Any idea as to why I am getting these errors? I’ve had similar errors in 0.38.x, but just did an AIO rebuild on 0.39.1 and am still seeing these messages:
17-02-28 01:40:19 ERROR (Thread-4) [somecomfort] API returned 500 from /Device/CheckDataSession/624305 request
17-02-28 01:40:19 ERROR (MainThread) [homeassistant.components.climate] Error while update entity from honeywell in climate
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 396, in _update_entity_states
yield from update_coro
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/entity.py", line 212, in async_update_ha_state
yield from self.hass.loop.run_in_executor(None, self.update)
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/climate/honeywell.py", line 279, in update
self._device.refresh()
File "/home/homeassistant/.homeassistant/deps/somecomfort/client.py", line 87, in refresh
data = self._client._get_thermostat_data(self.deviceid)
File "/home/homeassistant/.homeassistant/deps/somecomfort/client.py", line 449, in _get_thermostat_data
return self._get_json(url)
File "/home/homeassistant/.homeassistant/deps/somecomfort/client.py", line 425, in _get_json
return self._request_json('get', *args, **kwargs)
File "/home/homeassistant/.homeassistant/deps/somecomfort/client.py", line 422, in _request_json
resp.status_code))
somecomfort.client.APIError: Unexpected 500 response from API
17-02-28 02:31:23 ERROR (MainThread) [homeassistant.components.climate] Error while update entity from honeywell in climate
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 386, in _make_request
six.raise_from(e, None)
File "<string>", line 2, in raise_from
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 382, in _make_request
httplib_response = conn.getresponse()
File "/usr/lib/python3.4/http/client.py", line 1172, in getresponse
response.begin()
File "/usr/lib/python3.4/http/client.py", line 351, in begin
version, status, reason = self._read_status()
File "/usr/lib/python3.4/http/client.py", line 313, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
File "/usr/lib/python3.4/socket.py", line 371, in readinto
return self._sock.recv_into(b)
File "/usr/lib/python3.4/ssl.py", line 745, in recv_into
return self.read(nbytes, buffer)
File "/usr/lib/python3.4/ssl.py", line 617, in read
v = self._sslobj.read(len, buffer)
socket.timeout: The read operation timed out
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/adapters.py", line 423, in send
timeout=timeout
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 649, in urlopen
_stacktrace=sys.exc_info()[2])
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/packages/urllib3/util/retry.py", line 347, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/packages/urllib3/packages/six.py", line 686, in reraise
raise value
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 388, in _make_request
self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 308, in _raise_timeout
raise ReadTimeoutError(self, url, "Read timed out. (read timeout=%s)" % timeout_value)
requests.packages.urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='www.mytotalconnectcomfort.com', port=443): Read timed out. (read timeout=30)
File "/home/homeassistant/.homeassistant/deps/somecomfort/client.py", line 448, in _get_thermostat_data
with self._retries_login():
File "/usr/lib/python3.4/contextlib.py", line 59, in __enter__
return next(self.gen)
File "/home/homeassistant/.homeassistant/deps/somecomfort/client.py", line 433, in _retries_login
self.keepalive()
File "/home/homeassistant/.homeassistant/deps/somecomfort/client.py", line 473, in keepalive
resp = self._session.get(url, timeout=self._timeout)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/sessions.py", line 501, in get
return self.request('GET', url, **kwargs)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/sessions.py", line 488, in request
resp = self.send(prep, **send_kwargs)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/sessions.py", line 609, in send
r = adapter.send(request, **kwargs)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/adapters.py", line 499, in send
raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPSConnectionPool(host='www.mytotalconnectcomfort.com', port=443): Read timed out. (read timeout=30)
17-02-28 02:31:59 ERROR (Thread-7) [somecomfort] API returned 500 from /Device/CheckDataSession/624305 request
17-02-28 02:31:59 ERROR (MainThread) [homeassistant.components.climate] Error while update entity from honeywell in climate
resp.status_code))
17-02-28 07:38:06 ERROR (Thread-3) [somecomfort] API returned 500 from /Device/CheckDataSession/624305 request
17-02-28 07:38:06 ERROR (MainThread) [homeassistant.components.climate] Error while update entity from honeywell in climate
resp.status_code))
17-02-28 08:00:21 ERROR (Thread-12) [somecomfort] API returned 500 from /Device/CheckDataSession/624305 request
17-02-28 08:00:21 ERROR (MainThread) [homeassistant.components.climate] Error while update entity from honeywell in climate
resp.status_code))
17-02-28 09:28:49 ERROR (Thread-4) [somecomfort] API returned 500 from /Device/CheckDataSession/624305 request
17-02-28 09:28:49 ERROR (MainThread) [homeassistant.components.climate] Error while update entity from honeywell in climate
resp.status_code))
17-02-28 09:38:57 ERROR (Thread-5) [somecomfort] Failed to de-JSON /Device/CheckDataSession/624305 response
File "/home/homeassistant/.homeassistant/deps/somecomfort/client.py", line 400, in _resp_json
return resp.json()
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/models.py", line 866, in json
return complexjson.loads(self.text, **kwargs)
File "/usr/lib/python3.4/json/__init__.py", line 318, in loads
return _default_decoder.decode(s)
File "/usr/lib/python3.4/json/decoder.py", line 343, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python3.4/json/decoder.py", line 361, in raw_decode
raise ValueError(errmsg("Expecting value", s, err.value)) from None
ValueError: Expecting value: line 1 column 1 (char 0)
17-02-28 09:38:57 ERROR (MainThread) [homeassistant.components.climate] Error while update entity from honeywell in climate
return resp.json()
File "/home/homeassistant/.homeassistant/deps/somecomfort/client.py", line 415, in _request_json
return self._resp_json(resp, req)
File "/home/homeassistant/.homeassistant/deps/somecomfort/client.py", line 405, in _resp_json
raise APIError('Failed to process %s response', req)
somecomfort.client.APIError: ('Failed to process %s response', '/Device/CheckDataSession/624305')
17-02-28 09:54:12 ERROR (Thread-7) [somecomfort] API returned 500 from /Device/CheckDataSession/624305 request
17-02-28 09:54:12 ERROR (MainThread) [homeassistant.components.climate] Error while update entity from honeywell in climate
resp.status_code))
17-02-28 15:10:16 ERROR (Thread-1) [somecomfort] API returned 500 from /Device/CheckDataSession/624305 request
17-02-28 15:10:16 ERROR (MainThread) [homeassistant.components.climate] Error while update entity from honeywell in climate
resp.status_code))
17-02-28 16:27:27 ERROR (Thread-12) [somecomfort] API returned 500 from /Device/CheckDataSession/624305 request
17-02-28 16:27:27 ERROR (MainThread) [homeassistant.components.climate] Error while update entity from honeywell in climate
resp.status_code))
