I use the current Honeywell WIFI Thermostat integration. The product I use has the ability to integrate an externally connected sensor to return the local outside temperature and humidity. The somecomfort client library is written to return these attributes if the sensor data is available. I would like to see them also included in the Home Assistant integration. It would seem to be a simple addition and would eliminate the need for redundant system components to integrate local weather data.
Agreed, and seconded. I have the same system, and it is a great tool but it is somewhat useless unless I am standing in front of my thermostat. Would love to have it part of HA.
Yes, please. Outdoor temp and humidity sensors would be awesome. It looks like the somecomfort library can expose the data.
I also would like to be able to see my outdoor temp and humidity in home assistant.
I agree, outdoor temp and humidity would be wonderful
Add this please!
I tried making a copy of the climate component and adding to custom components and changing a few lines for outdoor but cannot get it working. not sure how to see if it’s in the somecomfort library or not.
Guess it isnt as simple as this :
@property
def outdoor_temperature(self) -> Optional[float]:
"""Return the current outdoor temperature."""
return self._device.outdoor_temperature
@property
def outdoor_humidity(self) -> Optional[int]:
"""Return the current outdoor humidity."""
return self._device.outdoor_humidity
@contactcr contractcr, I tried the same as you, no luck. I think outdoor temp and humidity may need to be added as a weather component, I don’t think the climate component in home-assistant has these attributes. Ecobee integration seems to use a weather.py file to get forecast attributes, maybe someone can implement similar for honeywell platform?
Looking at this further, the Netatmo and Fibaro integrations use sensor.py files to get outdoor temp and humidity, this looks promising.
Hey guys, I also have this thermostat and would love to see sensors for outdoor temperature and humidity. Unless @contactcr or @Hackashaq666 feel they are close to a solution already, I’d be happy to work on this as a contribution to home-assistant/core.
Go for it!
I just use openweathermap for current temp and it’s close enough for me. I compare outside temp to current temp in house and alert when I should open windows.
I’m using openweathermap now for outside climate and have found it to be pretty far off at times.
Any love on this?
I just got a honeywell system and recently discovered home assistant. I had the same wish, to be able to display the outdoor sensors. I started working on this. I had to rearrange the code a bit, but I have it somewhat working on my system. There’s still some stability issues that I still need to fix related to hitting the honeywell api too many times and getting blocked. I also want to add proper humidification support, although it appears the somecomfort library doesn’t have that.
Created https://github.com/home-assistant/core/pull/42381/. Let’s see what they think. This is my first home assistant contribution, so it may take some back and forth.
Hi @cfairfax, I have been using your “work in progress” for a couple of days as a custom component. Thanks for working on this! I am looking forward to you improving the stability, since it does become “unavailable” to home-assistant after a few hours. It would be great to have this accepted as a PR in home-assistant, but a custom component could be a short-term option for many users if the configuration requirements for a PR are an obstacle.
Thanks for testing out my change! I think I fixed the stability thing by bringing back the code that automatically retried the updates when it failed. I updated the branch. Can you try copying that into your custom_components and try it for a bit and let me know if it works better for you?
I’ll update and let you know if stable for me. Thanks again!
So far, your updated branch is working well for me as a custom component!
No stability issues so for over 10 hours.
My thermostat just became unavailable after 4 days.
Logger: custom_components.honeywell
Source: custom_components/honeywell/__init__.py:61
Integration: Honeywell Total Connect Comfort (US) (documentation)
First occurred: November 6, 2020, 8:38:19 PM (56 occurrences)
Last logged: 8:33:40 PM
SomeComfort update failed. Trying again - Error: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
SomeComfort update failed. Trying again - Error: You are being rate-limited. Try waiting a bit.
After restarting, it was stable for 3 more days but became unavailable again:
Source: helpers/update_coordinator.py:166
First occurred: 7:31:58 AM (1 occurrences)
Last logged: 7:31:58 AM
Error fetching honeywell_update_coordinator data: You are being rate-limited. Try waiting a bit.
Logger: somecomfort
Source: /usr/local/lib/python3.8/site-packages/somecomfort/client.py:404
First occurred: 8:56:58 AM (9 occurrences)
Last logged: 9:07:01 AM
Login as [email protected] failed
Source: custom_components/honeywell/__init__.py:50
First occurred: 8:56:59 AM (3 occurrences)
Unexpected error fetching honeywell_update_coordinator data: Login failed
File "/usr/local/lib/python3.8/site-packages/somecomfort/client.py", line 452, in _retries_login
self.keepalive()
File "/usr/local/lib/python3.8/site-packages/somecomfort/client.py", line 495, in keepalive
raise SessionTimedOut('Session timed out')
somecomfort.client.SessionTimedOut: Session timed out
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 144, in async_refresh
self.data = await self._async_update_data()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 132, in _async_update_data
return await self.update_method()
File "/config/custom_components/honeywell/__init__.py", line 127, in async_update_data
await __some_comfort_refresh_async_wrap(device)
File "/config/custom_components/honeywell/__init__.py", line 40, in run
return await loop.run_in_executor(executor, pfunc)
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/config/custom_components/honeywell/__init__.py", line 60, in __some_comfort_refresh_async_wrap
raise exp
File "/config/custom_components/honeywell/__init__.py", line 50, in __some_comfort_refresh_async_wrap
device.refresh()
File "/usr/local/lib/python3.8/site-packages/somecomfort/client.py", line 87, in refresh
data = self._client._get_thermostat_data(self.deviceid)
File "/usr/local/lib/python3.8/site-packages/somecomfort/client.py", line 467, in _get_thermostat_data
with self._retries_login():
File "/usr/local/lib/python3.8/contextlib.py", line 113, in __enter__
return next(self.gen)
File "/usr/local/lib/python3.8/site-packages/somecomfort/client.py", line 454, in _retries_login
self._login()
File "/usr/local/lib/python3.8/site-packages/somecomfort/client.py", line 49, in wrapper
return fn(*args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/somecomfort/client.py", line 405, in _login
raise AuthError('Login failed')
somecomfort.client.AuthError: Login failed
