Here is an example of the error in the Logs.
My automation runs, selects one of the logic options to change the Preset on the thermostat for the room. Then subsequently the Honeywell cloud is not responding to HA’s request to change the thermostat.
Logger: homeassistant.components.automation.room_9_timer_closed_hvac_on
Source: helpers/script.py:1918
integration: Automation (documentation, issues)
First occurred: 10:05:03 AM (3 occurrences)
Last logged: 10:05:03 AM
Room_9_Timer_Closed_HVAC_On: Choose at step 1: choice 2: Choose at step 1: choice 3: Error executing script. Error for device at pos 1: Honeywell could not set system mode.
Room_9_Timer_Closed_HVAC_On: Choose at step 1: choice 2: Error executing script. Error for choose at pos 1: Honeywell could not set system mode.
Room_9_Timer_Closed_HVAC_On: Error executing script. Error for choose at pos 1: Honeywell could not set system mode.
Logger: somecomfort
Source: components/honeywell/climate.py:523
First occurred: April 9, 2024 at 5:01:37 AM (509 occurrences)
Last logged: 10:24:18 AM
Service Unavailable 200, (<ClientResponse(https://www.mytotalconnectcomfort.com/portal/Device/CheckDataSession/8770685) [302 Found]> <CIMultiDictProxy('Cache-Control': 'private, s-maxage=0', 'Content-Type': 'text/html; charset=utf-8', 'Location': '/portal/Error?aspxerrorpath=/portal/Device/CheckDataSession/8770685', 'Server': 'Microsoft-IIS/8.5', 'ADRUM_0': 'g:22d4cd2d-f0f7-48f2-a414-f209c472366f', 'ADRUM_1': 'XXXXXXXXXXXXXXXXXXXXXX', 'ADRUM_2': 'i:197974', 'ADRUM_3': 'e:126', 'X-Frame-Options': 'DENY', 'X-XSS-Protection': '1; mode=block', 'X-UA-Compatible': 'IE=edge', 'Date': 'Thu, 11 Apr 2024 17:19:46 GMT', 'Content-Length': '184', 'Set-Cookie': 'XXXXXXXXXXXXXXXXXXXXXX;expires=Thu, 11-Apr-2024 17:21:47 GMT;path=/;secure;httponly')> ,).
Service Unavailable 200, (<ClientResponse(https://www.mytotalconnectcomfort.com/portal/Device/CheckDataSession/8767023) [302 Found]> <CIMultiDictProxy('Cache-Control': 'private, s-maxage=0', 'Content-Type': 'text/html; charset=utf-8', 'Location': '/portal/Error?aspxerrorpath=/portal/Device/CheckDataSession/8767023', 'Server': 'Microsoft-IIS/8.5', 'ADRUM_0': 'g:12d2faba-b164-42f4-9e0b-7ae884e5f0a3', 'ADRUM_1': 'XXXXXXXXXXXXXXXXXXXXXX', 'ADRUM_2': 'i:197974', 'ADRUM_3': 'e:126', 'X-Frame-Options': 'DENY', 'X-XSS-Protection': '1; mode=block', 'X-UA-Compatible': 'IE=edge', 'Date': 'Thu, 11 Apr 2024 17:19:49 GMT', 'Content-Length': '184', 'Set-Cookie': 'XXXXXXXXXXXXXXXXXXXXXX;expires=Thu, 11-Apr-2024 17:21:50 GMT;path=/;secure;httponly')> ,).
Service Unavailable 200, (<ClientResponse(https://www.mytotalconnectcomfort.com/portal/Device/CheckDataSession/8774585) [302 Found]> <CIMultiDictProxy('Cache-Control': 'private, s-maxage=0', 'Content-Type': 'text/html; charset=utf-8', 'Location': '/portal/Error?aspxerrorpath=/portal/Device/CheckDataSession/8774585', 'Server': 'Microsoft-IIS/8.5', 'ADRUM_0': 'g:bff2125c-e4af-419c-93c5-d0cf511c9a24', 'ADRUM_1': 'XXXXXXXXXXXXXXXXXXXXXX', 'ADRUM_2': 'i:197974', 'ADRUM_3': 'e:123', 'X-Frame-Options': 'DENY', 'X-XSS-Protection': '1; mode=block', 'X-UA-Compatible': 'IE=edge', 'Date': 'Thu, 11 Apr 2024 17:22:47 GMT', 'Content-Length': '184', 'Set-Cookie': 'XXXXXXXXXXXXXXXXXXXXXX;expires=Thu, 11-Apr-2024 17:24:47 GMT;path=/;secure;httponly')> ,).
Service Unavailable 200, (<ClientResponse(https://www.mytotalconnectcomfort.com/portal/Device/CheckDataSession/8433840) [302 Found]> <CIMultiDictProxy('Cache-Control': 'private, s-maxage=0', 'Content-Type': 'text/html; charset=utf-8', 'Location': '/portal/Error?aspxerrorpath=/portal/Device/CheckDataSession/8433840', 'Server': 'Microsoft-IIS/8.5', 'ADRUM_0': 'g:a9b24588-553c-4df4-b06d-b45b46a05091', 'ADRUM_1': 'XXXXXXXXXXXXXXXXXXXXXX', 'ADRUM_2': 'i:197974', 'ADRUM_3': 'e:119', 'X-Frame-Options': 'DENY', 'X-XSS-Protection': '1; mode=block', 'X-UA-Compatible': 'IE=edge', 'Date': 'Thu, 11 Apr 2024 17:23:16 GMT', 'Content-Length': '184', 'Set-Cookie': 'XXXXXXXXXXXXXXXXXXXXXX;expires=Thu, 11-Apr-2024 17:25:17 GMT;path=/;secure;httponly')> ,).
Service Unavailable 200, (<ClientResponse(https://www.mytotalconnectcomfort.com/portal/Device/CheckDataSession/8767023) [302 Found]> <CIMultiDictProxy('Cache-Control': 'private, s-maxage=0', 'Content-Type': 'text/html; charset=utf-8', 'Location': '/portal/Error?aspxerrorpath=/portal/Device/CheckDataSession/8767023', 'Server': 'Microsoft-IIS/8.5', 'ADRUM_0': 'g:afffd5f2-768f-47f4-b27f-9dab28d85f25', 'ADRUM_1': 'XXXXXXXXXXXXXXXXXXXXXX', 'ADRUM_2': 'i:197974', 'ADRUM_3': 'e:138', 'X-Frame-Options': 'DENY', 'X-XSS-Protection': '1; mode=block', 'X-UA-Compatible': 'IE=edge', 'Date': 'Thu, 11 Apr 2024 17:24:17 GMT', 'Content-Length': '184', 'Set-Cookie': 'XXXXXXXXXXXXXXXXXXXXXX;expires=Thu, 11-Apr-2024 17:26:18 GMT;path=/;secure;httponly')> ,).
