23:04.644 Info, Node032, Node 31
2020-01-11 10:23:04.644 Info, Node032, Node 34
2020-01-11 10:23:04.644 Detail, Node002, Expected reply was received
2020-01-11 10:23:04.644 Detail, Node002, Message transaction complete
2020-01-11 10:23:04.644 Detail, Node032, Removing current message
2020-01-11 10:23:12.798 Info, Requesting Neighbor Update for node 37
2020-01-11 10:23:12.798 Detail, Node037, Queuing (Command) ControllerCommand_RequestNodeNeighborUpdate (Node=37): 0x01, 0x05, 0x00, 0x48, 0x25, 0x9e, 0x09
2020-01-11 10:23:12.798 Detail, Notification: ControllerCommand - Starting
2020-01-11 10:23:12.799 Info, Node037, Sending (Command) message (Callback ID=0x9e, Expected Reply=0x48) - ControllerCommand_RequestNodeNeighborUpdate (Node=37): 0x01, 0x05, 0x00, 0x48, 0x25, 0x9e, 0x09
2020-01-11 10:23:12.829 Detail, Node037, Received: 0x01, 0x05, 0x00, 0x48, 0x9e, 0x21, 0x0d
2020-01-11 10:23:12.829 Info, Node037, REQUEST_NEIGHBOR_UPDATE_STARTED
2020-01-11 10:23:12.829 Detail, Node033, Expected callbackId was received
2020-01-11 10:23:12.829 Detail, Node033, Expected reply was received
2020-01-11 10:23:12.829 Detail, Node033, Message transaction complete
2020-01-11 10:23:12.829 Detail, Node037, Removing current message
2020-01-11 10:23:12.830 Detail, Notification: ControllerCommand - InProgress
2020-01-11 10:23:12.830 Info, WriteNextMsg Controller nothing to do
2020-01-11 10:23:14.823 Detail, Received: 0x01, 0x05, 0x00, 0x48, 0x9e, 0x21, 0x0d
2020-01-11 10:23:14.824 Detail,
2020-01-11 10:23:14.824 Info, REQUEST_NEIGHBOR_UPDATE_STARTED
2020-01-11 10:23:14.824 Detail, Notification: ControllerCommand - InProgress
2020-01-11 10:23:20.947 Detail, Received: 0x01, 0x05, 0x00, 0x48, 0x9e, 0x22, 0x0e
2020-01-11 10:23:20.948 Detail,
2020-01-11 10:23:20.948 Info, REQUEST_NEIGHBOR_UPDATE_DONE
2020-01-11 10:23:20.948 Detail, Requesting routing info (neighbor list) for Node 37
2020-01-11 10:23:20.948 Detail, Node037, Queuing (Command) Get Routing Info (Node=37): 0x01, 0x07, 0x00, 0x80, 0x25, 0x00, 0x00, 0x03, 0x5e
2020-01-11 10:23:20.948 Detail, Notification: ControllerCommand - Completed
2020-01-11 10:23:20.949 Detail,
2020-01-11 10:23:20.949 Info, Node037, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=37): 0x01, 0x07, 0x00, 0x80, 0x25, 0x00, 0x00, 0x03, 0x5e
2020-01-11 10:23:20.957 Detail, Node037, Received: 0x01, 0x20, 0x01, 0x80, 0x00, 0x00, 0x3c, 0x44, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x24
2020-01-11 10:23:20.957 Info, Node037, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2020-01-11 10:23:20.957 Info, Node037, Neighbors of this node are:
2020-01-11 10:23:20.957 Info, Node037, Node 19
2020-01-11 10:23:20.957 Info, Node037, Node 20
2020-01-11 10:23:20.957 Info, Node037, Node 21
2020-01-11 10:23:20.957 Info, Node037, Node 22
2020-01-11 10:23:20.957 Info, Node037, Node 27
2020-01-11 10:23:20.957 Info, Node037, Node 31
2020-01-11 10:23:20.957 Info, Node037, Node 34
2020-01-11 10:23:20.957 Detail, Expected reply was received
2020-01-11 10:23:20.958 Detail, Message transaction complete
2020-01-11 10:23:20.958 Detail, Node037, Removing current message
2020-01-11 10:23:20.958 Info, Deleting all return routes from node 10
