Honeywell Vista 20P Full Keypad via Envisalink
I have a use for a full keypad in my Home Assistant deployment, mostly for programming the Honeywell Vista 20P panel remotely. While if you don’t enter a code in the Envisalink config it will display a keypad, that keypad can only be used for arming or disarming the system, and not as a normal keypress.
There may be some other ways to do this, but this was fairly easy to put together. I was hoping that I could use variables and then have the service call be part of a button template, but I wasn’t finding luck with that method, so had to make each individual button be a little long with the configuration lines.
This assumes that you have installed custom:button-card and are using the envisalink_new integration found on HACS, though there is no reason that this wouldn’t work with the legacy Envisalink integration that is built into HA with minor tweaking.
Lovelace Code:
type: vertical-stack
cards:
  - type: custom:button-card
    entity: sensor.alarm_keypad
    show_name: false
    show_icon: false
    label: |
           var alpha = states['sensor.alarm_keypad'].attributes.alpha;
           return alpha.substr(0,16) + '<br>' + alpha.substr(16,32)
    show_label: true
    styles:
      label:
        - font-family: monospace
      card:
        - border: >
            [[[  if (states['binary_sensor.alarm_ready'].state === 'on') return
            'solid 3px green';  if (states['binary_sensor.alarm_ready'].state
            === 'off') return 'solid 3px orange'; ]]]
  - square: false
    type: grid
    cards:
        show_label: true
        label: 'OFF'
        tap_action:
          action: call-service
          service: envisalink_new.alarm_keypress
          service_data:
            entity_id: alarm_control_panel.alarm
            keypress: '1'
        styles:
          card:
            - height: 50px
          label:
            - font-size: 14px
        show_label: true
        label: AWAY
        tap_action:
          service_data:
            keypress: '2'
        styles:
          card:
            - height: 50px
          label:
            - font-size: 14px
        show_label: true
        label: STAY
        tap_action:
          service_data:
            keypress: '3'
        styles:
          card:
            - height: 50px
          label:
            - font-size: 14px
        show_label: true
        label: MAX
        tap_action:
          service_data:
            keypress: '4'
        styles:
          card:
            - height: 50px
          label:
            - font-size: 14px
        show_label: true
        label: TEST
        tap_action:
          service_data:
            keypress: '5'
        styles:
          card:
            - height: 50px
          label:
            - font-size: 14px
        show_label: true
        label: BYPASS
        tap_action:
          service_data:
            keypress: '6'
        styles:
          card:
            - height: 50px
          label:
            - font-size: 14px
        show_label: true
        label: INSTANT
        tap_action:
          service_data:
            keypress: '7'
        styles:
          card:
            - height: 50px
          label:
            - font-size: 14px
        show_label: true
        label: CODE
        tap_action:
          service_data:
            keypress: '8'
        styles:
          card:
            - height: 50px
          label:
            - font-size: 14px
        show_label: true
        label: CHIME
        tap_action:
          service_data:
            keypress: '9'
        styles:
          card:
            - height: 50px
          label:
            - font-size: 14px
        show_label: true
        label: READY
        tap_action:
          service_data:
            keypress: '*'
        styles:
          card:
            - height: 50px
          label:
            - font-size: 14px
        show_label: true
        tap_action:
          service_data:
            keypress: '0'
        styles:
          card:
            - height: 50px
          label:
            - font-size: 14px
        show_label: true
        tap_action:
          service_data:
            keypress: '#'
        styles:
          card:
            - height: 50px
          label:
            - font-size: 14px
Here’s a way cleaner way to do this with the use of a few custom cards.
decluttering_templates:
  alarm_button:
    card:
      show_label: true
      label: '[[label]]'
      tap_action:
        service_data:
          keypress: '[[key]]'
      styles:
        card:
          - height: 50px
        label:
          - font-size: 14px
type: custom:yet-another-expander-card
gap: 0.6em
padding: 0em
clear: false
overlay-margin: 1em
child-padding: 0.5em
button-background: transparent
title-card-button-overlay: true
title-card:
  show_name: false
  show_icon: false
  label: |
  show_label: true
  styles:
    label:
    card:
      - border: >
          'solid 3px green';  if (states['binary_sensor.alarm_ready'].state ===
      - height: 75px
cards:
  - square: false
    type: grid
    columns: 3
    cards:
      - type: custom:decluttering-card
        template: alarm_button
        variables:
          - key: 1
          - label: 'OFF'
        variables:
          - key: 2
          - label: AWAY
        variables:
          - key: 3
          - label: STAY
        variables:
          - key: 4
          - label: MAX
        variables:
          - key: 5
          - label: TEST
        variables:
          - key: 6
          - label: BYPASS
        variables:
          - key: 7
          - label: INSTANT
        variables:
          - key: 8
          - label: CODE
        variables:
          - key: 9
          - label: CHIME
        variables:
          - key: '*'
          - label: READY
        variables:
          - key: '0'
          - label: null
        variables:
          - key: '#'
          - label: null
@bdf0506 thank you for making this. Looks like some of the card add-ons you are using have changed. Have you updated with the newer versions?
Also, I tried using your original code and seems that it is not rendering the status window at the top?
It looks like the expander-card that was being used in this has been taken down by the author. I seem to recall having a hard time with that card when I first put this together.
I think it can be subbed out with this one: GitHub - Alia5/lovelace-expander-card: Expander card for HomeAssistant
But I haven’t had much luck with getting HA to use that card.
Since I had the old card in my instance, it’s running off the locally downloaded file, but I can see where it wouldn’t carry over to a new instance.
Without the expanding part of the card, here’s a simple vertical stack which will work. It’s mostly the same code, with a few slight modifications that ChatGPT told me to make.
cards:
    show_name: false
    show_icon: false
    label: |
        var alpha = states['sensor.alarm_keypad'].attributes.alpha || '';
        return alpha.length > 16
          ? alpha.substr(0, 16) + '<br>' + alpha.substr(16, 16)
          : alpha;
    show_label: true
    styles:
      label:
      card:
        - border: |
              if (states['binary_sensor.alarm_ready'].state === 'on') {
                return 'solid 3px green';
              if (states['binary_sensor.alarm_ready'].state === 'off') {
              return 'solid 3px gray'; // Default border
  - type: grid
    square: false
    columns: 3
    cards:
        variables:
          - key: '1'
          - label: 'OFF'
        variables:
          - key: '2'
          - label: 'AWAY'
        variables:
          - key: '3'
          - label: 'STAY'
        variables:
          - key: '4'
          - label: 'MAX'
        variables:
          - key: '5'
          - label: 'TEST'
        variables:
          - key: '6'
          - label: 'BYPASS'
        variables:
          - key: '7'
          - label: 'INSTANT'
        variables:
          - key: '8'
          - label: 'CODE'
        variables:
          - key: '9'
          - label: 'CHIME'
        variables:
          - key: '*'
          - label: 'READY'
        variables:
          - key: '0'
          - label: ''
        variables:
          - key: '#'
          - label: ''
@bdf0506 I had to change the code to get it working for my Ademco panel. The Entities you call in yours are not the same name in mine. Not sure why.
Not sure if you can make some variables at the top of the code, so people can set the Entities in one spot but that might be useful.
btw, REALLY nice work on this. Its kind a hidden in the forums, have you considered making it a HACS install?
Below is the code I use with my EVL3.
Entities are…
  • sensor.alarm_partition_1_keypad
  • alarm_control_panel.alarm_partition_1
cards:
    entity: sensor.alarm_partition_1_keypad
    show_name: false
    show_icon: false
    label: |
           var alpha = states['sensor.alarm_partition_1_keypad'].attributes.alpha;
    show_label: true
    styles:
      label:
      card:
        - border: >
            [[[  if (states['binary_sensor.alarm_partition_1_ready'].state ===
            'on') return 'solid 3px green';  if
            (states['binary_sensor.alarm_partition_1_ready'].state === 'off')
  - square: false
    type: grid
    cards:
        show_label: true
        label: "OFF"
        tap_action:
          service_data:
            entity_id: alarm_control_panel.alarm_partition_1
            keypress: "1"
        styles:
          card:
            - height: 50px
          label:
            - font-size: 14px
        show_label: true
        label: AWAY
        tap_action:
          service_data:
            keypress: "2"
        styles:
          card:
            - height: 50px
          label:
            - font-size: 14px
        show_label: true
        label: STAY
        tap_action:
          service_data:
            keypress: "3"
        styles:
          card:
            - height: 50px
          label:
            - font-size: 14px
        show_label: true
        label: MAX
        tap_action:
          service_data:
            keypress: "4"
        styles:
          card:
            - height: 50px
          label:
            - font-size: 14px
        show_label: true
        label: TEST
        tap_action:
          service_data:
            keypress: "5"
        styles:
          card:
            - height: 50px
          label:
            - font-size: 14px
        show_label: true
        label: BYPASS
        tap_action:
          service_data:
            keypress: "6"
        styles:
          card:
            - height: 50px
          label:
            - font-size: 14px
        show_label: true
        label: INSTANT
        tap_action:
          service_data:
            keypress: "7"
        styles:
          card:
            - height: 50px
          label:
            - font-size: 14px
        show_label: true
        label: CODE
        tap_action:
          service_data:
            keypress: "8"
        styles:
          card:
            - height: 50px
          label:
            - font-size: 14px
        show_label: true
        label: CHIME
        tap_action:
          service_data:
            keypress: "9"
        styles:
          card:
            - height: 50px
          label:
            - font-size: 14px
        show_label: true
        label: READY
        tap_action:
          service_data:
            keypress: "*"
        styles:
          card:
            - height: 50px
          label:
            - font-size: 14px
        show_label: true
        tap_action:
          service_data:
            keypress: "0"
        styles:
          card:
            - height: 50px
          label:
            - font-size: 14px
        show_label: true
        tap_action:
          service_data:
            keypress: "#"
        styles:
          card:
            - height: 50px
          label:
            - font-size: 14px
Expandable Collapsible version of the keypad.
Hides buttons / keys when not expanded
type: custom:expander-card
title: null
expanded: false
child-margin-top: 0.5em
padding: 3px
clear-children: true
clear: true
title-card-clickable: true
title-card:
  show_name: false
  show_icon: false
  label: |
  show_label: true
  styles:
    label:
    card:
      - border: >
      - square: true
cards:
  - type: grid
    columns: 3
    square: false
    column_width: 60px
    cards:
        show_label: true
        label: "OFF"
        tap_action:
          service_data:
            keypress: "1"
        styles:
          card:
            - height: 45px
            - margin: 0px
            - padding: 0px
          label:
            - font-size: 14px
        show_label: true
        label: AWAY
        tap_action:
          service_data:
            keypress: "2"
        styles:
          card:
            - height: 45px
            - margin: 0px
            - padding: 0px
          label:
            - font-size: 14px
        show_label: true
        label: STAY
        tap_action:
          service_data:
            keypress: "3"
        styles:
          card:
            - height: 45px
            - margin: 0px
            - padding: 0px
          label:
            - font-size: 14px
        show_label: true
        label: MAX
        tap_action:
          service_data:
            keypress: "4"
        styles:
          card:
            - height: 45px
            - margin: 0px
            - padding: 0px
          label:
            - font-size: 14px
        show_label: true
        label: TEST
        tap_action:
          service_data:
            keypress: "5"
        styles:
          card:
            - height: 45px
            - margin: 0px
            - padding: 0px
          label:
            - font-size: 14px
        show_label: true
        label: BYPASS
        tap_action:
          service_data:
            keypress: "6"
        styles:
          card:
            - height: 45px
            - margin: 0px
            - padding: 0px
          label:
            - font-size: 14px
        show_label: true
        label: INSTANT
        tap_action:
          service_data:
            keypress: "7"
        styles:
          card:
            - height: 45px
            - margin: 0px
            - padding: 0px
          label:
            - font-size: 14px
        show_label: true
        label: CODE
        tap_action:
          service_data:
            keypress: "8"
        styles:
          card:
            - height: 45px
            - margin: 0px
            - padding: 0px
          label:
            - font-size: 14px
        show_label: true
        label: CHIME
        tap_action:
          service_data:
            keypress: "9"
        styles:
          card:
            - height: 45px
            - margin: 0px
            - padding: 0px
          label:
            - font-size: 14px
        show_label: true
        label: READY
        tap_action:
          service_data:
            keypress: "*"
        styles:
          card:
            - height: 45px
            - margin: 0px
            - padding: 0px
          label:
            - font-size: 14px
        show_label: true
        tap_action:
          service_data:
            keypress: "0"
        styles:
          card:
            - height: 45px
            - margin: 0px
            - padding: 0px
          label:
            - font-size: 14px
        show_label: true
        tap_action:
          service_data:
            keypress: "#"
        styles:
          card:
            - height: 45px
            - margin: 0px
            - padding: 0px
          label:
            - font-size: 14px
@bdf0506 Curious if you have the issue where the status readout display shows ‘Stay’ when its in Away mode?
HA’s built-in keypad status always shows the status correctly so maybe I’m doing something wrong with your keypad?
