Honeywell Total Connect suddenly not working
Just discovered Honeywell integration stopped working all of a sudden. Anyone else seeing this?
2021-01-29 16:11:07 ERROR (MainThread) [homeassistant.core] Error executing service: <ServiceCall climate.set_hvac_mode (c:310110b658819e23fec286a39d041eee): hvac_mode=off, entity_id=['climate.office']>
  File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 445, in _make_request
    six.raise_from(e, None)
  File "<string>", line 3, in raise_from
  File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 440, in _make_request
    httplib_response = conn.getresponse()
  File "/usr/local/lib/python3.8/http/client.py", line 1347, in getresponse
    response.begin()
  File "/usr/local/lib/python3.8/http/client.py", line 307, in begin
    version, status, reason = self._read_status()
  File "/usr/local/lib/python3.8/http/client.py", line 268, in _read_status
    line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
  File "/usr/local/lib/python3.8/socket.py", line 669, in readinto
    return self._sock.recv_into(b)
  File "/usr/local/lib/python3.8/ssl.py", line 1241, in recv_into
    return self.read(nbytes, buffer)
  File "/usr/local/lib/python3.8/ssl.py", line 1099, in read
    return self._sslobj.read(len, buffer)
socket.timeout: The read operation timed out
  File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 439, in send
    resp = conn.urlopen(
  File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 755, in urlopen
    retries = retries.increment(
  File "/usr/local/lib/python3.8/site-packages/urllib3/util/retry.py", line 531, in increment
    raise six.reraise(type(error), error, _stacktrace)
  File "/usr/local/lib/python3.8/site-packages/urllib3/packages/six.py", line 735, in reraise
    raise value
  File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 699, in urlopen
    httplib_response = self._make_request(
  File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 447, in _make_request
    self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
  File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 336, in _raise_timeout
    raise ReadTimeoutError(
urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='www.mytotalconnectcomfort.com', port=443): Read timed out. (read timeout=30)
  File "/usr/src/homeassistant/homeassistant/core.py", line 1461, in catch_exceptions
    await coro_or_task
  File "/usr/src/homeassistant/homeassistant/core.py", line 1480, in _execute_service
    await handler.job.target(service_call)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
    await self.hass.helpers.service.entity_service_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 593, in entity_service_call
    future.result()  # pop exception if have
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 664, in async_request_call
    await coro
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 630, in _handle_entity_call
    await result
  File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 430, in async_set_hvac_mode
    await self.hass.async_add_executor_job(self.set_hvac_mode, hvac_mode)
  File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
  File "/usr/src/homeassistant/homeassistant/components/honeywell/climate.py", line 354, in set_hvac_mode
    self._device.system_mode = self._hvac_mode_map[hvac_mode]
  File "/usr/local/lib/python3.8/site-packages/somecomfort/client.py", line 170, in system_mode
    self._client._set_thermostat_settings(
  File "/usr/local/lib/python3.8/site-packages/somecomfort/client.py", line 482, in _set_thermostat_settings
    result = self._post_json(url, data=data)
  File "/usr/local/lib/python3.8/site-packages/somecomfort/client.py", line 447, in _post_json
    return self._request_json('post', *args, **kwargs)
  File "/usr/local/lib/python3.8/site-packages/somecomfort/client.py", line 430, in _request_json
    resp = getattr(self._session, method)(*args, **kwargs)
  File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 590, in post
    return self.request('POST', url, data=data, json=json, **kwargs)
  File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 542, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 655, in send
    r = adapter.send(request, **kwargs)
  File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 529, in send
    raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPSConnectionPool(host='www.mytotalconnectcomfort.com', port=443): Read timed out. (read timeout=30)
Looks like the portal is having issues… if I try going to Honeywell Home - My Total Connect Comfort it spins for a very long time.
For what it’s worth, it comes up fine for me and the logs are showing no errors.
