Horizontal Stack and Action Toggle not working
Hi Guys
I’m New in HA, so please forgive me for my stupidity.
I try to made a Horizontal Stack with many Entity Buttons, so i have created first scripts for every Button and if i add the Entity Button on the Dashboard it works with action: toggle.
If i create the Horizontal Stack and add the Buttons i can change anything but it remains on the default action : info.
So here is my config on the Horizontal Stack
type: horizontal-stack
title: Media Control
cards:
  - type: entity-button
    icon: 'mdi:television'
    entity: script.1577740137742
    action: toggle
    icon: 'mdi:apple'
    entity: script.1577745278123
    tap_action: null
    action: toggle
    tap_action: null
    action: toggle
    entity: script.1577745397782
    icon: 'mdi:power'
I have made the changes on the Editor of Lovelance UI and if i save and edit again it writes me on tap_action: null ( but i have write before tap_action: )(only, without none)
If i set tape_action: toggle, it works the toggle but the script was not executed.
Hope you can help me to understand what i made wrong:
i’m on the last release : 0.103.5
Thanks Fonio
Hi Fonio
you can’t toggle a script
if you look at the doc’s
you will see you need to use the call-service to run the script
example: in doc’s
type: entity-button
name: Turn Off Lights
tap_action:
  action: call-service
  service: script.turn_on
  service_data:
    entity_id: script.turn_off_lights
entity: script.turn_off_lights
As scripts are services you can simplify this to:
type: entity-button
tap_action:
  service: script.turn_off_lights
you still need the entity for that entity button
type: entity-button
tap_action:
Woops. Yes you do.
Oh my godness…thanks a lot a try it today later.
Thank you very much for your quick responses and
i wish you all a happy new year!
I have changed to call-service but same thing i receive the information window before i can execute the command, my code looks now:
cards:
    tap_action: null
    service_data: null
    entity_id: remote.harmonyhub
    icon: 'mdi:apple'
    tap_action: null
    service_data: null
    tap_action: null
    service_data: null
    icon: 'mdi:power'
2019-12-31 10_43_55-Home Assistant
Your indentation is not correct. Look at all the examples we gave you.
cards:
    tap_action:
      service: script.1577740137742
    icon: 'mdi:apple'
    tap_action:
      service: script.1577745278123
    icon: 'mdi:power'
    tap_action:
      service: script.1577745397782
Thank You! tom_I now it works :smiley:
