Recently my honeywell thermostats at my home not longer connected to the HA. Anyone noticed any changes. I can still control using the website from Homewell home and app but not via HA intregration. What change? My configuration has same as before:
climate:
Mine are working. Basically the same config as you, except I don’t use a !secret file, and I set scan_interval to 180.
I’ve found that without scan_interval I get rate-limited. I’d be interested to hear what works for others, and whether you see errors about rate limiting in the log. I have three thermostats, and I never knew whether HA made one API call for all three, or if my HA makes three times as many calls as someone with only one thermostat.
