Honeywell total connect comfort (EU) not showing correct hvac mode
Dear all
I’m having a problem and do not know where to start solving it. We recently installed the european evohome system with multiple rooms which we can heat seperately. I used the honeywell total comfort connect (europe) integration. All measured temperatures and set points for all rooms are showing and if I change something from either the evohome system or in home assistant it works perfect.
However, the home assistant is for all zones always showing the hvac mode “heat”. Even when all measured temperatures are 1-2 degrees celcius above the setpoint and the boiler indicates it is turned off and is not heating.
Can someone help me in finding out how to make home assistant correctly indicate whether a zone is heating or not? I tried search the forum and google with no succes.
Searching in the home assistant logs I do find only these error message below regarding home assistant, but cannot find something which explains my problem as far as my limited experience goes:
File "/usr/local/lib/python3.8/site-packages/homeconnect/sseclient.py", line 81, in __next__
next_chunk = next(self.resp_iterator)
StopIteration
File "/usr/local/lib/python3.8/site-packages/homeconnect/api.py", line 226, in _listen
for event in sse:
File "/usr/local/lib/python3.8/site-packages/homeconnect/sseclient.py", line 91, in __next__
self._connect()
File "/usr/local/lib/python3.8/site-packages/homeconnect/sseclient.py", line 56, in _connect
self.resp = requester.get(self.url, stream=True, **self.requests_kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 555, in get
return self.request('GET', url, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests_oauthlib/oauth2_session.py", line 477, in request
url, headers, data = self._client.add_token(
File "/usr/local/lib/python3.8/site-packages/oauthlib/oauth2/rfc6749/clients/base.py", line 198, in add_token
raise TokenExpiredError()
oauthlib.oauth2.rfc6749.errors.TokenExpiredError: (token_expired)
File "/usr/local/lib/python3.8/site-packages/urllib3/response.py", line 697, in _update_chunk_length
self.chunk_left = int(line, 16)
ValueError: invalid literal for int() with base 16: b''
File "/usr/local/lib/python3.8/site-packages/urllib3/response.py", line 438, in _error_catcher
yield
File "/usr/local/lib/python3.8/site-packages/urllib3/response.py", line 764, in read_chunked
self._update_chunk_length()
File "/usr/local/lib/python3.8/site-packages/urllib3/response.py", line 701, in _update_chunk_length
raise InvalidChunkLength(self, line)
urllib3.exceptions.InvalidChunkLength: InvalidChunkLength(got length b'', 0 bytes read)
File "/usr/local/lib/python3.8/site-packages/requests/models.py", line 753, in generate
for chunk in self.raw.stream(chunk_size, decode_content=True):
File "/usr/local/lib/python3.8/site-packages/urllib3/response.py", line 572, in stream
for line in self.read_chunked(amt, decode_content=decode_content):
File "/usr/local/lib/python3.8/site-packages/urllib3/response.py", line 793, in read_chunked
self._original_response.close()
File "/usr/local/lib/python3.8/contextlib.py", line 131, in __exit__
self.gen.throw(type, value, traceback)
File "/usr/local/lib/python3.8/site-packages/urllib3/response.py", line 455, in _error_catcher
raise ProtocolError("Connection broken: %r" % e, e)
urllib3.exceptions.ProtocolError: ("Connection broken: InvalidChunkLength(got length b'', 0 bytes read)", InvalidChunkLength(got length b'', 0 bytes read))
File "/usr/local/lib/python3.8/site-packages/requests/models.py", line 756, in generate
raise ChunkedEncodingError(e)
requests.exceptions.ChunkedEncodingError: ("Connection broken: InvalidChunkLength(got length b'', 0 bytes read)", InvalidChunkLength(got length b'', 0 bytes read))
Thanks for any help in advance.
I use the US Honeywell thermostats, but perhaps there’s some similarity.
Something changed in the HA integration a while back. It seems to involve the state of the climate entity and the attribute hvac_action. Today, the hvac_action attribute shows what action the thermostat is calling for (heating, in the example below) and the state always shows “heat” while the thermostat is in “heat” mode, as opposed to “off” or “cool.”
I’m not sure I understand why this decision was taken. The mode doesn’t change much, and for a heat-only thermostat, might stay on all year. To me, the “state” of a thermostat should indicate what it’s calling for the HVAC system to do. But for some reason nobody consulted me :wink:
Anyway, here are the attributes of my Honeywell thermostat while it’s calling for heat. The “state” is showing “heat,” as of course it will be all winter. Unfortunately, when you set up a “badge” in Lovelace to show your climate entity, it displays the state, not the hvac_action.
hvac_modes:
  - 'off'
  - cool
  - heat
min_temp: 40
max_temp: 90
fan_modes:
  - 'on'
  - auto
preset_modes:
  - none
  - away
current_temperature: 70
temperature: 70
target_temp_high: null
target_temp_low: null
current_humidity: 128
fan_mode: auto
hvac_action: heating
preset_mode: null
fan_action: running
dr_phase: -1
friendly_name: 1st Floor
supported_features: 27
Thanks for the response. That might be an explanation. However, as far as I can see I do not have a hvac_action attribute. Below all attributes of one if the zones. Maybe there are some differences in EU vs US version? Anyone with an EU version with the same problem?
hvac_modes:
  - 'off'
  - heat
min_temp: 5
max_temp: 35
preset_modes:
  - none
  - temporary
  - permanent
current_temperature: 20.6
temperature: 18
preset_mode: temporary
status:
  setpoints:
    this_sp_from: '2021-01-31T08:00:00+01:00'
    next_sp_temp: 17
    next_sp_temp: 17
  zone_id: '6387066'
  active_faults: []
  setpoint_status:
    target_heat_temperature: 18
    setpoint_mode: TemporaryOverride
    until: '2021-01-31T21:00:00+01:00'
    temperature: 20.5
    is_available: true
friendly_name: living
icon: 'mdi:radiator'
friendly_name: Badkamer
