Hoppe eHandle ConnectSense for Windows Experience
Hello all.
I wanted to share my experience with the window handle from Hoppe.
I have been looking for a way to determine the position of the window handle, as a simple open/closed status of the window sash is not always sufficient for me.
Since I already operate > 50 Zwave devices anyway, I stumbled upon this handle by chance.
The quality is excellent. In my stainless steel variant, the workmanship and the material is simply top. So you do not build a China junk to the windows.
The mechanical installation was easy in my case, because I had previously installed window handles from Hoppe. To find the correct dimension, I have removed and measured an old one before ordering.
The integration in zwave-js is available in the current versiion. So an inclusion via SmartStart was no problem. However, I could not scan the code, but had to type it.
After that the handle reports the following values:
-window sash open/closed
-window tilted
-Intrusion attempt detected
-The handle position can be determined indirectly via the last action (manual lock/unlock is sent via notfication).
So far, all this works very reliably. I am very satisfied with this window handle, even if it is, depending on the variant, quite expensive (130-200€).I have now installed 7 pieces on the first floor.
Greetings Olli
Hi Olli,
thank you for sharing your experience which convinced me to write my first message.
I started with one piece to make sure that this device is reliable and can confirm a great experience.
I only use the built in “Home Security Sensor status”. Closed/open/tilted is detected by an automation script consuming the zwave_js_notification of command_class 113 and type 6 to make sure that I receive the status depending on the handle position without the window position itself. The reason is that I want to retrieve an open/tiltet status even if the window is leant to the frame.
To make sure that I only get the information that is needed I have optimized my dashboard to show an handle only if any of the following condition matches:
  • Security Sensor != ‘idle’
  • Handle is not closed
The card shows the following information:
  • First Icon: yellow if tilted, orange if open
  • Name: Window
  • Security Icon: yellow if window is not closed (and therefore the handle security sensor is inactive), green (closed and idle) or red flashing on intrusion (whole line is flashing)
  • Ventilation recommandation icon: green if humidity calculation makes sense, yellow if not and window is closed, red if not and window != closed
  • Status (Gekippt=tilted)
Window_Handle_Card
Hope that this is helpful for someone!
I just added a ConnectSense handle as my first z-wave device. So apologies, if I miss something very basic.
The integration worked fine and I can see intrusion, open/close and tilt status of the handle, as described by @memphi2.
Can you help me detecting the “regular” open handle status as well? Apparently this is possible as described by @hoca2023, but I’d need some more pointers :grimacing:
I am right now only using what came “out-of-the-box” after adding the device in Z-Wave JS
While “Sensor state (Tilt)” works just fine, there isn’t an entity “Sensor state (Regular)” etc. and the Entities “Window/door is open in regular/tilt position” are always “Off” (even if “Sensor State (Tilt)” shows “On”, “Window/door is open in tilt position” shows “Off”.
Any hints?
Hi Dirk,
I use classic Home Assistant automations, one per handle.
You only have to replace the value for node_id using your handle id in the below automation script. If you are using Z-Wave JS you can select the device and open “Z-Wave Info” to find your id.
In addition you have to create a helper variable of type text (office_window_state).
The automation will fill the variable when you open/close/tilt the handle. If you miss the position, e.g if you rotate the handle from closed about 20° you will ran into the default action of the automation and the variable is filled with “Unknown”. This could be enhanced to a more detailed status but as a closed handle should be closed this information is detailed enough from my point of view.
I know that this script can be simplified but in the current version it should help to understand the different parameters the handle will deliver.
alias: Window Handle - Office
description: ""
  - platform: event
    event_type: zwave_js_notification
    event_data:
      domain: zwave_js
      node_id: 26
      command_class: 113
      type: 6
condition: []
  - choose:
      - conditions:
          - condition: or
            conditions:
              - condition: template
                value_template: "{{ trigger.event.data.parameters.data==[0, 0]}}"
                value_template: "{{ trigger.event.data.parameters.data==[1, 0]}}"
                value_template: "{{ trigger.event.data.parameters.data==[2, 0]}}"
                value_template: "{{ trigger.event.data.parameters.data==[3, 0]}}"
        sequence:
          - service: input_text.set_value
              entity_id: input_text.office_window_state
              value: Open
      - conditions:
          - condition: or
            conditions:
                value_template: "{{ trigger.event.data.parameters.data==[0, 1]}}"
                value_template: "{{ trigger.event.data.parameters.data==[1, 1]}}"
                value_template: "{{ trigger.event.data.parameters.data==[2, 1]}}"
                value_template: "{{ trigger.event.data.parameters.data==[3, 1]}}"
        sequence:
              value: Tilted
      - conditions:
          - condition: or
            conditions:
                value_template: "{{ trigger.event.data.parameters.data==[0, 2]}}"
                value_template: "{{ trigger.event.data.parameters.data==[1, 2]}}"
                value_template: "{{ trigger.event.data.parameters.data==[2, 2]}}"
                value_template: "{{ trigger.event.data.parameters.data==[3, 2]}}"
        sequence:
              value: Closed
    default:
          value: Unknown
mode: queued
Thanks for the quick reply - will give it a try (as soon as I get access again to my Z-Wave JS plugin again :roll_eyes:).
So do I understand correctly, that I did not nothing wrong/there is nothing wrong, but thes two handle state entities (“Window/door is open in regular/tilt position”) simply don’t work/have no function with the Hoppe ConnectSense?
If you did something wrong I did it wrong in the same way :wink:
After adding the device the available sensors did not show all states and that is why I decided to use the automation.
Hope that you can solve the problem of getting access to your Plugin(s).
I dug a bit into the Z-Wave standard and Hoppe’s implementation and I think there is simply no position state for the handle in “regular open position”. The ConnectSense is only sending window open/close state, handle fully open (tilt position) and close position and intruder alert status (plus some general status info, like battery SoC etc.). At least that’s all what is configured/visible in Z-Wave JS and the information I found at the Z-Wave registry lists even less… So I think the way you derive the “handle in open position” (non-tilt) is the only way to do it.
I did, thanks. Power cycle was the solution (I don’t have a clue why :wink:).
Works perfect. Thank you so much!
Hi, i got some of the shellys with zwave and joined the zwave universum too. thank you for sharing this. i purchased two of these Hoppe eHandle and just want to quickly share my eventbased trigger helper sensor. So you dont have to create an automation for it.
template:
  - trigger:
      - trigger: event
        event_data:
            domain: zwave_js
            node_id: 6
            command_class: 113
            type: 6
      - name: Wohnzimmer TerrassentĂźr Status
        state: >
            {% if trigger.event.data.parameters['1'] | int == 0 %}
            {{ "Open" }}
            {% elif trigger.event.data.parameters['1'] | int == 1 %}
            {{ "Tilted" }}
            {% elif trigger.event.data.parameters['1'] | int == 2 %}
            {{ "Closed" }}
            {% else %}
            {{ "Unknown" }}
            {% endif %}
Hello
I’m new to Home Assistant and I also purchased a Hoppe handle for test purpose. I’m facing the same issue and want to try your solution, but I can’t find a way to create an “eventbased trigger helper sensor”.
I’m using the HA UI: Settings > Devices & Services > Helpers > Create Helper > Template > Template a sensor
But this tells me “This template does not listen for any events and will not update automatically.”
May be I’m too stupid, but which helper should I use to get a “eventbased trigger helper sensor”?
Thank you for your help.
I’m not sure if its possible in GUI. I think you have to use the yaml.
Hi all, for some reason I don’t receive any messages on “zwave_js_notification” anymore.
Is this just me?
Yep, the was an update. Reinterview them and have a look at the diagnostic sensors. There is a new sensor:
Thanks, Olli! Indeed I can now see the new sensor. Unfortunately it does not update and I can see errors in my log. My HA is up to date.
Any suggestions how to solve this?
Logger: zwave_js_server
Quelle: /usr/local/lib/python3.14/site-packages/zwave_js_server/event.py:74
Erstmals aufgetreten: 12:08:35 (4 Vorkommnisse)
Zuletzt protokolliert: 12:09:30
Error handling event: value updated
File “/usr/local/lib/python3.14/site-packages/zwave_js_server/event.py”, line 72, in emit
listener(data)
File “/usr/src/homeassistant/homeassistant/components/zwave_js/entity.py”, line 267, in _value_changed
self.async_write_ha_state()
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 1050, in async_write_ha_state
self._async_write_ha_state()
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 1199, in _async_write_ha_state
) = self.__async_calculate_state()
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 1106, in __async_calculate_state
state = self._stringify_state(available)
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 1056, in _stringify_state
if (state := self.state) is None:
File “/usr/src/homeassistant/homeassistant/components/sensor/init.py”, line 663, in state
raise ValueError(
…<2 lines>…
ValueError: Sensor sensor.door_griff_esszimmer_access_control_door_handle_state provides state value ‘24’, which is not in the list of options provided
Edit: I don’t get these errors when the entity is manual disabled by me. I already fully rebootet HA.
HA 2026.4.x is needed to support those sensors, so are you really up to date with HA and Z-Wave JS App?
In Zwave-JS it looks like this:
Reinterviewing is needed here.
regards
Olli
Yes this is my Z-Wave JS version: 1.1.0
And this is my HA version:
When I find some time I’ll try to delete and add the device again. Maybe that helps, Thanks so far, Olli! Nevertheless please let me know if you think you have a solution for this.
Re-adding helped! thanks a lot anyway, Olli!
