I am attempting to get this integration work. I have a new folder that I created within custom_components called ‘tuxedo’. In that folder I have the alarm_control_panel.py, manifest.json and init.py.
Downloaded from (home-assistant/homeassistant/components/tuxedo at dev · hinzo/home-assistant · GitHub)
Within my configuration.yaml I have added the following lines with the appropriate data:
#Tuxedo
alarm_control_panel:
- platform: tuxedo
mac: 0xxxxxxxx
url: https://1xxxxxxxx
private_key: 4xxxxxxxxxxxxxxxxxx3
code: xxxx'
I am getting the following error
[140563627163168] The system cannot restart because the configuration is not valid: Platform error alarm_control_panel.tuxedo - Integration ‘tuxedo’ not found.
11:37:39 AM – (ERROR) Home Assistant WebSocket API
Can someone please advise as to what I am doing wrong?
Thank you!
