Can someone help me extend the automation below just a bit. I’m hoping to get it to differentiate “armed_night” and “armed_away”; right now whether I leave home or gets late at night (in my setup, it is 11pm), the alarm always goes to “armed_night”.
In my instance, I would like it to go to “armed night” at 11 pm if everyone is home and to “armed_away” if everyone is “not_home”.
Thank you all for your help on this!
- id: sentry_mode_enabled
alias: Sentry Mode Enabled Announcement
initial_state: true
- platform: state
entity_id: input_boolean.sentry_mode
to: "on"
- choose:
- conditions:
- condition: or
conditions:
- condition: state
entity_id: group.external_doors
state: 'on'
- condition: state
entity_id: group.garage_doors
state: open
sequence:
- service: input_boolean.turn_off
entity_id: input_boolean.lockdown_issue
- service: script.text_notify
who: "parents"
message: "Unable to lock down Turner House due to issue"
- service: script.speech_engine
data_template:
# who: "kitchen"
message: >
"I was unable to activate barn door protocol due to an open door.",
"You may want to check the external doors. I was unable to secure them all.",
"My systems check has failed. Please check the external doors.",
"Someone has left the pod bay doors open."
] | random }}
default:
data_template:
# who: "kitchen"
message: >
"Barn door protocol has been activated.",
"Turner House has been secured! ",
"Sentry Mode is active. ",
"I am now monitoring the doors and will let you know if anyone attempts to access.",
"Turner House Shields are up."
] | random }}
- service: alarmo.arm
entity_id: alarm_control_panel.alarmo
code: '1131'
mode: armed_night
- service: script.turn_on
entity_id: script.reset_front_door_motion_count
There’s quite a bit of fundamental things you need to do this though.
You need home presence nailed. You don’t want to be arming your system away when you’re home or visa versa. Do you have that nailed? IMO simply using whether a phone is home or not isn’t enough in my house. I use a house presence to determine who is home and whether they are upstairs, etc.
Luckily for now, there are just 2 of us and the phone presence only is working very well (they are pretty much always with each of us if we are gone); what are some thoughts you were having though, I’m all ears.
@calisro Thank you for the help you have given me in the past and responding here.
**EDIT: Also, the above was stolen code that I am trying to adapt for my situation.
Heck, I stole the whole home assistant setup from the youtuber slackerlabs (github repo)
This is how I manage auto-arming my alarm when the house is vacant. It incorporates quite a bit into the house_occupied group including phone presense, wasp sensors, and such. In your case, you’d probably substitute that for your own trigger.
alias: Ring Auto Arm Away v4
description: ''
- platform: state
entity_id: group.house_occupied
to: 'off'
for:
hours: 0
minutes: 10
seconds: 0
condition:
- condition: state
entity_id: input_boolean.auto_arm_away
state: 'on'
- condition: state
entity_id: alarm_control_panel.tampa_alarm
state: disarmed
- condition: state
state: 'off'
entity_id: input_boolean.arm_away_trigger
data: {}
- service: timer.start
duration: '120'
entity_id: timer.auto_arm_time
- service: script.tts_no_interrupt
target: group.all_speakers_n_kids
message: Alarm will be arming soon. Say Google Dont Arm to disable.
volume: 1
- wait_for_trigger:
- platform: state
to: 'off'
timeout: '20'
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
- service: notify.phone_notifications
title: >-
Auto Arm Alarm activates at
{{state_attr('timer.auto_arm_time','finishes_at')| as_datetime |
as_timestamp | timestamp_custom("%I:%M %p") }} .
message: Select Alarm Action
tag: Ring-General
group: Ring
timeout: >-
{{(as_timestamp(state_attr('timer.auto_arm_time','finishes_at'))-as_timestamp(now()))|int}}
ttl: 0
priority: high
color: yellow
notification_icon: mdi:shield-sync-outline
actions:
- action: alarm-disable-autoarm
title: Disable Auto Arm Away
chronometer: true
when: >-
{{(as_timestamp(state_attr('timer.auto_arm_time','finishes_at')))|int(0)}}
default: []
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 1
- repeat:
while:
- condition: state
state: active
- condition: state
state: 'on'
- condition: state
state: 'on'
sequence:
- parallel:
message: >-
The alarm is arming {% if
states.timer.auto_arm_time.attributes.finishes_at %}
in {{(as_timestamp(state_attr('timer.auto_arm_time','finishes_at'))-now().timestamp())|round}} seconds.
{% else %}
very soon.
{% endif %} To stop auto arm, Tell Google Dont Arm.. or walk
in front of an alarm motion sensor.. Or open and close an
exterior door.
volume: 1
- service: homeassistant.turn_on
data: {}
entity_id: switch.tampa_siren
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 300
- service: homeassistant.turn_off
data: {}
- wait_for_trigger:
- platform: state
entity_id: group.house_presense
- platform: state
to: 'on'
- platform: state
to: 'off'
- platform: state
to: 'off'
timeout: '20'
- choose:
- conditions:
- condition: template
value_template: '{{ wait.trigger == None }}'
sequence: []
default:
- service: timer.finish
data: {}
data: {}
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
- parallel:
message: Auto Arming Alarm Now.
volume: 1
- service: script.alarm_arm_away
data: {}
data: {}
title: Auto Arm Alarm Arming.
tag: Ring-General
group: Ring
timeout: 300
color: red
ttl: 0
priority: high
notification_icon: mdi:shield-check-outline
default:
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 500
- parallel:
message: Auto Arm Disabled. Will Not Arm Alarm.
title: Auto Arm Alarm was disabled.
message: Alarm will not arm
tag: Ring-General
group: Ring
timeout: 300
ttl: 0
priority: high
color: yellow
notification_icon: mdi:shield-off-outline
mode: single
I basically broadcast in the house just incase someone is there when I try to arm away and if no one disables the auto-arm-away, it turns it on. Works well for me incase I left a kid home and presence didn’t detect them for some reason. They can simply disable it with their voice or by walking in front of a sensor.
I use something different for when we are home.
alias: Ring Auto Arm Home v3
description: ''
- platform: state
entity_id: input_boolean.auto_arm_home
to: 'on'
- platform: time
at:
- '22:30:00'
- '23:00:00'
- '23:30:00'
- '00:00:00'
- '00:30:00'
enabled: false
- platform: state
for:
hours: 0
minutes: 0
seconds: 30
entity_id: sensor.master_bed_state
to: Occupied
- platform: time_pattern
minutes: /15
condition:
- condition: state
state: 'on'
for:
hours: 0
minutes: 0
seconds: 30
- condition: state
state: 'on'
- condition: state
state: disarmed
- condition: state
entity_id: group.downstairs_occupied
state: 'off'
for:
hours: 0
minutes: 1
seconds: 0
- condition: state
state:
- Occupied
- condition: time
after: '21:29:00'
before: '05:00:00'
- condition: state
entity_id: media_player.living_room_shield
state:
- standby
- 'off'
for:
hours: 0
minutes: 0
seconds: 30
- condition: state
entity_id: input_boolean.company
state: 'off'
- condition: state
entity_id: media_player.backyard_tv
state:
- standby
- 'off'
for:
hours: 0
minutes: 0
seconds: 30
- service: script.alarm_arm_home
data: {}
mode: single
Ahh, I understand the necessity now. Thank you for sharing you’re approach at this. The thing I was having difficulty with was differentiating between night and away with what I have. The only way I could think to do it was to use “choose” with one path being the condition of time and the other path, being the condition of who’s home???
Thank you for this one also. It will be good for me to review other people’s approaches at these things. This was about the last thing I wanted to correct before I could say I am at a good minimum requirement base once I moved over from smartthings.
@calisro Rob, I hate to ask you another question but this one has been bugging me a bit and I just figured I would throw it out there to you as I can tell you know what you’re doing. So:
Is there a benefit to having the scripts and automations built strictly in yaml packages or in yaml in general?
To be honest, I don’t see a benefit other than possibly some organization that you get with packages. And with me being a noncoder, it seems like a nightmare for myself to build automations outside of the GUI.-- I’ve considered pulling everything out of “yaml” only but I don’t know if it’s a good idea and was wandering some others opinions on this (maybe I should start another thread)
What are your thought on this? For now, since, I stole most of my setup from a more capable individual, almost everything is in packages. What is your opinion of this whole situation?
It’s preference. I haven’t used packages much but they do help keep things organized. A package is nothing but a group of related things.
It we’re being upfront, I probably would have used packages if I knew more about HA back when I started. There’s some functionality that would have been nice to have just in one place.
But it’s really just organization preference.
I don’t really use the gui much anymore now that I know the syntax. I use the editor UI but typically write in the yaml editor.
