Should install the version specified in the error message. I don’t know about the component being broken as I stoppe dusing it a few months ago when I moved to an ecobee. But you can always check the issues over at GitHub.
I am in a similar situation (Windows 10). I am receiving the following error in my log:
homeassistant.bootstrap: Not initializing climate.honeywell because could not install dependency somecomfort==0.3.2
So I attempted to install somecomfort with the following command:
pip3 install somecomfort==0.3.2
But, I get the following error(s):
Collecting somecomfort==0.3.2
Using cached somecomfort-0.3.2.tar.gz
Exception:
File "c:\users\ryan\appdata\local\programs\python\python35\lib\site-packages\pip\basecommand.py", line 215, in main
status = self.run(options, args)
File "c:\users\ryan\appdata\local\programs\python\python35\lib\site-packages\pip\commands\install.py", line 324, in run
requirement_set.prepare_files(finder)
File "c:\users\ryan\appdata\local\programs\python\python35\lib\site-packages\pip\req\req_set.py", line 380, in prepare_files
ignore_dependencies=self.ignore_dependencies))
File "c:\users\ryan\appdata\local\programs\python\python35\lib\site-packages\pip\req\req_set.py", line 620, in _prepare_file
session=self.session, hashes=hashes)
File "c:\users\ryan\appdata\local\programs\python\python35\lib\site-packages\pip\download.py", line 821, in unpack_url
hashes=hashes
File "c:\users\ryan\appdata\local\programs\python\python35\lib\site-packages\pip\download.py", line 663, in unpack_http_url
unpack_file(from_path, location, content_type, link)
File "c:\users\ryan\appdata\local\programs\python\python35\lib\site-packages\pip\utils\__init__.py", line 605, in unpack_file
untar_file(filename, location)
File "c:\users\ryan\appdata\local\programs\python\python35\lib\site-packages\pip\utils\__init__.py", line 577, in untar_file
with open(path, 'wb') as destfp:
OSError: [Errno 22] Invalid argument: 'C:\\Users\\Ryan\\AppData\\Local\\Temp\\pip-build-373unzoh\\somecomfort\\tests/cassettes/set-attr-hold_heat-17:00:00.json'
I really don’t know what to do to resolve this. Any ideas?
